Question about Dell Inspiron 1525 Notebook
Mouse froze now willnot switch on
Press on button led flashes then clicks off
  • 979 Answers
Hello Sir, Hi, try removing the battery, and replug it again.
Posted on Apr 27, 2010
How do I setup a wireless mouse on a desktop
To setup a wireless mouse regardless of its type, do the following:
1. Insert the USB transmitter (this could look like a mini plug or a stick) and wait for windows to complete installation.
2. Once this is successful, turn on the mouse by holding down the power button. Or insert the disc that came with the mouse and run the installer. The installer will install the device drivers and setup your mouse's configuration panel which will reside in your system tray.
Make sure that the mouse has batteries and that it is switched on for it to work. It will glow red when it is switched on.
Jul 06, 2011 | Gigabyte Wireless Optical USB Mouse GMW7C
It won't sync
Click on the USB small button "after attach it to the computer" one click. While the red tiny led flashing - turn your mouse updown and hit the small button.
When the red flashing led stop - then you connected.
May 16, 2011 | Belkin Mini Wireless Optical Mouse...
Will not connect..its not in sync with my pc
Hello
Turn the switch to the "On" position, located underneath your mouse if your mouse has a switch.
Restart your computer to have a fresh starting point for troubleshooting. Sometimes, just restarting your computer can resolve issues you have with your HP wireless mouse.
Move your HP mouse about 39 inches away from your receiver.
Unplug your USB receiver, if you have one, and wait about 10 seconds.
Replug the USB receiver into another USB port, closer to your mouse if possible, then resynchronize your mouse and receiver.
Press and hold the connect button on your receiver, while plugged in, until you see the LED light flash.
Hold and press the connect button underneath your mouse until the LED light on the receiver stops flashing.
Check to make certain the button under your mouse does not get stuck in the depressed position and releases. Also, make certain you complete this resynchronizing process in 60 seconds, or else you must start over. Your mouse will now have a new identification number from resyncing.
Unplug the USB receiver, wait 10 seconds, then replug the receiver firmly into the USB slot, pushing it in entirely. You will notice the receiver's activity light turn on, then off in the next five seconds.
Press the connect button underneath your mouse until you see the activity light turn on again on the USB receiver.
Check to make certain the mouse connect button does not remain depressed when you release it.
Nov 14, 2010 | HP Wireless Optical Mouse
Hi I have a KM80545 (mikomi) Argos value range wireless keyboard. The keyboard has been working fine until the batteries needed changing. Hence I have changed batteries and the keyboard doesn't seem to be...
I had the exact same problem but with my mouse! the keyboard worked so it obviously was a problem related to connecting to the router (USB)
I later discovered that the LED light on the USB is a button, so click that and click the little circular button on the back of your mouse, then be patient, the mouse should reconnect!
Apr 24, 2010 | KME PC Keyboard and Mouse
Cannot get mouse to move arrow
Check the dongle to see if there are any buttons on it that need to be pressed.
Apr 21, 2010 | NexxTech NWOMUMI Mouse
I changed batteries and forgot how to reconnect. It is plugged in via USB, batteries are birght. I have pressed the connect button on the base. It flashes but the mouse does not work. I have pressed the...
This is from the manual for the Logitech MX700 cordless optical mouse.
1. Press connect button on Base Station.
Its LED blinks green. 2. Press connect
button on mouse bottom. Base Station LED
turns solid green, and then off.
I hope this helps
Mar 07, 2010 | Logitech MX 700 Mouse
We have a wireless keyboard and mouse and it seems that something between them and the computer is slow or off. we type and only a few letters appear..the mouse seems to be ok just kinda slow ofrom when...
Most likely you need to re-sync the device
  1. Resynchronizing the keyboard and/or mouse causes the devices to reconnect to the receiver using new identification numbers. Use the following steps to resync the devices:
    NOTE: The following connection sequence must be completed within 60 seconds. If the sequence is not done in 60 seconds, start over.
    1. With the receiver plugged in, press and hold the Connect button on the receiver until the activity LED flashes.
      NOTE: Some HP computers have receivers built into the front of the computer; such as TouchSmart 700 Series PCs and Digital Entertainment Centers. Look for a small connect button built into the case. If you have a TouchSmart 500 or 800 Series PC, the receiver plugs into a USB port on the underside of the case and does not have a connect button - skip this step. Figure 4: An example of a receiver c01065862.jpg 1 - Connect button and LED activity light Figure 5: Another example of a receiver c00526313.jpg 1 - Connect button 2 - Num Lock LED 3 - Alpha Lock LED 4 - Scroll Lock LED 5 - Activity LED
    2. Press and hold the recessed connect button on the underside of the keyboard until the activity light on the receiver stops flashing. When you release the button, make sure it does not stick in the depressed position.
      NOTE: If problems persist after resetting AND there is another wireless keyboard or mouse near, use these steps again, holding down the keyboard or mouse button for ten seconds. Doing so may give the keyboard or mouse a new ID number in case the other keyboard or mouse was using the same number.
    3. Press the Connect button on the receiver again until the activity light flashes.
    4. Press and hold the recessed button on the underside of the mouse until the activity light on the receiver stops flashing. Make sure the connect button does not stick in the depressed position.
  2. If your mouse and keyboard have a USB receiver, unplug the USB receiver, wait 10 seconds, and then insert into another USB port - preferably into a USB port that is closer to the mouse and keyboard. For example, if the USB receiver was plugged into a USB port on the back of the computer, unplug it and plug it into a front USB port.
Hope this helps!! Good luck!!
Sep 17, 2009 | HP Wireless Optical Mouse
My wireless keyboard stopped working the mouse works but not the keyboard what can i do
1)Verify that the batteries are correctly installed in the keyboard and mouse. If possible, use a fresh set of alkaline batteries. 2)Reset the keyboard and mouse connections : --With the receiver plugged in, press and hold the Connect button on the receiver until the activity LED flashes. --Press and hold the recessed connect button on the underside of the keyboard until the activity light on the receiver stops flashing. When you release the button, make sure it does not stick in the depressed position. --Press the Connect button on the receiver again until the activity light flashes. --Press and hold the recessed button on the underside of the mouse until the activity light on the receiver stops flashing. Make sure the connect button does not stick in the depressed position. --Make sure that the receiver is at least 20 centimeters (8 inches) away from other electrical devices (computer, monitor, keyboard, etc.). --Remove any other objects that are between the keyboard, mouse, and the receiver, especially speakers. Hope this should resolve the Issue. Thank you.
Sep 30, 2008 | Computers & Internet
Pairing my Macally BT micro mouse
Q: After pairing my mouse, the button click works but cursor tracking does not move. What can I do?A: The cursor tracking problem is because red sensor LED is not on. Please try another set of battery or fully charge battery again, and verify if bottom red LED turns on. If red LED still does not turn on, please remove batteries from mouse, press and hold the pairing button for 5 seconds, next press and hold the left and right buttons simultaneously for 10 seconds, followed by several clicks. Install the battery into mouse, you should see red LED turns on, mouse cursor will move.
Oct 03, 2007 | Macally BTMicro Mouse
Trouble pairing my bluetooth Macally BT micro mouse
Dell Inspiron 1525 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
