Question about GE Americana 15.6 Cu. Ft. Top-Freezer Refrigerator
My Americana refrigerator has completely stopped running. There is power to the unit as the light does come on when I open the door. I'm going to guess that the motor is bad, but I can't be sure. I'm hoping it's a simple fix. Thanks.
  • GE Master
  • 43,501 Answers
Yes, the compressor is not starting...these tips will help you with that...
Try change the start components....potential relay and start capacitor...if that don't work it is the compressor going bad...
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Asker's Testimonial " Thanks! You helped me to understand the relay and capacitor's purpose,and why a change in either may cause the compressor not to start. "
Posted on Apr 27, 2010
What do I check to fix my Dometic Americana refrigerator. It won't start using electric or gas.
Fist off before you get crazy replacing things make sure the camper is level when testing this. Gas will not run to it if you are not level. Also make sure the gas is turned on and make sure you have selected automatic or gas only on your fridge. Also give it about an hour before you test the temp. These take a bit longer to start feeling cool. If all of that does not work you will need to check the refrigerant, igniter(for the gas side) and the compressor. Also make sure the fuses are good to go at the main panel and that the breakers are in the "on" position
Sep 11, 2014 | Dometic DM2852 Americana Fridge...
Lights Out and Door Open Indicator Flashes
The problem is above the doors at the switch, the unit can't see the switch opening (closing the door opens the switch). The linkage is where the problem is, the light go out to protect the fridge from getting too warm and the lights are remaining on after you close the door.
I hope this helped. Good Luck
Dec 22, 2013 | KitchenAid Refrigerators
Service number kuds301xbl2
I would find the electrical breaker for this unit and shut it off for a minute, then re set the breaker thus resetting your unit.
Apr 28, 2013 | Maytag MDBH975AWS Stainless Steel...
No light, no cooling in refrigerator, but cold freezer Americana A3316ABSDRWW
This usually means you have ice build up between the two units. Defrost the freezer and if possible let it sit to completely thaw all ice from the channels that allow cold air from the freezer to move to the Refrigerator side. You will also want to check your door seals to make sure you don't have any leaks or a bad seal causing your issue. The issue with the light is most likely a burned Bulb or bad switch. Replace the bulb and see if that resolves the issue. You also need to check and make sure the fans are working properly which move the air from the freezer to the refrigerator side and that all the cooling grill son the unit are clean and not clogged with dust build up.
Nov 25, 2011 | KitchenAid Refrigerators
Moved unit to new loation plugged in and it started running and then open the refrigerator door and the unit stopped.
the move and opening the door didn't cause problem ck the plug in the wall and is light inside on . if not re ck power . if light is on it may have gone into a defrost cycle and it will not run for 1/2 hr . if it didn't start up then ck the cold control . these are some of the things that may have caused this . mm hope these help .
Oct 31, 2010 | Maytag Refrigerators
I have a Dometic Americana refrigerator that is not working. When I first turned it on, everything was fine. I left for about an hour and when I came back, there were no lights on the control panel or...
These often have a recall kit installed that has a thermal fuse in the burner area....when the burner overheats the thermal fuse shuts the hole thing down to prevent fire, the ammonia smell is probably from the cooling unit. check under your burner, to see if you see a bright yellow powder or liquid if you do, your cooling unit is for sure bad and is dangerous to run. The thermal fuse shuts the fridge down completely and can be reset by pushing in the button in the middle.
May 21, 2017 | Dometic RM2652 Refrigerator
Refrigerators Logo
284 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
