Question about Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook
My g4 power book screen is very dark
Change my g4 power book screen .but when i turned it on you can see it but it very dark. what do i go back and check for?
  • Apple Master
  • 3,866 Answers
This is door to a poor backlight meaning the backlight needs to be changed out. Going to cost like $125 for the part if you do not know how to do it then a tech will need to get involved so tack on your labor. I hope this helps as it did dozens of people with the same issue. please do leave ratings and feedback for your free answer today.
Posted on Apr 27, 2010
G4-1215dx screen is dark
A dark screen means the inverter maybe faulty or the CCFL lamp at the bottom of the LCD is faulty.
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Apr 03, 2013 | HP recertified pavilion g4-1215dx laptop -...
Dear I have change logic board for my Power-book G4 titanium a 1 GHz. when i turn on the machine i only have the shine sound and the display always white and doesn t see any symbol of apple. Why i have...
Try putting in your OSX cd and holding "C" when it boots up. The problem could be with the board or it might be just a problem with the screen.
After it boots try seeing if you can get it to make sounds by pushing the volume buttons. If it makes the "click" noise then it is the screen that needs fixing.
Jul 03, 2011 | Apple PowerBook G4 Mac Notebook
My G4 iBook screen goes dark shortly after I power-up, even If I hit the F2 key, the screen remains dark.
Got the same problem with my ibook G4.
I have research on how to fix it, and found out that most model of G4 has the same problem.
I soon found out the main problem and the solution, it would require some skill in soldering and dis assembling the whole laptop.
Go to this site and hope it will help you just it like it helps me a lot!
http://macintoshhowto.com/hardware/how-do-i-get-my-broken-g4-ibook-fixed.html
Thanks for using Fixya!
Dec 14, 2010 | Apple iBook G4 Mac Notebook
Powerbook g4 no brightness have yo use flash light
Okay. Try this
http://support.apple.com/kb/TA25861?viewlocale=en_US
If it does not help then it is possible that the Back light on the screen is faulty. If you just purchased the computer, then you should go back to the vendor and ask him to change or fix it .
Oct 25, 2010 | Apple Power book G4 Refurbished Notebook -...
When I turn on my 17" power book g4 I hear the drive and chime and see a blip of screen light up from the lower right corner of the screen but goes black right away. I have no software at this time. I...
Do you have this machine plugged into AC power? If not, you may just have a depleted battery, which would fit these symptoms perfectly.
The problem is not software related, because with a missing or empty internal drive you would get a flashing question mark folder icon instead.
Does the machine power off when the screen goes black, or does it continue to run with a dark screen? Common solution for the latter is to wait two minutes until the boot sequence sounds complete, then press the F2 button to raise the screen brightness. Failing that, you may have a blown-out backlight tube in the screen itself, which can be addressed.
Oct 18, 2009 | Apple Powerbook G4 17" 1.67 GHz SuperDrive...
Power Book G4 reinstall using Power Book G5 OS X10.4.6
Apple have software locks to stop you using the bundled disc in the "wrong" machine, get a copy of 10.4 (try eBay, ) and you should be OK
Apr 13, 2009 | Apple Titanium G4 and 8413i Book series AC...
My emac is on but the screen is dark and blank.
On the keyboad, above the numbers are the function keys. Depending on the keyboard being used, there is a key that changes the brightness of the screen. You can also go into your System Preferences under Displays and change it there.
Hope this helps
Verb
Mar 16, 2009 | Apple eMac G4 Desktop
Ibook screen issues
This is nearly impossible to diagnose via the Web. It sounds like the logic board is at fault, but not necessarily.
Nov 23, 2008 | Apple iBook G4 Mac Notebook
Hi sir/ Mm
look closely at the screen. You might have to change the lighting or shine a powerful light from the back of the screen, through the Apple logo. If you see a dim image, your problem is either with a bad "inverter" board, a bad "CCFL" light (the bulb that lights the screen), or with the logicboard itself. check back for more info if this is happening.
Jul 08, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook Logo
167 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
