Question about Kenwood KRF-V5060D Receiver
Kenwood amplifier 5.1 sound keeps droping out . Pro logic stop working then other sound modes stop working after a while i.e. stereo, Hall etc...
  • 3,083 Answers
You have a component (probably a transistor) that is overheating, or possibly a capacitor going bad. The circuit board will have to be troubleshot, and the bad component identified. Fortunately, heat problems can be figured out by buying some Freeze Spray (Freon), and when the unit acts up, you spray suspected components, slowly...until it works again. This will identify which component you need to replace by unsoldering, etc. I would start in the power supply area, if you can identify it...chances are that's where your problem is. Good luck, hope this helps.
Posted on Apr 27, 2010
The audio keeps going in and out and cuts off. Also I have other devices going into aux in but it doesn't show 5.1 surround it only shows the front L, Front R, and CT speakers in stereo. I want everything...
If you are playing a source that is Stereo such as FM Radio or a CD the sound will not use all 5.1 speakers unless you enable the correct Surround Mode. On the remote there is a button on the lower right of the remote that says SURROUND. You can toggle through the various surround modes with this button the mode you want is Dolby Pro Logic The Pro Logic mode uses the built-in circuit to steer the Left, Center, Right and Mono Surround channel audio signals and uses all five speakers to play both stereo and Dolby Pro Logic program source, such as TV and VCR. You can use this mode with any stereo program source (such as VCR/TV) to enjoy multi-channel sound experience.
Mar 02, 2011 | RCA RTD317W Theater System
No surround sound when watching tv or other programs also when you turn the sound down the volume numbers go up.
Mine used to work but I recently moved and think I connected everything the same way, but I'm having the same problem you are now and I'm just curious if you ever solved the issue? For whatever reason, I'm simply not seeing the Dolby Pro Logic, PL Movie, etc. modes. Just the standard Stereo, Arena, Theater, etc. modes. I'm connected to the receiver's optical audio inputs both directly from my cable box and from the TV itself, so I feel like I must just be overlooking something simple.
As for the numbers going up, it's not actually a problem... It's just something about the way DB (decibels) work I think.
Jan 09, 2011 | Kenwood VR-507 Receiver
Can;t play back surround speaker while watching tv programs.
Nov 27, 2010 | Kenwood VR-507 Receiver
Samsung ht-c550 dolby pro logic II mode does not work.
1. Go to the DVD input.
2. Select menu
3. Settings
4. Audio
5. ASC
6. Turn OFF the Auto Sound Calibration
7. Exit the menu
8. Go to the DVD input and retry the pro logic II button and switch to MATRIX.
(Also you have to enable the "matrix" setting each time on all of the inputs you use.)
Jul 07, 2010 | Samsung HTC550 Theater System
Lost manual..do not know what is the difference sound surround
Hi use this link to download the manual .
manualnguide.com/manual/teac-ag-v8060-receiver.../page/2/.
Take care.
May 18, 2010 | Teac AG-V8060 Receiver
Not getting true surround sound
The only way to get Dolby 5.1 audio out of the Xbox will be via fiber optic cable from the Xbox to a Dolby Digital amplifier - which will output a decoded 5.1 signal to a 6 channel amplifier and 5 speakers and one sub-woofer. I doubt the Logitech speaker system has a Dolby 5.1 decoder built in with the amplifier for under $100, but I can't say for sure. If the Logitech has a an optical (or TOSLink) input, connect it to the Xbox and follow the instructions below.
To configure your audio settings, follow these steps:
  1. Start the Xbox 360 console without a disc in the disc tray.
  2. In the System section of the Xbox Dashboard, select Console Settings.
  3. In the Console Settings area, select Audio.
  4. In the Audio Settings area, configure settings for analog output or digital output:
    • Analog output settings:
      • Dolby Pro Logic II: Select this setting for stereo systems or Dolby Pro Logic II-compatible systems.
      • Mono: Select this setting for systems that do not support stereo output. Note If you have connected to Xbox LIVE and downloaded any AutoUpdates, the Mono option will not be available.
    • Digital output settings:
      • Digital Stereo: Select this setting to use digital stereo output.
      • Dolby Digital 5.1: Select this setting to use Dolby Digital output.
      • Enable WMA Pro: Select this setting to enable WMA Pro pass-through if your receiver supports the WMA Pro format.
Note You must use one of the following cables to support digital output:
  • Xbox 360 Component HD AV Cable
  • VGA HD AV cable
  • S-video AV cable
  • Advanced SCART AV cable
  • Japanese HDAV D-connector AV cable
Additional info:
http://www.dummies.com/how-to/content/hooking-up-xbox-360-sound.html
Sep 28, 2009 | Audio Players & Recorders
The two rear speaker on 5.1 surround sound are working but produce no sound when played through only through the test. could u advise me on how to change the levels so that sound can be heard from all 5...
If you have diffrent mode's on your system like---
3ch,pro logic, and or live,hall pavilion,try setting them@pro logic first.then if you have DSP mode that increases the rear effect the higher the number the stronger the effect.
Dec 20, 2008 | Audio Players & Recorders
Can't get Surround Sound with Movie
hiya
do you get full 5.1 when watching a movie from the dvd player...........??
as when u watch tv the reciever must be set to pro logic to enable 5.1 upmix as its only a stereo feed....
Dec 15, 2008 | Technics SA-DX1050 Receiver
Nakamichi AV-7 (issue with surround mode - prologic)
Nice Receiver!
>In your surround sound settings make sure the levels are set correctly and the distance from your listing point to the furtherest
speakers are set to accommodate the levels etc.
>How many speakers 5.1, 6.1, or 7.1 (1meaning subwoofer)
>Pro-Logic supports 5.1 but not sure about 6 or 7
>Pro-Logic II does support all
>Make sure you are hear the sound from all sometimes the sound is really faint if you are in surround mode
Thank You and good luck
Aug 28, 2008 | Nakamichi AV-7 Receiver
Kenwood KRF-V5060D Receiver Logo
245 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
