Question about IBM 06P4069 Mouse
Its taking an extra effort to click the mouse and get it to action.
My car has extra oil then the level.
There is DEFINITELY harm in having too much engine oil. The most common problem is -- believe it or not -- lack of lubrication caused by low oil pressure. What happens is the crankshaft "whips" the oil in the oil pan into a foam. The foamed oil is then pushed through the lubrication system. The air bubbles causes a drop in oil pressure and less oil is delivered to moving parts. This results in increased wear, lower fuel economy, higher temperatures and generally just a Whole Lot Of Bad Things.
The action of the crankshaft whipping up the oil also robs the engine of some power; it takes effort to push the crankshaft through all that extra oil.
Drain the oil to the proper level
hope this helps have a great day
Aug 21, 2011 | 2002 Nissan Altima
Curser turns to circle with black line through it
Hello, Try changing the cursor's color with these detailed instructions:
No. Mouse actions Keyboard actions 1 To open the Ease of Access Center, select:
  • Start.
  • Control Panel.
  • Ease of Access.
  • Ease of Access Center.
To open the Ease of Access Center, press:
  • Windows logo key winkey.gif+U.
2 Under Explore all settings, select:
  • Make the mouse easier to use.
  • Make the mouse easier to use by pressing TAB, then ENTER.
3 Under Mouse pointers:
  • Select a cursor and pointer combination.
  • Select Save.
Under Mouse pointers, select a cursor/pointer combination by pressing:
  • ALT+R for Regular White
  • ALT+U for Regular Black
  • ALT+G for Regular Inverting
  • ALT+L for Large White
  • ALT+B for Large Black
  • ALT+I for Large Inverting
  • ALT+X for Extra Large White
  • ALT+K for Extra Large Black
  • ALT+N for Extra Large Inverting
  • Select Save by pressing ALT+S.
May 06, 2011 | Compaq Computers & Internet
The left click doesn't work every time I push it down.
Sounds like the left switch has already gone bad. If it isn't a year old, it should be under warranty. Take it back (along with the receipt) to where you purchased it and ask for a replacement.
Sep 14, 2017 | HP Wireless Optical Mouse
The left click is not consistently working
you should change your mouse cuz only left mouse have this physicall problem due to extra pressure or hard clicks on it.mouse is sensitive device so repair is not better option.just change it.
Dec 06, 2009 | Razer RP01050101R1M1 Pro Click Mobile...
Everytime i click on something my computer opens up a menu how do i get it to stop?
It's possible that your mouse has been configured so that the LEFT mouse button is performing the action that the RIGHT mouse button does on most computers, namely to open the "context-menu".
Access "Control Panel", and then "Mouse", and check the actions that are associated with each click.
Nov 27, 2009 | Compaq Audio Players & Recorders
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
Left button recently requires "extra" effort to make it work...any explanation?
Have you spilled liquid such as coffee or soda into the mouse? If not, the micro switch is starting to fail under the button.
Jul 18, 2009 | Microsoft Wireless IntelliMouse Explorer
HELP IN CHANGING COLOR FOR MAPS
you're going to need some 'if then statements' linked to the color of the city. and some global procs for them so that they can tell the program what state they are in.
on mouse down-action x-
action x
if city.rgb=(rrr,ggg,bbb)
then city.rgb = (rrr2,ggg2,bbb2)
end
Nov 15, 2008 | Computers & Internet
Left click button not working correctly
Afraid it sounds like the mouse is the problem you can go into control panel, mouse, and change it round so u press the right mouse button to do the same thing. Sorry cant help anymore.. John
Sep 12, 2006 | Targus Kaleidoscope AMU0301 (AMU0301US)...
IBM 06P4069 Mouse Logo
35 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
