Question about Cfm Klimaire KSWG009H113 Split System Air Conditioner
We have 10 hp Motor with centrifugal fan fitted with 5 TR Cooling compressor? We want to know the cfm of air?.
  • power_enterp May 11, 2010
    You need to either get specifications from fan designers, or take a reading with a manometer or flow hood
  • 34 Answers
You need to either get the specifications from the fan manufacturer, or take air readings with a manometer or flow hood
Posted on Apr 27, 2010
I need a 4 piston A/C compressor or a 4 piston hydraulic pump for a project. do you know which models have this
http://www.boge.com/in/artikel/download/Brochure304_EN_Piston.pdf
Devair/DeVilbiss Piston Air Compressors
www.centrair.ca/piston_compressors.html 5hp piston air compressor, 7.5hp piston air compressor, 10hp piston air compressor, 15hp piston air compressor, 25hp ... PUMP: 2 x 447 (2 stage 4 cylinder)
10HP 4 Cylinder 2 Stage Air Compressor Pump
https://www.eatoncompressor.com/10hp-4-cylinder-2-stage-air-compress... Solid cast iron 2-stage V-4 piston series pump, oil lubricated design to extend pump ... This is our 10 HP, 4 Cylinder, 2-Stage, air compressor pump with 43 CFM ... Compressor Stages‎: ‎Two Stage CFM @ 100 PSI‎: ‎43 CFM Compressor Type‎: ‎Bare Piston Pump Horse Power‎: ‎43 CFM
Petstar 4 - Ingersoll Rand
www.ingersollrandproducts.com > ... > PET Compressed Air Solutions Ingersoll Rand PETStar® 4 reciprocating air compressors offer durability and ... pistons with heavy-duty Class 40 cast iron cylinder construction; Piston rings and ...
Jan 31, 2016 | Air Tools & Compressors
Why use 1/4" coupler/fitting with 3/8" ID hose.
Hi Jason! Something to remember. When you refer to a 1/4" fitting, they have 1/4" NPTF (pipe thread) connections which isnt 1/4" in diameter. It is actually .540 diameter and your 3/8 hose is actually .375. On most air hoses you find, 1/4" fittings with 3/8" hose is REALLY common and considered the standard for most common air tools.
One thing that I have always taught people when it comes to pneumatics is to know the air requirements of your tools. If an impact you have has a 1/4" inlet, well the manufacturer calculates that size fitting allows a sufficient amount of air to operate it at the best performance. So, your 1/4" fitting with 3/8 hose should be fine for equipment with 1/4 connections. If you have a tool that has a larger 1/2" or 3/4" inlet, well you need to step up you hose to at least 1/2 fittings and 1/2" hose.
All pneumatic devices have a certain amount of air that they will need to run correctly. This is the CFM (cubic feet per minute). The compressor can only put out so much. Most of your smaller compressors dont put out alot of air (cfm). A good rule of thumb is on electric compressors, 4 cfm per horsepower of the motor (2 cfm per hp on gas operated). So, if you have a 5 hp compressor, figure you will only have a maximum of 20 cfm available. Check your tools, see what their consumption will be. You may find that you may not have enough compressor so putting on larger fittings and a larger hose because your tools demand more air may not be the fix if your compressor cant create enough air. Hope this helps! rex
May 01, 2014 | Washing Machines
VP10 Pump,air Compressor,single Stage,3 Hp 5FTU5
3 inch pulley with a 3600 rpm motor. 6 inch pulley with 1800 rpm motor.
Nov 04, 2013 | Champion VP10 Pump,air Compressor,single...
I have an ingersoll-rand upright compressor model 2545k10-p, 10 hp, 120 gal, 175psi compressor, and the electric motor will run for about 15-20 seconds and then automatically shut off, and be really hot....
Does the motor rotate the compressor or just set there and hum? How old is this unit? Overload heaters may be to small or unit may be single phaseing. Is there air pressure in the tank when this happens.
Oct 15, 2010 | Ingersoll Rand Stationary Air Cooled...
I have an Ingersoll Rand Type 30 air compressor. Model #234. I was given this unit because the motor had gone bad. I would like to replace the motor and use it but I was not given the bad motor with the...
One dealer for your model compressor is Northern. They are very good at replacement parts. If you do not have 3 phase power, you could shop around for 5 to 7 hp 220 v motor making sure that the motor mount will align with your plate. Pully size depends on dia. of pulley on the pump. Most pumps turn between 550 min to 1100 rpm depending on the power available and cfm requirements. Most motors turn at 1725 rpm so for example if your compressor has a 14 in. pulley then you motor will need a 5 in. pulley to turn it about 620 rpm. The larger the pulley at the motor the higher cfm produced but more amps used. Motor speed x pulley dia. divided by compressor pulley dia. To obtain more efficiency and highest cfm you will need 3 phase. Good place to see motors and two piece pulley combnations is www.grainger.com. Good luck
Sep 25, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
I have a craftman air compressor,5.5 hp.30 gal.tank,7 or 8 years old not used much,but always worked good until yesterday now motor makes 4 or 5 revolutions and kicks out breakers cooling fan and motor...
new at this..yet here goes..the cooling fan and motor turn freely..ok..does that include the piston assembly being connected,at the same time that the'cooling fan/motor turn freely' while in connection to the piston assembly? 'cause my 1st thought would be a gummy piston ect. (assembly) "not used much" i've used some tranny fluid in the past too 'un gum' a sticky piston..just my 1st thought ..based on info given..
Jun 28, 2010 | Craftsman Air Tools & Compressors
What horse power is required for producing 16.9 CFM at 100 psi or what horsepower is required to produce 16 CFM at 175 psi We have an air dual stage air compressor and need to find a motor to fit that will...
You are looking for about 5 H.P. to do that, but what is more important is the r.p.m. of the motor, the size of the pulley,,, and the size of the compressor pulley! most manufactures will spec the pump for certain horse power,,, they go hand in hand,,, for example you cannot take a pump designed for 5 H.P. and hook a 10 H.P. motor and a bigger pulley on it and spin the pump faster to make more air,,, it wont take that high of speed,,, I hope this helps.
Feb 25, 2010 | Campbell Hausfeld Air Tools & Compressors
How to confirm the cfm of screw conveyor that
start with empty tank and stopwatch. start compressor and stopwatch. stop at certain value f.e. 5 bar the machine have pumpt 5 times tank in much seconds calculate time and liters.
Aug 27, 2009 | Ingersoll Rand Stationary Air Cooled...
Compressor Support
Home Use: Compressed-air power tools can dramatically decrease the amount of time spent on a project. Many homeowners will use smaller, portable units (either hand-carried or wheeled) that move easily from the garage to the house, yard or roof. Common air toolsAir Tools such as brad nailersAir Nailers, reversible drillsAir Drills, and impact wrenchesAir Impact Wrenches require about 0–5 CFM (Cubic feet per minute — units in which air flow is measured). It's important to know if the compressor you purchase will drive the air tool you'll need for your project. For example, smaller air nailersAir Nailers run on 2 to 5 CFM at 70 to 90 PSI, while larger shearsShears, sandersSanders and polishersPolishers require up to 10 or more CFM and 100 to 120 PSI. Business Use: Air compressors used for business/professional applications are often classified “industrial grade.” They're packed with features that let you take on more demanding jobs with more horsepower, more CFM, more PSI and more (longer) run times. Though some industrial-grade compressors are portable, many are stationary units with large-capacity, ASME certified air tanks (up to 120 gallons), greater HP, more CFM air volume and faster recovery time to run a wide variety of air tools for as long as you need them to do the job.
Aug 27, 2008 | Jenny Products Inc AM780-HC4H 4 Gallon...
Cfm Klimaire KSWG009H113 Split System Air Conditioner Logo
323 people viewed this question
Top Cfm Heating & Cooling Experts
Dan Webster
Dan Webster
David Payne
David Payne
Donni Steen
Are you a Cfm Heating and Cooling Expert? Answer questions, earn points and help others
