How do I check a motherboard by myself to see if I am buying a good used one, I do have a 6 digit tester??? I am a single father with 4 kids and can't afford to pay to have tested, what do you recommend? I know medium on electronics so I am capable If I have the right tools. thank you martin
  • 12,061 Answers
Ok, there is no real method of ensuring you are going to get a "Good" MB. What you need to do, is simply obtain a MB, with a warranty, I personally do not think, that there are much difference between a good 2nd hand one, and a New one. You would be better off purchasing a NEW lower end MB, from a local supplier, with a warranty, than a 2nd hand one without. Usually though, as long as you buy from a reputable seller, always check them out. Most MB, as long as they are still in the "Box" and as long as they have NOT been used, DO NOT buy a pre-used one ever! Also, often these days you can buy an entire PC, for the cost of a MB. so ensure you check, check, and check again. Also make sure you get a return warranty, if you purchase. As related buy from a well recognized place and you will have NO problems at all.
Posted on Apr 27, 2010
Is there such a thing as metal detectors for kids?
Yes, you can get special metal detectors that are suitable for kids. They are smaller in size, lighter and easier to use than some of the more complicated metal detectors.
Check out this link where the metal detectors are characterize by age;
http://www.metaldetector.com/learn/buying-guide-articles/kids/best-kids-metal-detectors
Feb 21, 2013 | Retail Supplies
29 onida oxigen h out complant
you mean a horizontal output transistor problem with your tv unit?. there are possible cause why a horizontal transistor get bad. it depends to what kind of trouble does the tv unit have. here are some of trouble that i encountered of H-out problem and how i fix it
  • leak regulator transistor, the problem of the tv unit when you turn on it works but suddenly shut down then the horizontal output get bad. now how are you going to know if the transistor is leak and shorted. by means of a digital multi tester or an analog tester. a good transistor must have a reading of .4 to .9 in a digital tester below or above to the range is said to be leak transistor. a regulator transistor is usually found at power supply section. how to test a transistor using the digital tester. get the tester and then pull out the transistor to chassis board. vinceisaac_24.jpg as you can see in the image above is a digital tester some other brands may vary in ranges but all the function are the same. now set the pointer to the resistance checking select to the range with diode sign. a transistor have 3 pins for base, emitter and collector (component term ) with the use of test probe now touch one end of probe either of the 3 pins and other probe to the other pin.check the reading to the display of tester if no reaction reverse the polarity until you find the correct reading as what i said a good transistor is about .4 to.9 and then try this process to the other pin of transistor to check if all the junction are good.
  • defective deflection yoke, the problem with the tv every time you turn on unit the horizontal output get damaged. a deflection yoke composed of two windings for vertical and horizontal coil ( technical term ). now how will you know if the coil has problem. a yoke has 4 wires, 2 wires for vertical and the other 2 wires for horizontal now with the use of digital tester set the pointer to the resistance checking either in a lower range. touch with the test probe either of the 2 wires check the reading if 0000 that means shorted sometimes cause by an over heat the insulation get damaged. repeat the process to the other 2 wires, a good coil at least has a reading about .5 to 1 ohm for horizontal and for vertical around 1.6 to 6 ohms it may vary depending to the yoke needed by the tv unit. vinceisaac_25.jpg the image above is sample of deflection yoke it was located and installed at the neck of ( crt )picture tube. if one of the coil winding has problem it always damaged horizontal output transistor and other part . i hope this trouble that i encountered will help you too to fix your problem good luck.
Jun 03, 2011 | Televison & Video
Loud noise during spin cycle. Bid from Sears was over $900.
buy a new machine,the spider gear is gone and the part is like 500 bucks,you used to much detergent and it eats the metal on the gear
Oct 16, 2010 | Kenmore HE2 Plus Front Load Washer
I have intel board DG41RQ -E5400 ,2.7 dual core procesor with 1gb ram ddr2,400w power supply,500gb sata hard drives. i recently bought this system but my 5 hard disk are damaged.please tell me is this a...
In my opinion Motherboard issue, but I can't assure, it could also be the Power supply, as bad power supply could cause the motherboard mal-function and is causing the hard drive failure. If the motherboard is under warranty, you better get a replacement than wasting another Hard drive, and I hope it's better for you to replace the power supply as well, you'll spend less buying a 450watt power supply than buying a new 500gb hard disk.
Also make sure the cabinet is properly fitted and the ground is working without any problem, you can check this by using a tester (screw driver tester) after it's connected to the mains, or you can try with your hand (it'll not kill you :-], but I don't recommend if you have a screwdriver with tester).
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Oct 10, 2010 | Intel DG41RQ Motherboard w Pentium Dual...
RPM Tester: Hello! I am looking for a tester of engine RPM.
Led are easy to read,but is it worth the money? Once you use it you just put it away for how long? Turn on the car, A.C. and tune the rpms to the lowest point of idling without killing the fuel-to-air mixture and where the idles soften any vibrations.
Nov 20, 2009 | 1987 Toyota Corolla 2 Door
95 jeep grand charokee laredo hard to start,
Check your spark plug, wires, distributor cap and finger. If you spark plugs older than 15000ml, replace them. To check your spark plug wires, use a tester (U can buy at any auto store) you hold direct on the wire and a small sparkling will show you if the wire works or not. You can check the wires also with this: use a single spark plug (don't remove one out your engine!), remove the wire from first SP, connect it with the single SP, hold it to ground, let someone start your engine...you need to see regular sparks.. do this step by step with all 6 wires. If all wires are fine, check the SP's, If you miss on one wire, replace the wire, if you miss on more than one, chekc the distributor cap and finger. If this items are older than 20000ml or 5 years, replace them.
Oct 27, 2009 | 1995 Jeep Grand Cherokee
Laptop wont recognize 4 gb sd card
We have 3 of the original 512Mb Disney MixMax players for the kids and, according to the specifications printed on the box, the largest memory card you can use is a 2Gb card, you cannot use a 4Gb memory card with a Mix Max. I have further tested this fact by trying to use a 4Gb card myself and it will not work no matter how I try to format it or anything else. I decided to be smart: read the information they give you with the product and don't try to add a memory card that's too big for the item's capabilities. You have no choice but to buy several 2Gb cards like we did and put them in a carrying case so the kids hopefully won't lose them.
Nov 08, 2008 | Disney Mix Max Digital Media Player
Maytag Neptune Front Load Dryer - No Heat (MDE5500AYW)
hi carolyn,
if you can use a multi meter, then i can guide you which part to order. if you would have the wiring diagram of your unit then it is much better. plus basic tools to open your dryer. phillips screwdriver, 1/4 hexnut driver, and a multi-tester to test continuity.
90 percent of dryer not heating is the thermal cutoff switch. if you can test yours, then that would help you and save you a lot of $$$.
tnx 4 using fixya,
drcool
Sep 29, 2008 | Dryers
Overload led on 2 channels
Hi Oranzky,
Will the overload LED's light up with the Speakers disconnected?
Nov 11, 2007 | Audio Players & Recorders
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
