External Hard Drives
What is the best 250GB External Hard Drives which powers from the usb port?
  • Anonymous May 11, 2010
    I can tell you what I do not recommend... any Seagate external drives. They have an over heating issue.
    Geno
Iomega hard drives!
Posted on Mar 24, 2008
SOURCE:
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
My computer does not recognise simpletech 250GB HDD drive when connected. The lights glow only. Earlier I had used this on my TV. Could it be that the system got corrupted
Buy an external USB hub that has an AC power adapter.
Your computer is not providing enough power to spin up the drive.
A self powered hub will provide the necessary power. 7 Port USB 2 0 HUB AC Adapter Monoprice com
Mar 10, 2015 | SimpleTech SimpleDrive 250GB 3.5" USB 2.0...
I am trying to do a back-up from my computer but the external hard drive does not appear on "my computer". when the external drive is connected to the external usb drives it makes a noise.
The cable coming off the hard drive should have two usb plugs. Make sure both are plugged into the computer so that the drive is getting enough power. If it's a laptop you are plugged into the same thing applies but also make sure that the AC Adapter is plugged into the laptop when you plug the external drive into the USB ports. Sometimes it won't power the drive if it's running off battery power.
Of course it could be a problem with the Hard Drive within the enclosure if it is a constant clicking. But it sounds like it could just be the USB port not powering the drive up.
You could try on another pc as well.
Jan 21, 2011 | Hitachi SimpleDrive Mini 250GB USB 20...
Western Digital external USB 2.0 Problem
Buy an External USB 2.0 Hub with the 5.0V power supply. I have a TARGUS 4 Port Hub. MY WD2500XMSB works fine thru the HUB, but will not work using any cable (even the one that came with it) when directly connected to the USB port on my computer. The power consumption of passports sometimes exceeds the .5 milliwat rating for the ports and ccause the port power to interrupt (see USB 2.0 specifications). The external hubs with external power have a higher power output usually an can power the passport drives. CW Rumsey
Oct 07, 2009 | Western Digital 250GB MyBook External USB...
Simpletech external harddrive, blue flashing light with a constant beeping
Your drive is not getting enough power. try a different usb cable and a different usb port on the computer
Sep 26, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Xp computer wont recognise new 250gb elements ext hard drive
use it on a differnet usb port
these portable hard drives have some issues with 1.1 usb ports
Jul 12, 2009 | Computers & Internet
Where can I find a Mac driver from a Simpletech 250gb Marshmallow It has been formatted on a PC. I now want to reformat it and use it on my Powerbook G4 OS 10.4.7
You shouldn't need a special driver, but you do need to plug in the usb y cable to 2 usb ports. Normally 1 usb port doesn't supply enough power to make external USB drives go. That is why I prefer firewire, it supplies much more power at higher sustained rates. Once the drive is going just open the Disk Utility and format for your needs. If you need to share files with a PC, partition as MS-DOS (FAT). If you are sharing with a mac or not using the drive on other computers, format as extended with journaling.
Jun 20, 2009 | SimpleTech Signature Mini 250GB External...
I require a driver for our Beyond micro external hard drive.
It looks as though there is no driver support for beyond micro although the specs state that the drive is plug and play. which means you just plug it in and windows sets it up. other than that there are no software or drivers for it.
best of luck.
hope this helped.
please remember to rate me.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Mar 02, 2009 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Windows XP will not recognize my WD 250GB Harddrive
Just plug your USB HDD directly into your MBoard's USB port...
Feb 09, 2009 | Western Digital 250GB MyBook External USB...
Open Questions:
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
Ekse
