Question about Fuji FinePix M603 Digital Camera
FLASH ON FUJI M 603
Have lost the instructions to the above, could you please tell me how to turn off the flash. Thank you. Barbara
On the right side of the camera there is a button with a flash symbol next to it. Push this and watch on the screen what icon you have. Push enough times to make the "crossed flash" icon appear.
Posted on Oct 19, 2008
How can i use the internet to format my Sony Ericsson W580I PHONE
Hello and Welcome to FixYa!
Its simple to format / flash / reprogram your phone you need to follow the instructions;
  • You need 2 things; Your Phone's USB data cable and internet connection.
  • If you have the above tools, kindly download this application.
  • Install and run the update utility i.e; the downloaded application.
  • Follow the on screen instructions, choose your Phone and region and proceed with the update.
  • NOTE: All the Data will be lost Copy them to your memory card and then remove it before flashing.
It was very simple, even though if you are having issues do tell me.
If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
Mar 20, 2011 | Sony Ericsson w580i Cellular Phone
Fuji s7000
Thanx to forum input I found a Quantaray qb-350a flash with a single contact on the hotshoe. By turning on "external flash" in the Fuji s7000 allows the Q350 to work beautifully and for about $40 bucks. It also works on earlier Fuji's like the 6200.
Thanx
Frank
Mar 20, 2009 | Quantaray QTB-9500A TTL Flash
The flash on my Fujifilm s3000 quit working.
Hi,I know some of the common things for the digital camera. I want you to try these.
-------->If the built-in flash does not function, then the camera may be set to Auto and will only flash when taking pictures in poorly illuminated environments.
-------->Set the camera to the Forced flash setting so it will flash regardless of the surrounding brightness.
IMPORTANT: If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
* When shooting MPEG movies
* When set to the Twilight mode
* If an external flash is connected
The information above should resolve your issue. However, if the issue still persists, you can try resetting the camera to factory specifications.
Some cameras have a RESET button built into them or a menu option to reset the camera to the default settings.
Refer to the instruction manual supplied with your camera for specific information regarding the availability of a RESET button or menu option to reset the default settings. Otherwise, continue with the manual reset procedure below.
1. Turn off the camera.
2. Ensure the camera is not connected to an AC power adapter.
3. Remove the battery from the camera for 15 seconds.
4. Reinsert the battery.
5. Turn on the camera.
If all the above fails you, then i doubt that Impact damage would have caused the flash not to work.
But i know you are not going to like this solution. No other way , you have to contact Nikon service centre for repair.
i hope this helps to fix your problem.
Thanx for using fixya.
Jan 03, 2009 | Fuji FinePix S3000 Digital Camera
Camera and flash gun trigger voltage
Hi Syd,
Vivitar 2800 and 2800D are two different flashes. The first is an old flash, having high trigger voltage, which, as you will see, still can be used with your Fuji. The second is a member of modern flashes, having a low-voltage release. Manufacturers specify the highest applicable voltage at the trigger (hotshoe or PC) terminal; at most digital cameras it reaches several hundred volts.I believe, this is, what your seller was asking. As far as I know, Fuji doesn't mention this value in the user manual of the Finepix 9500, but I met reports of people, who called Fuji and asked that and the answer was 400 volts!
So the short answer is: buy any wireless trigger if you have the 2800D, and tell the seller the flash has about 200 volts if your flash is an older 2800.
I wonder if you did already use your flash with your Fuji?
Laszlo
Nov 27, 2008 | Cameras
Flash won't work
good day,
have you tried setting the camera on "flash mode"? usually it has a lightning symbol that specifies that you are in flash mode. you can also set it on auto-flash where it automatically detects the level of light and uses flash when necessary.
however, if you have already tried the suggestions above, you may have a busted flash. in this case, you can approach your seller or the nearest service center of fuji.
i hope this will help
Oct 12, 2008 | Cameras
FORCED FLASH NOT WORKING
Aug 14, 2008 | Fuji FinePix Z1 Digital Camera
Flash
Here is the manual for the DSC-W35. http://www.sony.jp/products/di-world/cyber-shot/manual_english/W35_handbook.pdf
Please look on page 21 where it tells you to press the UP ARROW on the control button repeatedly until you get the flash mode you want.
Apr 28, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
Flash - how do you get it?
The button to 'pop up' the flash is located just above the LCD display
Feb 06, 2008 | Fuji FinePix E510 Digital Camera
Fugifilm E510 Digital Camera
I have a FinePixA330. I dropped it acidentaly on my carpeted floor but now it will not flash or even take a picture. Is therre any hope for it?
Oct 18, 2007 | Fuji FinePix A350 Digital Camera
Fuji FinePix M603 Digital Camera Logo
73 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
