Question about Microsoft Windows XP Professional SP2
My computer turn on color quality in 4 bit no choices
    President:
  • 1,768 Answers
1. Identify the type of computer and contact the manufacturer and download the correct driver for your PC.
Posted on Apr 27, 2010
  • 1,606 Answers
If I understand your description the video display setting is only allowing 256 colors. Basically this means the video driver being used is a generic display driver not the actual one you need to run. You need to find out what video card you have and download and then install the drivers. After that you will then be able to select the higher resolutions and color settings.
Black ink seems to be clogged even after putting in a new cartridge.
Try thi:
Cleaning the Print Head
  1. Press the Ink, Ink/Reports, Ink Management/Reports or Ink Management key.
  2. Use the up or down navigation key to select CLEANING.
  3. Press Menu/Set to confirm your choice.
  4. Use the up or down navigation key to select the color that is not printing
    -OR-
    Select ALL if more than one color is not printing.
  5. Press Menu/Set to confirm you choice.
  6. The machine should begin cleaning automatically, and the LCD will alternately show "CLEANING" and "PLEASE WAIT". When the machine completes its cleaning cycle, the LCD will display the date and time.
  7. Test by printing the "Print Quality Check Sheet":
    2. Use the up or down navigation key to select TEST PRINT.
    4. Use the up or down navigation key to select PRINT QUALITY.
    5. Press Menu/Set to confirm your choice. Press the Color(Colour) Start key to print the Test Sheet.
If one or more of the ink colors is still missing from the printed page, repeat the print head cleaning steps listed above up to 4 more times. After each cleaning, print the Print Quality Check Sheet to see if there is any improvement.
Jan 17, 2011 | Brother MFC-5840CN All-In-One InkJet...
Color quality is lowest (4 bit), cannot change also font is very large and I also cannot change.
The video driver is missing or corrupted. Go into Device Manager - Display Adapters - your video card and right click on it and uninstall the driver from there. Reboot , go to the manufacturer of the video chip and download and install a new one.
Jul 05, 2010 | Gateway FPD 1730 17" Flat Panel LCD...
My PC's color quality shows only lowest 4 bit
Sounds like you need to install a video driver. If you have a video card separate from the mother board, look up the card and download drivers for it. Alternatively, you may be able to use the Windows Update tool to autodetect the driver.
If the video card is on the motherboard, look up the motherboard's model number on the manufacturer's website as they should have drivers there.
Finally, look back at the disks you got with your computer, often there is a "drivers disk" which you can reload the driver with.
Jun 23, 2010 | Intel Celeron M 420 1.6GHz 533MHz 1MB...
Change 64 bit back to 32 bit
hello there:
you will need to go to the start menu click on it and then click on my computer then click on control panel then look for appearance and themes the you should see a box that says change screen resolution click on it you will see a drop down box with a rainbow of colors and you should have a choice of picture quality you should have the 32bit option hope this helps you out.. thank you
May 29, 2010 | HP Pavilion dv6000z Notebook
Animated resolution and 4 bit color quality
go to the support site for your computer and download the graphics drivers from there then you can switch it
May 27, 2009 | Compaq Evo D300s (269124-051) PC Desktop
Colors in PAINT are limited
assuming you are using XP-
1. right click on your desktop and select "Properties"
2. click on the "Setting" tab
3. make sure that the color Quality is set to "Highest 32 bit"
4. you can also:
  • click on "Advance"
  • find the tab of your graphic card
  • make sure it is on settings that allow high quality of colors
Apr 26, 2009 | Computers & Internet
Unable to print BLACK
The machine should begin cleaning automatically, and the LCD will alternately show "CLEANING" and "PLEASE WAIT". When the machine completes its cleaning cycle, the LCD will display the date and time. Print the Print Quality Check Sheet and see if all colors are present:
    1. Press the Ink Management key.
    3. Press Set to confirm your choice.
    5. Press Set to confirm your choice. Press the Color(Colour) Start key to print the Test Sheet.
If one or more of the colors is still missing from the printed page, cleaning the print head may resolve this problem. When cleaning the print head, you are given the option to clean BLACK ONLY, three colors at a time (CYAN, YELLOW, and MAGENTA), or all four colors at once. For this issue we recommend cleaning only the affected color. If more than one color is missing then select ALL. Follow the steps listed below to clean the print head:
    -OR-
  5. Press Set to confirm you choice.
I hope it helps!!!
Dec 09, 2008 | Brother DCP 115C All-In-One InkJet Printer
Color quality
this is normal function of the programs some programs do not reset your resolution so you may have to do it manually. candy land did this repeatedly in my daughters computer.
Feb 13, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Microsoft Windows XP Professional SP2 Logo
69 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
