Question about D-Link DI 514 Wireless Router (DI-514)
When i use my D-Link router, I have a problem. I
When i use my D-Link router, I have a problem. I go online and the router has the blinking green lights. One day, my internet connection was cut. The router lights were stationary. I had to reboot the router by shutting it off and then 5 minutes later turn it back on. What is going on here? Problem is the router? It been happening every hour.
    Problem Solver:
  • 15 Answers
I would say if you didnt make any changers to the router and it was going ok before, I will try ringing your ISP ( internet service ) and see if they are able to share any light on this matter, if not you might have to do a factory reset on the router. hope this helps.
Posted on Apr 27, 2010
Why is my net gear wn 802T modem blinks green
The cable modem is online and processing traffic
Jun 09, 2014 | Belkin (F5D7230-4) Router (587009)
Power Problem with 2Wire 2701HG-B
Sounds like a startup self test. All wireless devices go through a power on self test. Does it connect? You can connect to it and go online? I rarely turn mine off, only in a electrical storm.
Nov 22, 2012 | 2wire (2701HG-B) Wireless Router
Dlnik dir-615 all lights flash
If rebooting or a complete factory reset did not solve the issue, I believe your ROM or other electronics may be defective. I had a similar issue with a D-Link router several years ago, probably due to a power surge.
Aug 22, 2012 | D-Link DIR-625 (790069292637) Wireless...
Diagnostic light keeps blinking
Check the LED lights that are blinking on the front of the DSL modem. Check the "Internet/Online" LED and make sure it is blinking green or a solid green. If this LED is not blinking, then the modem is not getting a phone signal, or the service is out. Remove the line and check it to make sure that you're getting a signal.
Check to see if filters are connected to the phone lines that are all around the house. These filters separate the phone line from the DSL line so that the lines do not crosswire and disturb the Internet connection or the phone connection. The DSL is usually shipped with a couple of phone filters. These phone filters can be purchased at many electronics stores or provided free from your Internet Service Provider.Check to see if the modem is connected to a wireless router. If the modem is connected to the router, try disconnecting the router and connect the modem straight to a computer. If the modem is also a multi-port wireless router, then connect the computer to a different port on that same router.Reset the router if the previous steps do not resolve the problem. Follow the initial set up instructions given to you when you first installed the router. Perform any firmware updates that might be needed once online, and use the discs that came with the modem.
Feb 07, 2012 | Cisco RVL200 Router
There is an orange "i"
The orange "i" means that the Ethernet cable connection to the modem has been detected.
The light should be blinking green for Internet connectivity.
I advise you to reset the router:
To restore the factory default configuration settings:
1. Use a sharp object such as a pen or a paper clip to press and hold the restore factory settings button, located on the rear panel of the router, for about 5 seconds, until the Power light begins to blink .
2. Release the restore factory settings button, and wait for the router to restart, and for the Power light to stop blinking and become solid green.
The factory default settings will be restored so that you can access the router from your Web
browser using the factory defaults.
If resetting the router does not correct the issue, you should call your ISP (Internet Provider) and check if they are having a problem.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 23, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
Orange light on instead of green?
If this is on one of the local computer ports and it is blinking it is nothing to worry about according to the manual (http://cache-www.belkin.com/support/dl/p74559-b_f5d7230-4v7_man.pdf, page 11). It is just another normal status color like green but signifies a different network speed/duplex. If you are having issues with network connectivity, please reply with information such as:
1) Is the Modem light on and blinking? 2) are other machines using this router and able to get online? 3) did anything change to the computer plugged into the orange port such as windows updates or new hardware install?
Hope this helps some!
Mar 17, 2011 | Belkin (F5D7230-4) Router (587009)
Linksys has stopped working - no connectivity. I directly connected the modem to computer and it works fine. Power light on Linksys is green but is blinking and does not go to steady green.
You can try to follow the steps from this link to fix the blinking power light of your router, because a blinking power light is a sign of something is bad on the router. But if after doing the steps and still a blinking power the router is already bad and needs replacement.
http://www.fixya.com/support/r3801591-fix_blinking_power_light_linksys
May 06, 2010 | Linksys Wireless-N WRT150N Router
All the light are green
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Apr 20, 2010 | D-Link Computers & Internet
Router unavailable, error message. green light blinking on router link light.
That means the Internet link is not active, type 192.168.1.1 in the internet browser. if u get the configuration window that means the system is communicatiog to router..if not check the cables connected properly..
May 21, 2009 | Dell Dimension 2400 PC Desktop
My Belkin is blinking.
IT means that the router has gone defective.
May 20, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
D-Link DI 514 Wireless Router (DI-514) Logo
67 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
