Question about Microwave Ovens
Morning Peeps A hole has blown on the inside screen of the door can I replace the door or screen Thanks
    Habit-Forming:
  • 193 Answers
You can but use caution because if it is fitted wrong it can leak radio waves
Posted on Apr 27, 2010
My daughter's GE Model JVM2070SK02 failed to shut off this morning which ignited a muffin that was in the microwave. She stated that she had been having problems with it that that required unplugging the...
It sounds like a cook relay stuck closed and this is why it continued to cook. When the door was opened it should have blown the monitor fuse (which is how it is designed to for safety) so that it cannot cook when the door is open. Or, a cavity temp fuse was blown due to the fire inside. Also a safety feature.
Oct 08, 2013 | GE Profile Spacemaker Over-the-Range...
On the inside of the door of my microwave front window is an adhesive plastic covering that if you pull it off there is a black mesh screen exposed. is that clear sheet suppose to be removed.
The metal mesh is a filter screen to keep the microwaves in the oven while letting you see the food. The plastic sheet that's peeling off is meant to keep that screen clean. It's not supposed to be removed, since then food can get into the holes in the screen. A buildup of foods can lead to overheating and burn the paint and possibly damage the door. It should be replaced.
The part number is WB36X10068. A Google search turned up several sources. Here's one, but there are others. The new sheet has the adhesive applied, you just peel off the protective film and stick it in place. Clean the door inner surface first so the new sheet will stick firmly.
Good luck with the repair, and thanks for using Fixya!
Oct 17, 2010 | Hotpoint RVM1435 Microwave Oven
Power to back of oven going in and out of the oven but nothing happening not even the clock is coming on. please help.
Hi
Thanks for using FixYa. When microwave oven doesn't work at all, it means interior fuse inside the microwave has blown (usually a part inside the microwave makes this fuse blow). Sometimes a bad fuse holder inside the microwave cannot hold the fuse tight enough and the fuse will blow as well. If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work. It can also be due to a stuck or faulty door switch which might have blown the interior microwave fuse.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 13, 2010 | Belling Microwave Ovens
No power to microwave
Hi
When your microwave oven doesn't work at all, it means interior fuse inside the microwave has blown (usually a part inside the microwave makes this fuse blow). Sometimes a bad fuse holder inside the microwave cannot hold the fuse tight enough and the fuse will blow as well. If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work. It can also be due to a stuck or faulty door switch which might have blown the interior microwave fuse.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 14, 2009 | Microwave Ovens
Microwave was working fine but just stopped this morning. Is there a way that I can replace the high voltage fuse? Is it located in the panel inside the microwave?
You have not mentioned the make and model. Any way you can check the AC fuse on the power board inside the oven. If it is blown off you can replace it by a similar one, around 10amps fuse.
May 16, 2009 | GE Profile Spacemaker Over-the-Range...
Panasonic NNA554W blows 10a fuse when microwave comes on
Possibly the interlock monitor switch is bad or out of adjustment. This switch is designed to create a short circuit across the power line (and then blow the fuse) if you attempt to defeat the door interlock and operate the oven with the door open. A shorted capacitor or diode could also cause the fuse to blow. Because of lethal voltages inside and the possibility of microwave leakage if repairs aren't done correctly, you are best off leaving microwave service to professionals.
May 15, 2009 | Panasonic NN-SN657SMicrowave Oven
The mesh screen on the inside door has a hole in it..
would suggest replacing door for safety purposes only," it could be fine as far as resisting waves",but never sure for how long or if it realy is. An old saying makes sense," Better safe than sorry".
Apr 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Door latch and Screen
This is because of the broken latch. There are switches inside the oven that are operated by the door latches to make sure you're not trying to use the oven with the door open. With the new door, your oven should be back to normal.
Feb 06, 2009 | Whirlpool Microwave Ovens
No one at Delonghi will help, nor will Argos where product was bought. I just want to know if my microwave is safe (bought in May 2006) - the inside of the door (looks like a plastic covering) is bubbling...
There is a fine metal mesh / screen inside the door assembly.
If any of the holes in that screen are damaged or enlarged, then leakage is possible.
If the bubbling / deformity in the door keeps it from shutting fully and flatly, then leakage is possible.
If the bubbling / deformity in the door allows moisture to collect on or near the screen, it may lead to rust, which can damage the screen and lead to leakage.
Please feel free to contact me directly (especially if you include a few photos of the door) if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 21, 2008 | Microwave Ovens
Hole in plastic on inside of door
check the conductivity of the plastic with an ohmmeter by placing the probes an inch apart on the plastic surface. If the resistance is large or infinity, the plastic probably performs no role in stopping the microwave radiation. If so, any epoxy probably can be used to close the hole safely. Make sure you don't use too much and if possible place tape over the repair and orient the microwave so the epoxy presses against the tape while drying to prevent it from oozing into any door hinge/close mechanism. Otherwise, a piece of microwave door glass from a broken unit can ge glued over the hole and should stop the radiation. You can check for leakage with test units but be very carefuly anyway.
Nov 30, 2007 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
26 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
