Question about Gb Electrical Non Fusible A C Disconnect Switch
Fueltank warning light staying on on dash 80 series l/cruiser
  • 12,061 Answers
This is usually, a stuck, sensor, or a short circuit to earth in the wiring.
Posted on Apr 27, 2010
91 Land Cruiser, starts fine, however all dash warning lights stay on once motor is running, checked all oil, water levels etc, all fine, any ideas please.
I've had a similar issue. Turned out the Alternator was clogged with mud and wasn't charging anymore. Pulled it out and apart, cleaned it out and put it back and voila! Problem solved. Check the output of your Alternator, should be around 13.2-13.5V.
Oct 10, 2011 | 1991 Toyota Land Cruiser
The fuel tank warning light is illuminated on my 95mod 80 series
Just a thought.I don't think the tanks transfer fuel.They draw the fuel from one tank or the other.I may be wrong,but have a look.Hope this helps
Jan 10, 2010 | 1995 Toyota Land Cruiser
ALL warning lights on dash flash off and on - then go off for a few minutes then does it again. Car runs fine.
I have a 2008 pt cruiser sometimes the dashboard will flash off and and but not all the time
Oct 08, 2009 | 2003 Chrysler PT Cruiser
Toyota Land Cruiser fuel tank warning light on
Hi There. Have the exact same problem on my 95mod petrol with the sub fuel tank not emptying. think it may be the relay but cant find it. The earlier models have the relay in the rear wheel well, but ours are set up differently. had the whole car to pieces but still cant find it. Was wondering if you had any luck with yours and could enlighten me. Thanks kim_mck53@hotmail.com
May 11, 2009 | 1995 Toyota Land Cruiser
Dash warning lights
its telling you it has some thing wrong . get a code reader on asap.. just for peac of mind
Mar 31, 2009 | 1994 BMW 3 Series
Toyota Land Cruiser check timimg Belt
I am assuming that you have a series 80 diesel engine and that it has run for about 100,000 kms hence the warning light and the changing of the timing belt. Based on the instructions of its repair manual you need to "remove the grommet off from the speedometer and turn off the lamp by pushing the warning light reset switch, then replace the grommet." Alternately, you can try to reset the entire computer of the vehicle by removing the battery cables for a couple of minutes. Pls note that some car radios/head units would revert to security default (ask for a code) when power is completely removed.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 24, 2008 | 1997 Toyota Land Cruiser
Gb Electrical Non Fusible A C Disconnect Switch Logo
46 people viewed this question
Top Gb Electrical Electrical Supplies Experts
ken skalski
Are you a Gb Electrical Electrical Supply Expert? Answer questions, earn points and help others
