Question about Philips 26PF5320 26 in. LCD Television
I get sound but no picture if i switch off and on after about 15mins the picture comes on.
  • 21 Answers
Are you a technical person?if not,ignore my tips...
check the supply voltage From power supply section going to inverter board.
maybe a leak capacitor of the supply voltage of the inverter board...
hope it help you a lot.
Posted on Apr 27, 2010
No picture
Try unplugging for 15mins then hold power button if nothing then TV is probably pooped out if plasma screen then the backlight bulb probably blew out usually located in front left hand side behind panel in a plastic and metal cage you have to order these from the company
Feb 14, 2015 | Televison & Video
After turning the AC unit on roughly 10-15mins. outdoor unit turns off head unit still on
It sound like you have problem with compressor overheated. Make sure your is clean and correct amount of freon
Nov 06, 2013 | Fujitsu 18C1 Air Conditioner
Macerator works only for 5mins every 15mins. But won't work during the 15mins.
Well it is working in a stinky environment! Just think, without it you could be hand chopping all that "stuff" up!!!
http://www.ehow.com/info_12169188_saniflo-system-work.html
Sounds like you have a sticky switch inside the macerator.
http://www.saniflo.com/products/index/show-product/lang/en/type/part/id/54
As this is a messy piece of plumbing, I'm going to recommed that you take it out of the system and take it outside in the yard, away from the house and give it a good hosing out. It is possible that some gunk has clogged up the pressure chambers vents and this is causing the float or whatever mechanism in there to be stuck on. Flush it as much as possible before you disconnect it.
Sep 04, 2012 | Saniflo SANIPRO Macerating Pump
JVC Model# HD-56GC87 runs 15mins then shuts off why? picture is bright and clear, fans all working, lamp compartment door switch ok. no timers on. what could it be??
You may want to contact JVC as I seem to remember this model did have some upgrades that needed to be done with a computer hooked directly to it.
Apr 23, 2012 | Mitsubishi VS-45607 45" Rear Projection...
Tv makes a clinking sound when turned on. No picture and no sound
that clicking sound comes from the relay or the chip in power supply. You can carefully remove the back and change the power board. The tv has to be unplugged for at least 15mins before to do that. Do that at your own risk because some parts hold power even if unplugged
Mar 11, 2012 | Philips 42PFL5332D 42 in. LCD Television
Top up tv dtr box froze then staying on orange light, wont work
i had same problem today, it had locked up during deal/no deal
unplugged it three times nothing happened, wouldn't switch on
unplugged again left it for 5 minutes
then plugged in and left alone for 15mins plus
lights flasing then evetually green light went
all ok
May 03, 2009 | Televison & Video
My ps3 loads games,but after about 15mins crashes,why?
abey teri cd per scraches to bhai tu cd per deo spray kar le our use 5 minutes tak chor de or fir cd ko cloth se saaf kar de fir cd chal padegi
Feb 09, 2009 | Sony Playstation 3 (PS3) Console
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Philips 26PF5320 26 in. LCD Television Logo
155 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
