Question about Dell 1609WX Projector
Vertical stripes on screen
I have equally spaced dark vertical lines appearing on the screen if the projector is moved slightly - they then will not go away until the projector is turned off
SOURCE: Dell 2300 projects verticle stripes accross the projector screen.
this is due to improper power supply or a loose connection inside. the symptoms are of power supply unit inside projector. check out the current and amperes inside the projector on board. sometime the current stable but the ampears are down.also check the switching transistors & filters inside.......
Posted on Feb 12, 2008
  • 8 Answers
SOURCE: Vertical lines on projected image from a Dell Data Projector. White vertical lines are appearing at even spacing across the width of the image projected. At a loss to how to fix this. Any ideas as to
that is due to lcd filter units , try to align, precision work
Posted on May 25, 2009
projdoc
  • 2237 Answers
SOURCE: White Vertical Lines on screen from a JVC projector
bad pcb. get your money back.
Posted on Aug 07, 2009
projdoc
  • 2237 Answers
SOURCE: dell 5100mp dlp projector - white vertical lines evenly spaced
clock and phase are off. go into menu and reset the settings to factory default.
Posted on Sep 02, 2009
Ezrahite
  • 2632 Answers
SOURCE: Hi, I'm experiencing vertical lines
Welcome to Fixya. The problem that caused you to have a vertical line on the projector is the controller board (motherboard) of the projector. It is not the lamp because you should have receive an error on the light should be blinking if the issue is the lamp. You can get intouch with dell for repair. I also provided a manual so that you can check it.
Dell 2400MP Manual
Thanks
Posted on Aug 06, 2011
White vertical lines are appearing at even spacing across the width of the screen. Any idea how to fix ?
most of time this is happening due to the dmd connector & main board .some times dry solder occur .but you have to do carefully or by soldering expert
Mar 10, 2016 | NEC NP110 Projector
Image is bright but there is a slight issue - on the left hand side a purple line displays vertically. Anybody knows why is this fault appeared and how could it be solved.
There is three LCD in the projector red, green and blue. If green LCD make any fault mean line or dot or dots then screen show these line or dot in purple color:
If line is very straight and sharp edges then green LCD is faulty and need to be replaced.
If line is not straight and faded edges then some thing in LCD block so your projector need service
Feb 22, 2011 | Sony VPL PX40 Multimedia Projector
7 wide black vertical interference bars on all screens. Equally spaced with normal looking segments. Like the stripes on a flag. On both maintenance screens and program screens, too. The bars are "fizzzy"...
if these lines are pulsating, it sounds like the connection at back of the engine where it connects to the main board. you can try to reseat it and see if that fixes it. otherwise it could be one or the other. really hard to tell without a test fixture. if the bars are fuzzy like they look like they may be underwater then that would be a bad light tunnel.
May 11, 2010 | InFocus ScreenPlay 4805 Multimedia...
I have a viewsonic pj500 projector which has functioned perfectly for 5 years. Now the area around the image area either shows a dark blue with dark stripes and the image area has a yellow cast which seems...
LCD projector 101, your blue device is dying inside of projector. Consider purchasing a dlp based product, they do not suffer from color decay.
Really you are blessed , most lcds last about 3-4000 hours or 4 lamp changes. good luck
Apr 13, 2009 | ViewSonic PJ500 Multimedia Projector
Thin vertical line appears on projector
I have found that vertical lines that suddenly appear from projectors are due to poorly connected cables. Sut off your projector and wait for the fan to go off. Then unplug the connectors from the computer to the projector and secure them again, making sure to go all the way. Hope this helps.
Nov 25, 2008 | Office Equipment & Supplies
Vertical line
Hi Abouttime
This is unfortunately a sign of Mainbaord damage to any make of Projector.
But do give this a go , you've got nothing to lose.
Try using a different signal cable and then pressing Auto on either the remote of the Projector or the Projector it self once the line appears.
Thanks for using Fixya !
May 22, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Infocus 70+
We have had similar issue w/ multiple LP70+ projectors. The units get to be 1-2 years old and suddenly the right vertical edge of the display is distorted. There is usually a shadowed vertical bar that clouds about 3-5% of the horizontal space from the right edge.
What's the cause?
Nov 13, 2007 | InFocus LP70+ Multimedia Projector
Dell 1609WX Projector Logo
118 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
