Question about Intel Computers & Internet
Were do i hook up the power cord on the board at
  • 64 Answers
It should be a 4 box prong connector
Posted on Apr 27, 2010
Tip
GET YOUR BLOWN UP RADIO BACK ONLINE.
When you cant get your radio turned on. All it does is blow the fuse imeadiatlly hooking it to power. Most likely it is the (reverse polarity diode). The quick fix is to locate your diode? This diode usually is back behind a coil wound transformer on your board inside the radio and in the general area of where the possitive ans negative plug wires solder to the board! Usually it is black with a silver band around one end. If you clip it on one end or remove it this will restore your radios power. CAUTION:: When doing this ALWAYS use a dual fuse power cord . This will prevent this from happening again by blowing the fuse first. Doing this procedure will remove your thermal protection to the radio thus making it wide open to being fried for good if it ever gets hooked up backwards again. This is my reasoning for the dual fused power cord. Good luck!
on Mar 11, 2015 | Galaxy Radios Radio Communications
Where does the power cord hook up on the circuit board on my samsung hcn5527w?
The power cord normally goes through the Main switch and into the power supply section which is the SMPS. You will find the main fuse and the AC filters before it feeds to the rectifier section.
Feb 17, 2011 | Samsung HCN5527W 55" Rear Projection...
Tv turns off and dont want to turn on again
check outlet power by connect other device, check power cord if OK check then unplug tv and open the back cover and check power filter fuse power filter is the one that you hooked power cord if OK check power supply board fuses if OK check the power supply board for bad blown components .good luck
Apr 29, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Kenmore dryer 3prong cord installation diagram
if its a" flat cord" what-ever color jacketed 3 wire cord, the 2 outside wires are your 2 hot power wires they go to L1 and L2 on your dryer,the center is the N neutral wire and goes to the N terminal,usually the L1 and L2 are a gauge larger than the neutral: HINT: the center is normally neutral on both the cord and machines terminal board in the back of the dryer,there usually is a diagram on the dryer on how to install the input power at the place you hook up power
Feb 07, 2010 | Kenmore 62602 Electric Dryer
I have a 2 yr old dell inspiron 1525 any time i plug a working power cord in it turns the power off to the cord(green light goes off) i tried two different cords and both times they lost power as soon as i...
Unfortunately, it sounds like you have a bad motherboard... I've seen this one a few times. There's a very tiny chance the DC jack you're hooking it into is bad (this is soldered onto the board), but more than likely the board itself is bad. Because of how cheap laptops are nowadays, it may be just as cheap to buy a newer (and faster) one than to get a replacement board for that one, if you're out of warranty.
Nov 10, 2009 | Dell Inspiron 1525 Laptop Jet Black
My power cord was pulled out of my 52 inch rca projection tv. When I took off the back, I don't see where the cord was hooked up. Can you give me an idea of where to look?
It will be on small board infront of ssb board in chassis on right side you have 3 boards on bottom first board is power next to it is SSb and right behind that board is AC board that plugs in ac cord.
Dec 19, 2008 | Televison & Video
Maxtor 1tr wrong power cord was hooked up to it
If you plugged the wrong power cord into it, it could have damaged the power supply in the drive. You may have to get it repaired.
Jun 10, 2008 | Maxtor OneTouch III (T01G500) 500 GB...
New Power Cord Stopped Working
DO NOT use the HP power adapter that is 19V / 3.95A. That is too much power for the Scanjet, which is expecting 12V DC (and a much lower amperage). It's possible that hooking up this power adapter may further damage the electronics inside the scanner. If the second adapter has stopped working then it is possible that the internal circuit board has damage already and another adapter may not work. If you have access to a multimeter / voltmeter you could check for the 12V coming from the adapter. If you're getting the 12V, then the internal circuit board to the Scanjet is probably defective.
Nov 17, 2007 | HP Scanjet 4470c Flatbed Scanner
Computers & Internet Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
