Question about Sony Bravia KDL-46V4100 46 in. LCD HDTV
My Sony Bravia XBR 46 is making a clicking sound all the time, EVEN while turned off? It sounds like it is powering up or off, this happens all day and at night, kinda unnerving? Any thoughts are ideas? Thx
SOURCE: Verizon remote control code for Sony Bravia XBR
Got an older model sony xbr 36 tv. Wanna program it to work with mt time warner cable. How do i do it. Yhe TV is about 4 -5 yrears old.
Posted on Dec 27, 2007
rustym62
  • 201 Answers
SOURCE: standby light blinks 13 times
13 blinks is backlight error.. can be 1 of 2 things, 1st bad inverter board (on left side panel looking from back) it has several plug ins to the panel as it supplies voltage to the backlights.2nd could be panel itself as backlights are built into it they can't be replaced. Inverter is probably around $200 +labor, panel= buy new tv... they are outrageously expensive. Good luck!
Posted on Apr 29, 2009
  • 197 Answers
SOURCE: sony bravia 46 lcd The picture dims and
set has a light sensor. go in menu and turn light sensor off
Posted on Jul 02, 2009
circuitworld
  • 335 Answers
SOURCE: A fine green vertical line displayed on the Sony Bravia 46.
Thats a pixel data problem, there's no data being sent to that row of pixels so they don't change color. This is a pixel address registry (PAR) issue and the PAR circuits need to be serviced its usually due to open or shorted SMT components on the PAR circuits. PAR also sends data, voltage, and control to each pixel, the green line you see are pixels that have voltage but because there's no data sent too them their all green because there's no control. If the pixels have voltage but no data or control they show up as green red, blue, yellow, or whit line vertically down the LCD panel. The vertical-horizontal section of PAR are controlled by 16 to 32 bit micro-controllers which may need replacing. If its under warranty take it back if not have your local repair center fix the tv for you...
Posted on Nov 09, 2009
  • 8 Answers
SOURCE: how do I remove the stand of the Sony Bravia XBR
you have to lay the tv on it's front on something to protect it from being damaged.on the back you'll see where the base joins the bottom of the display, this needs to be unscrewed and a wall bracket screwed in instead.
Posted on Nov 26, 2009
Can you help diagnose a problem with my Sony LCD tv?
Is the screen cracked at all? This is mostly what causes this type problem. Unplug the television but not before doing a complete factory reset a total rester network everything if this don't help 1 of the displays is going out.
Mar 26, 2016 | Sony Bravia XBR-Series KDL-46XBR2 46-Inch...
Problem turning tv on.
The switch could be no good or, more likely, the power supply is failing
Jan 16, 2013 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Sony BRAVIA XBR KDL-46XBR4 HDTV LCD Television
you need to replace defective capacitors in the power supply of the tv
Jan 05, 2013 | Sony Bravia XBR-Series KDL-46XBR4 46-Inch...
No sound or picture
Visit the site named 'Electro-help' for more details. Click this link. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 975 posts to different brand TVs now.
Oct 11, 2012 | Sony Bravia XBR-Series KDL-46XBR2 46-Inch...
I have a 46 inch Sony Bravia 46 XBR4 set. The right side went out only colored lines appear. The rest of the screen is fine. email address GLCSS19@AOL.COM.
Sounds like the tcon (timing control) board. Sometimes unplugging the LVDS cables from the tcon, cleaning and reconnecting solves this. The catches on the LVDS cables are easily damaged and must be handled carefully.
Jan 20, 2011 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
With my Sony Bravia 46" xbr the screen keeps cutting out. I'm usig hdmi cables and can't find a reason why te tv keeps cutting out. The sound still remains but picture doesn't. Not even out technician can...
Usually this happens to my set when I am in HD cable channel mode after being on a non-digital ANALOG channel.
I basically reset the TV by changing to a DIGITAL cable channel -- stay on that channel for ten-twenty seconds -- then I switch back DIRECTLY to a HD channel (key in channel number directly on remote).
TV works fine -- seems to be a glitch when the TV changes modes from Analog to HD
Jun 29, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
My Sony Bravia 46' XBR46 LCD has horizontal lines that cause the picture to be blurry, why is this?
I hope this helps it seems Sony has extended warranty coverage for your TV for this issue.
http://esupport.sony.com/US/perl/news-item.pl?news_id=378&template_id=1
IF YOU FOUND MY SOLUTION HELPFUL PLEASE VOTE 4 THUMBS UP.
(any less hurts our averages)
Thank and Good Luck!
Jan 27, 2010 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Picture freezes on Sony Bravia 46 in
this can be a weak signal check the connections on cables. also in hot weather you can get a build up of static electricity and it will need to be discharged, turn off tv at mains and cross the connector and the cables if you have a buster or other box connected to them turn off and do the same to them. use something metal but make sure there is no power to them.
Jun 21, 2017 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Intermitent no sound on digital, KDL26S4000 sony bravia TV
Try going in the settings and turning off "Steady sound". Or turn the audio setting to stereo, disable surround sound.
Steady Sound
You don't have to listen to commercials at a higher volume than the normal programming. This TV has a volume equalization feature for both program and commercials to enhance your audio entertainment.
Selvol
Bravia XBR 42"
Nov 22, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia KDL-46V4100 46 in. LCD HDTV Logo
274 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
