How to troubleshoot speaker
The sound of my tv is garble not clear,,thanks
  • 75 Answers
Try to clean up the top side of the speaker ( it may be so many dust in it ). check the cable or change the speaker
Posted on Apr 27, 2010
  • 979 Answers
Hello sir, Hi!, the garble is caused by two things, 1. a bad speaker, 2. a bad power amplifier IC.
To test the Speaker,
Remove the speaker out from the TV, (this needs disassembly stuff) test it using any available portable amplifier. or radio, OR replace the speaker with the same size.
If this does not solve the garble sound, replace the power amp IC. (this really needs skills in electronics.) thats it.
Our 2 year old Sanyo 50 flat screen has a garbly, audio sound. Is there any way to fix this?
as sanyo is taken over by panasonic, warranty status is therefore unclear, in most countries it is 3 to 5 years warranty, do not meddle with it, check warranty status first here, choose your region:
http://panasonic.net/sanyo/
take serial number, part number and year of manufacture, fill form and you will have info if it is still under warranty in your country/region. if it is under warranty - call numbers provided and arrange it.
if there is no warranty for your unit anymore, any tv technician will help you.
hope this info will help you - do not forget to vote...
Feb 12, 2015 | Sanyo Televison & Video
Tip
No Sound or Garbled Sound on a Nuvi Series GPS
I've seen many posts of "No Sound" or "Garbled Sound" for the Garmin Nuvi Series. This is a common problem with the Nuvi.
In order to troubleshoot this problem, we need to determine if it's a hardware or software issue or a setting issue.
No Sound:
1. Try the obvious. Is your volume setting turned up?
2. Is the sound muted with the mute button?
3. If your Nuvi has a FM transmitter, is it selected to "FM" or "Speaker"? The "FM" setting will mute the internal speaker. Setting it to "Speaker" will send sound to the speaker.
Garbled Sound:
1. Does the sound seem to be better at lower volume settings?
If you still can't hear audio or if the sound is garbled, then we now have to determine if the internal speaker is defective. The easiest way to do this is:
1. Plug a set of headphones into the headphone jack. Now try listening to the sound. Listen for the touchscreen beeps, MP3 audio, voice directions, etc. Try adjusting the volume using the headphones. If you can hear sound through the headphones and it's clear and not garbled, then your internal speaker is defective.
The headphone jack is not only a jack but it's also a switch. When you plug in your headphones, the audio amplifier of your Nuvi is switched from the internal speaker to the headphone jack. When you unplug the headphones, your Nuvi's audio amplifier is reconnected to the internal speaker.
Now, if you can't hear audio through either the internal speaker or the headphone jack, you may have a different problem.
1. The internal audio amplifier (hardware) is defective.
2. There is a software problem. You could try resetting your Nuvi with the reset button or perform a factory reset. The software problem is more likely if you can hear MP3 audio or touch screen beeps but not speech.
The internal speaker has a voice coil. The voice coil is nothing more than a thin piece of long wire, wrapped around a magnet, numerous times. If you can't hear any sound, it is very likely that this coil is "open"; meaning that the wire has broken inside. If the sound is garbled, this is an indication that the speaker is mechanically defective and not reproducing the sound as it should. The speaker has a "diaphram" that moves in and out as it reproduces sound. If the diaphram has been damaged, it can't move in or out like it should and reproduce the sound clearly. There is also a possiblity that the voice coil has shorted windings, meaning that instead of it being a long piece of wire, it's now shorted to its adjacent windings and is electrically shorter now. Again, this can impact the reproduction of sound.
So, why did your speaker go bad?
1. It's possible it was defect in the manufacturing process and failed prematurely.
2. You might have had the volume up too high. I recommend using the lowest volume level possible. High volume levels put greater stress on the diaphram and may overheat the voice coil.
3. A speaker is an electro-mechanical device. It's subject to being damaged if you happen to drop or jar your Nuvi and/or operate it outside of its normal operating parameters.
What's the Next Step?
If your Nuvi is under warranty, I strongly suggest that you contact the manufacturer and tell them what happened. Tell them all of the steps you have gone through to confirm that the speaker is defective. If the warranty is still in effect, they should repair or replace your Nuvi.
If your Nuvi is out of warranty, try calling the manufacturer anyway. You have nothing to lose. Maybe they will replace it anyway.
If you have no sucess with the manufacturer, you will need to take your Nuvi to someone who is qualified in repairing your Nuvi.
I hope this tip has been helpful to you. Feel free to contact me if you have further questions or require further assistance with this problem.
Best wishes,
- Jim
http://www.sharcnet-usa.com
on Oct 01, 2008 | Garmin Nuvi 350 Car GPS Receiver
Tip
No Sound or Garbled Sound on a Garmin Nuvi GPS
No Sound:
Garbled Sound:
Best wishes,
- Jim
on Sep 30, 2008 | Garmin Nuvi 660 GPS Receiver
Ipad 3 sound garbled
Is there difference between speaker and headphone jacks ports
Not all computer headphone jacks will work with speakers. So, it would appear that your computer is one them. Read the article I've linked.
Jun 05, 2014 | Apple iPad 32 GB WiFi Tablet PC
When I am playing my music on my computer, the sound is terrible. The music is loud but garbled and the singing is low and garbled that you cannot understand or barely hear what the words are. Thank...
You need to purchase a better sound card for your machine. http://www.google.co.uk/search?q=sound+card&hl=en&tbs=shop:1&aq=f#q=sound+card&hl=en&safe=off&tbs=shop:1,p_ord:p&sa=X&ei=FmlyTa2mAYKXhQexotkw&ved=0CAoQuw0oAQ&fp=3ae27606703de1d6
Mar 05, 2011 | Dell A215 Computer Speakers
Tip
No Sound Issue on the Garmin Nuvi Series
No Sound:
Garbled Sound:
Best wishes,
- Jim
on Sep 30, 2008 | Garmin nuvi 350 GPS Receiver
Toshiba tv, model cf32c50 has a garbled sound issue.
distorted sound sometimes accompanied by buzzing is caused by detuned circuit in the SIF amplifier and sound detector circuit. a distorted sound alone is caused by a breakdown in AF amplifier circuit so try to change the sound ic since its the only options left. good luck!
Jul 27, 2010 | Toshiba Televison & Video
Sammsung s4253 plasma tv audio garbled on digital channels
I had the same problem with my S4253 using Directv. I then turned off the Dolby Digital on the sound settings on the Directv satellite box. Problem went away.
Oct 04, 2008 | Samsung HP-S4253 Television
Nuvi 350 Garbled voice
How is the other sound? Like MP3 sound? Is it garbled there? Try using headphones. If the sound is good there, then your internal speaker is bad.
Email me at ks3r at sharc dot net if you are interested in me fixing this for you.
- Jim
Sep 10, 2008 | Garmin Touch Screen GPS Receiver
TV Sound
Hi there!
There may be loose solder connections around the IF or sound section of the board. Sound section you will find in the area where the speakers plug into the board. IF is in the area of the tuner. Check also for the correct selection of sound for your area.(BG,DK,I,etc.). Good Luck,JUS004
Mar 08, 2008 | Apex Digital AT2002S 20" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
