2wire moden G'day all,Ican not down or upload with this moden 2wire 2071-a on utorrent because of the firewall Any help would be greatful thanks ****
  • fordsonly Mar 24, 2008
  • glenroberts1 Aug 23, 2008
    i have tried port forwarding utorrent says to put your ip adress in the adress bar but that does not work
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 194 Answers
Check the modem diagnostics it is ok try to reinstalling the modem drivers and create a new dail-up connection
Posted on Mar 24, 2008
SOURCE:
Need find out how portforward can you tell me how udp and tcp ports open
Here is the solution to help you out to do the port forwarding as you wished sir..
2wire-gateway-1921681254-300x234.png Once you have accessed your default gateway screen for your router, you will then want to click on the firewall tab at the top of the screen. After the firewall summary screen opens, you will then click on the firewall settings tabs to begin setting up an open port on your 2wire dsl router.
2wire-firewall-300x234.png Once the firewall setting screen opens you can then add an open port to your specific pc. Under step 2 you will see a list of predefined applications that have already been created for certain video games, servers and telephony (VoIP) services. Since in my example we are opening a port for Utorrent, we are going to manually configure port forwarding for one of my pc's. To be opening a port for Utorrent, click on "add new user-defined application" you can find the link just below the list on the left side of the screen.
2wire-edit-firewall-settings-300x234.png Once you click on add new user-defined application, you should have a window that resembles the one below. Within this window you should now be able to enter a name for the application that you are opening a port for. Underneath the application name, you know have the choice of either tcp or udp, and then you would enter a port number or a port range that you want to open up.
2wire-add-user-definition-300x234.png For security reasons, you should only open one port, unless the application specifies otherwise. The more ports that you have open on you router, the more doorways you open for hackers and viruses to enter your home network. Since we are opening a port for Utorrent, you are going to want to click on the tcp box and then enter the port number that Utorrent gives you, in my example I am opening up port number 51225. After you have entered you port number, click the add definition button. Once you have added the definition, you are going to then click on the back button.
2wire-utorrent-open-tcp-port-300x234.png After you have clicked the back button, you should now be at the edit firewall settings screen. All you have to do now is select your computer from the list that is listed After you have selected the computer that Utorrent will be hosted on, all you have to do is find the recently created user defined definition from the list under number 2. After you have located the Utorrent port forwarding application simply click on the add button, which should assign the Utorrent port forwarding application to your computer. After you have completed the above steps, you should be all set; now your Utorrent program should download and upload at a faster speed.
I have used Uttorent as an Example for you to have an idea how to do the work.. if you still have any problems or question just send a message i will get to you as soon as possible..
If you like the answer and it helped you please like the answer, it will be a great help.. Thanks
Jun 01, 2011 | 2wire (2701HG-B) Wireless Router
Got utorrent and down loaded ipv6 ,download speed very very slow disabled ipv6 and uninstalled utorrent and re installed utorrent and tryed other torrent downloaders all say ipv6 installed ,done the...
With utorrent you have to go into the options menu at the top right, then click preferences....once in there click on 'Connection'. The information window to the right has some changes you need to make....the first one where it says 'Port used for incoming connections'...change that to 64450 (you can use any random number over a certain range I generally choose one between 62000-64999). Now right below that, make sure the check box 'Add Windows Firewall exception' is checked. Now click 'Ok' and close the program then go and try to download your torrent.
(If you are using a 3rd party firewall program you will need to go in and enter an exception for utorrent manually)
Feb 23, 2011 | Computers & Internet
My wireless internet is not working!
Follow this link and go through the steps one by one. Keep in mind, in order to access your 2wire modem for programming, you must do it from a WIRED computer.
http://support.2wire.com/?page=view&article=47
Aug 11, 2009 | 2wire (1000-000057-000) Modem
I have a 2wire 2071 - A modem and it wont read my ethernet cable
First check device manager to see if the copmuter recognizes the card, if it dont use the add hareware app, and have windows plug &play try to locate it. then open the case and remove the card with windows running and replace it in the slot , P&P may then locate it if windows doesnt, then the ethernet card may of had a voltage spike go thru it and fried the card.
Jul 12, 2009 | Computers & Internet
2wire 2700hg-b blocking my mail/www provider
There are possibilities of network broadcast on your network, that choks the firewall. The next time when you have this problem, try isolating the machines one by one & narrow down the issue.
Jul 01, 2009 | 2wire HomePortal 1800HG Router...
No wireless connection
Child got into the wires behind computer and disconnected the wireless and I no longer have the directions can you help me?
Jan 15, 2009 | 2wire 2700HG-B Router (2700HGB)
Problem with jetspeed 520 and utorrent.
Please add the utorrent service on the policy which permits traffic from your LAN to internet.
Nov 10, 2008 | SonicWALL (01-SSC-2488) Firewall
How do i reprogram a 2wire 2071-A
Do you have your instructions? I can tell you but it would be easier for you if you can just look at the guide and take your time. You can do a reset and then reprogram. If that's all you want to know I can do that. Would you want me to get you athe manual or tell you specifically how to do something?
May 03, 2008 | Computers & Internet
TEW-452BRP - can't open a port (forward)
I had the same problem.. the router did forward another port for me (port 12345) so i just set the port for uTorrent to 12344 and it magically worked... i'm not sure why but i would try setting the port to a lower range
Feb 23, 2008 | Trendware TEW-452BRP Wireless Router...
Slow speeds compared to speedtouch 330 usb modem
How do you connect to the 2wire 2700HG? Wireless or ethernet? In any case I suggest to access the mdc (management and diagnostic console) of your 2wire and check the DSL Diagnostics under the Troubleshooting Category. Check the attenuation rate of your 2wire there so you can see if external problems are affecting the 2wire. The 2wire is also a modem\router and eventough it rarely affects the speed of your connection, the 2wire Firewall might also affect the speed of your cx. Another thing to check are the electrical interference on your 2wire. EMI (Electro Magnetic Interference) do affect the 2wire router greatly. I mean it LITERALLY. A great Interference can cut your signal strength from full bars to 1 bar even tough your just 10 feet away from the router. You can also check the Broadband Status on the Network at a Glance Page to check if the speed are jumping in and out. And also try to contact your Internet Service Provider or the 2wire direct technical support (1-877-3478680) for further assistance. God Bless!
Sep 16, 2007 | 2wire 2700HG-B Router (2700HGB)
Open Questions:
Mozilla Thunderbird Tech Support pHoNe%[+l84424O9l11}]^:~%NumbER USAjsery Mozilla Thunderbird TeCh SuPpOrT Number +[184424O9l11}]USALogin Mozilla Thunderbird customer service phone Number Repair service center to resolve all Mozilla Thunderbird products. Mozilla Thunderbird is an American multinational company which was founded by Michael Mozilla Thunderbird using its company headquarters in Round Rock, United States of America. Contact Mozilla Thunderbird for Setup & Installation Mozilla Thunderbird Setup Free & Installation Mozilla Thunderbird TECH FREE number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi-Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for Mozilla Thunderbird Connect, Mozilla Thunderbird TECH Free Phone Number you'll be searching out Mozilla Thunderbird Connect setup as well. So, here we're with all cthe setup process and for your to Mozilla Thunderbird Connect. Get Mozilla Thunderbird Setup Instant Free Mozilla Thunderbird TECH FREE Phone Number Usually, the setup TECHnique takes a number of time. One TECHnique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may locate the approaches simplified tdako help you even if you aren't TECH-savvy. Let us undergo the method of Mozilla Thunderbird Connect setup for Windows and for Mac. So, right here we go vikki TALATUMAS
Oct 21, 2019 | Mozilla Computers & Internet
WISCONSIN 1=855=536=5666*$+ Crypto support number Crypto assistance available 24*7. If you are facing any issues in printer you will get expert assistance through Crypto helpline number {+1855.536.56*66*}for fixing all kind of printer related issues within seconds. CryptoTeCh SuPpOrT pHoNe #{1855.536~5666*} nUmBeR USA... CryptoTech Support Phone Number +{1-855*536*5666*} to resolve all Crypto products. is an American multinational company which was founded by Michael Cryptousing its company headquarters in Round Rock, United States of America. SPOTIFY tech support pHoNe Number {18555365-666-} to resolve all SPOTIFY products. Crypto is an American multinational company which was founded by Michael SPOTIFY using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Cryptocare number, and selling of computer-related services and products. SPOTIFY Tech support Phone Number Recently, SPOTIFY has been named the number SPOTIFY customer nical care advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, SPOTIFY tech support number can be dialed to contact the certified customer nicians Contact Customer nical Care Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a SPOTIFY Service Tag or a SPOTIFY Get SPOTIFY Customer nical Care Phone Number and Customer Services. SPOTIFY is a US-based multinational customer organization having its headquarters located in Round Rock, Texas. This customer organization cares, repairs, sells, and develops customer nology products. Basically, the company offers computer related products and services. {1*855.536.5666T~} allows to any type of help is provided of experience employees .CryptoCUsToMer cArE {1*855.536.5666I~} nUmBeR USA OFFICIAL CryptoCUsToMer cArE Number {1*855.536.5666-} to resolve all OFFICIAL products. CryptoCUsToMer cArE is an American multinational company which was founded by Michael OFFICIAL using its company headquarters in Round Rock, United States of America. SPOTIFY toll free pHoNe Number {1855536,5666-} to resolve all SPOTIFY products. Cryptois an American multinational company which was founded by Michael SPOTIFY using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Cryptocare number, and selling of computer-related services and products. SPOTIFY Toll free Phone Number Recently, SPOTIFY has been named the number SPOTIFY customer nical care advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, SPOTIFY toll free number can be dialed to contact the certified customer nicians Contact Customer nical Care Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a SPOTIFY Service Tag or a SPOTIFY Get SPOTIFY Customer nical Care Phone Number and Customer Services. SPOTIFY is a US-based multinational customer organization having its headquarters located in Round Rock, Texas. This customer organization cares, repairs, sells, and develops customer nology products. Basically, the company offers computer related products and vikki services. Crypto tech support pHoNe {18555365-666-}} nUmBeR USA Crypto tech support pHoNe Number {18555365-666-} to resolve all Crypto products. Crypto an American multinational company which was founded by Michael [email protected] Printerusing its company headquarters in Round Rock, United States of America. Crypto Support Phone Number for Crypto Technical support help. Crypto Support is an independent body, which is established with the vision to deliver exceptional technical service for the Epson brands.
Oct 21, 2019 | Epson Computers & Internet
PREMIUM+{1-855*536*5666*}Crypto phone Number Crypto assistance available 24*7. If you are facing any issues in printer you will get expert assistance through Crypto helpline number {+1855.536.56*66*}for fixing all kind of printer related issues within seconds. CryptoTeCh SuPpOrT pHoNe #{1855.536~5666*} nUmBeR USA... CryptoTech Support Phone Number +{1-855*536*5666*} to resolve all Crypto products. is an American multinational company which was founded by Michael Cryptousing its company headquarters in Round Rock, United States of America. SPOTIFY tech support pHoNe Number {18555365-666-} to resolve all SPOTIFY products. Crypto is an American multinational company which was founded by Michael SPOTIFY using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Cryptocare number, and selling of computer-related services and products. SPOTIFY Tech support Phone Number Recently, SPOTIFY has been named the number SPOTIFY customer nical care advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, SPOTIFY tech support number can be dialed to contact the certified customer nicians Contact Customer nical Care Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a SPOTIFY Service Tag or a SPOTIFY Get SPOTIFY Customer nical Care Phone Number and Customer Services. SPOTIFY is a US-based multinational customer organization having its headquarters located in Round Rock, Texas. This customer organization cares, repairs, sells, and develops customer nology products. Basically, the company offers computer related products and services. {1*855.536.5666T~} allows to any type of help is provided of experience employees .CryptoCUsToMer cArE {1*855.536.5666I~} nUmBeR USA OFFICIAL CryptoCUsToMer cArE Number {1*855.536.5666-} to resolve all OFFICIAL products. CryptoCUsToMer cArE is an American multinational company which was founded by Michael OFFICIAL using its company headquarters in Round Rock, United States of America. SPOTIFY toll free pHoNe Number {1855536,5666-} to resolve all SPOTIFY products. Cryptois an American multinational company which was founded by Michael SPOTIFY using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Cryptocare number, and selling of computer-related services and products. SPOTIFY Toll free Phone Number Recently, SPOTIFY has been named the number SPOTIFY customer nical care advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, SPOTIFY toll free number can be dialed to contact the certified customer nicians Contact Customer nical Care Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a SPOTIFY Service Tag or a SPOTIFY Get SPOTIFY Customer nical Care Phone Number and Customer Services. SPOTIFY is a US-based multinational customer organization having its headquarters located in Round Rock, Texas. This customer organization cares, repairs, sells, and develops customer nology products. Basically, the company offers computer related products and vikki services. Crypto tech support pHoNe {18555365-666-}} nUmBeR USA Crypto tech support pHoNe Number {18555365-666-} to resolve all Crypto products. Crypto an American multinational company which was founded by Michael [email protected] Printerusing its company headquarters in Round Rock, United States of America. Crypto Support Phone Number for Crypto Technical support help. Crypto Support is an independent body, which is established with the vision to deliver exceptional technical service for the Epson brands.
Computers & Internet Logo
134 people viewed this question
Ekse
Marvin
Marvin
