Question about D-Link DI-808HV Router (280006OB)
I have a DI-808HV router and since I bought it in 2007 I hadn't thought of updating the firmware. I went to D-Link support but it was a dead end. I found a copy of what was supposed to be the latest version. I updated but found it was a version from 2006 and the one I had was 2007!!! I need to find the latest or at least the version I had, Any sources would be appreciated Charles
    President:
  • 1,768 Answers
The latest is the what you have as firmware update.
you should contact the manufacturer's tech support.
Posted on Apr 27, 2010
Cannot get iphone to log onto network
This may be resolved by something as simple as a power-cycle of the router. Disconnect the power cable from the router and wait approximately 30 seconds and then plug the power cable of the router back in.
If this does not resolve the issue, see whether there is a firmware update available for the router at the D-Link support page for this router.
At that support page, click on the "Support Resources" tab and follow the instructions for determining the version of DI-524 that you own.
Once you have determined this, you can then download the appropriate firmware update and follow the directions provided.
Often a firmware update is required to support newer equipment.
If the problem continues to persist, it may be that this router, which is "end of life" on the D-Link, will not support your iphone.
Dec 27, 2010 | D-Link AirPlus DI-524 Wireless Router
D-link DI-808HV - no response after firmware upgrade
Unfortunatly, from what you are saying it seems that the router is dead.
Mar 10, 2010 | D-Link DI-808HV Router (280006OB)
Working on a dlink di808hv and it wont connect to the internet
I have disk for d-link wireless router / wbr-1310 that will not load.
need interet site with download for this router. thanks
Feb 14, 2010 | D-Link DI-808HV Router (280006OB)
I am running vista and using the dlink di-808hv router. i have set up a pptp connection. when i use ms vpn to connect, it connects but only limited connectivity. can you help?
Peer to peer tunneling protocal is what pptp is if its connecting a limited connectivity that means some of the ports are stull being blocked thus needing for you to use your machine in a demilierized zone so this will open all avilable ports to your VPN software. Also keep in mind not all ISP's will support PPTP so you may have to use a softvpn software. Thanks i hope this helps
Sep 01, 2009 | D-Link DI-808HV Router (280006OB)
D-Link DI-808HV Router Problem
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
May 04, 2009 | D-Link DI-808HV Router (280006OB)
Hi. i cant connecct my VPn
- Make sure you have an updated firmware on your router and after wards kindly visit this site for further instructions:
http://support.dlink.com/faq/view.asp?prod_id=1384&question=DI-804HV%20/%20DI-804V%20/%20DI-808HV
Mar 15, 2009 | D-Link DI-808HV Router (280006OB)
How to get two DI-808HV routers to talk
please call dlink tech support at 877-453-5465. just an advise on how to handle the call when you reach dlink tech support (agent); do not agree to call back after you troubleshoot with them (they'll be giving you a case id reference# and be advising you to check your pc or call "who" and call them back to continue the troubleshooting). insist to the agent that he need to resolve the problem asap (by the way, agents are not allowed to drop the call or they'll be dead-history!). and if the agent still insisted you to call back, ask for a "senior level technician" to finish the job (escalate the problem).
fyi: dlink tech support handling time to resolve a call is 15 to 18 minutes only. if you reach that 15-18 minutes (max) time the agent will think of a way for you to call back (advising you to check with your pc manufacturer, check with your ISP, call microsoft to update your software, etc... non-sense!) they need to do this in order to reach their handling time (agents need to reach 21 to 25 billable calls, and billable calls are "solution provided", "resolved", and "dropped call"). ---- believe me, i was one of them and repented.
Mar 05, 2009 | D-Link DI-808HV Router (280006OB)
DI-524 status problem
Did this happen after a firmware upgrade? If so, this link may help:
http://borgetech.blogspot.com/2007/09/d-link-di-524-revision-b4-status-light.html
Apparently there's a utility which will force firmware to load on the router. The steps are a bit technical, though.
If that doesn't work, the router is probably toast. Time for a new one.
Feb 08, 2009 | D-Link AirPlus DI-524 Wireless Router
D - Link Router and a switch
If you don't have the latest firmware for your Dlink router which is 1.43, please download it first. You may want to download the software here: http://drivers.softpedia.com/progDownload/DLink-DIHV-Firmware-Download-20625.html
Access you router by going into 192.168.0.1, then look for the firmware upgrade option. Point the location of the .bin file that you've downloaded and that should fix your intermittent problem.
Hope this helps.
Thanks.
Jul 07, 2008 | D-Link DI-808HV Router (280006OB)
D-Link DI-808HV Router (280006OB) Logo
113 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
