Question about Digital Audio 1500 WATTS CLASS D MONO BLOCK AMPLIFIER DAD1504 Car Audio Amplifier
How do i fix the rca's on the amp? the amp turns on and the green light comes on but the amp does not give power to my subs. So i think the rca relays are blown. can it be fix'd or hot wired some how?! its one of the best amps ive had so i hate it to go to waste
  • 93 Answers
Sorry but when a amp is fryed its done for. Looks like you will have to replace it.
Posted on Apr 27, 2010
RCA D61130 power light blinks green tv wont come on
Time for it to go to a shop--it is unlikely this brand/model will get fixed in the home.
May 18, 2012 | RCA D61130 TV
Havin problem with a1200 class a/b amp it ligts green and red at same time after hooking in remote how doi fixdo i need diagram to fix
Make sure you don't have any shorts on your speaker wires or rca cables. Unplug one at a time, the turn on power until it stays green with no protect light, then you know what input is causing the short. If you remove all speaker wires and rca wires and all you have connected is the ground, power(12volts) and remote and it still lights up red/green(in protect mode) then your problem is the amp.
Mar 09, 2010 | Car Audio & Video
No sound
unplug spkr from amp and leave rca and turn if this dont happen again check you spk
if it does happen again unplug rca and turn on and if this happen your amp may be bad
May 17, 2009 | SPL Audio Phantom DK2-1000 Car Amp
Hi there just picked up a jbl bp 1200 for good price although just wired it up and turned the key to find the red light come on few seconds then solid green and no sound...checked ground,remote wire rca...
Most amps do a "power up" where all the lights can come on, then settle into "green light" or some sort of "ready status" light comes on. The red or yellow lights can indicate "protection mode" (a bad amp) and green is the universal signal for okay. - So try this - Double check your connections and the amp. Pay close attention to the settings on the amp before you declare it not working. I have had many amps (especially newer ones) cause problems from a simple switch that was in the wrong position. Be sure to use good power and audio cables matched to your amps capabilities with good strong grounds on a clean non-painted metal surface. If all is in order from there start checking your signal from the deck to the amp. You can also check manufactures website for the manual, (if you didn't get one) looking at it may give a clue about proper switch configurations and hook-ups. Let me know if you need additional info concerning these idea's.
-Dynami
Apr 15, 2009 | JBL BP1200.1 Car Audio Amplifier
Rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv will not turn on
I turn on tv green light comes on and gos off and no picture.
Feb 04, 2009 | RCA D52W19 52" Rear Projection Television
My Sonance 2100 has no output
Ensure that the power button is pressed in. Set the Auto-On switch on the rear panel to the OFF positon. If the green light comes on the amp was not seeing any signal to trip the Auto-On feature to turn on. Check the source and RCA cable connected to the amp.
If no green light, then the internal fuses are blown. Have a certified technician handle that repair to avoid a shock hazard.
Jun 14, 2008 | Sonance 2120T 2-Channel Amplifier
RCA TV Will Not Power On - Powered Off Suddenly
I have the same problem. Just Monday it started, Green light blinks but nothing comes on. Any suggestions?
May 31, 2008 | RCA HD52W59 HDTV Projection Television
When Amp is powered on by remote lead, red LED comes on
how are your rca ups comming from your deck or did u splice and ad to factory?
Apr 30, 2007 | Visonik V2118 Car Audio Amplifier
Car Audio & Video Logo
75 people viewed this question
Top Digital Audio Car Audio & Video Experts
Joe Ankney
Level 1 Expert
Matthew Spark
Matthew Spark
Tom Chichester
Are you a Digital Audio Car Audio and Video Expert? Answer questions, earn points and help others
