Question about Samsung Washing Machines
Samsung washing machine error message 13e
Got a Samsung washing machine Q1657s which keeps showing the error message 13e on the display. I have cleared the filter and turned the machine off for over an hour at a time but it wont reset. How can i get rid of this error message?PLEASE!
yalmer
  • 552 Answers
SOURCE: samsung washing machine
http://www.repairclinic.com/SmartSearch/smartsearch.aspx?SearchText=%60Awashingmachine
Go here for a new filter. If the link does not work, go to the repairclinic website first.
Posted on Mar 25, 2008
SOURCE: Can't get rid of E1 error on a Samsung front loader washing mach.
E1 : washing machine has exceeded a check time for fill, heat or empty.
Common causes for this are fill and empty problems, heater fault (or the wiring
to it broken), water pump open circuit (although that would stop the water draining too) Pressure chamber blocked or pressure tubing pipe looped below the pressure bottle, or a sticking eco ball in the sump hose (sludge and grease build up)
This error code is generic and vey common.Since you have tried the remedies.Try getting checked the internal wiring damage by professionals.I hope certainly hope the problem lies there.
Posted on Dec 10, 2008
SOURCE: Samsung WD-J1255R washing machine takes double the displayed time
The problem is surely with the clock timer or the control board (cannot be repaired).I hope the product is under warranty, you can better have it replaced.Good luck.And please do post your comments.
Posted on Jan 16, 2009
SOURCE: Samsung front loading washing machine won't spin out.
I have the exact same symptom with mine that is only 4 months old. I have a technician coming as soon as the part is available. The problem is the PCB control board. Samsung has corrected a known issue with the original and has manufactured a new one. This is a known issue and thus the part is hard to get. I have, however found a temporary fix. Unplug the machine for about a half an hour. I haven't figured out how long to do it exactly but when you plug it back in it should read PF for power failure. It's the equivalent of a reboot for your pc. I got about 3 days of service from the machine before it stopped spinning again. Another reboot and I'm back in business.
Posted on Feb 08, 2009
  • 13 Answers
SOURCE: Washer keeps displaying '4E' Lack of water error
If you have pulled out and cleaned the filter at the back of the machine where the hose connects then I would check that your pump is not running during the cycle and also make sure your drain line is at least half way above your drum at its highest point, If its too low then it will drain off even if the pump is not running.
Posted on Apr 11, 2009
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    I have a Samsung vrt top loader washer it keeps displaying 3e. Sometimes it will not even do it. What could be the problem
    Melisa, Check and see if still under warranty and contact Samsung for repair.
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    Global Download Center
    Samsung Washers
    Mar 02, 2016 | Samsung Washing Machines
    I KEEP GETTING A DE MESSAGE AFTER A FEW MINUTES
    My washing machine is displaying an error code ... - Samsung
    Samsung ElectronicsFeb 19, 2014 - ... your Samsung washing machine and the solution needed to resolve the .... If problem persists please call Customer Careline. *. dE. dE1. Ed.
    Aug 06, 2015 | Washing Machines
    I have a samsung washing machine wf7600naw washing machine that won't spin and is displaying the error code SE. How can I fix the problem?
    WATER DRAIN ERROR - Display shows 5E.
    5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
    Dec 11, 2010 | Samsung Washing Machines
    Problem with the Samsung Washing Machines The machine keeps coming up with the message HEI 10x
    Here is a list of errors for your machine.
    I hope they help you.
    SAMSUNG WASHING MACHINES, ERROR FUNCTIONS
    When an error occurs, the alarm noise will sound and the error code displayed in the program window. Listed below is a series of error codes you may or may not see for your model of Samsng Washing Machine. The errors are shown as blinking in O.5 second intervals until the error status has cleared. In this case, all the driving devices are turned off until the error is cleared.
    1. WATER SUPPLY ERROR - Display shows 4E.
    Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
    2. WATER DRAIN ERROR - Display shows 5E.
    3. OVER-FLOW ERROR - Display shows oE.
    Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
    4. UNBALANCE ERROR - Display shows UE.
    Laundry load is unbalanced, manually loosen any tangled laundry.
    If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
    5. WATER HEATER ERROR - Display shows HE, HE1.
    HE, HE1 is displayed if the water temperature rises by 7 C or more in 1 Min or by 2 C or less 20 Min after heating process has started. The error can be cleared by turning POWER switch OFF.
    6. WATER PRESSURE SWITCH ERROR - Display shows 1 E.
    * Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
    Normal Level = Abnormal W/L Frequency
    Low Level = 30.00 Khz
    High Level = 15.00 Khz
    If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
    7. ABNORMAL WATER TEMPERATURE ERROR- Display shows cE.
    e.g. If the water temperature is 50 C or more, during a Delicate or Wool cycle.
    At the time of initial water supply, if the water temperature is not appropriate, the display will show cE. This error can be cleared by POWER SWITCH OFF.
    8. WATER LEAKAGE ERROR - Display shows 11 E.
    Water Leakage error occurs when the water drains naturally, (by leakage) after the washing program starts.
    9. THERMISTOR ERROR - Display shows tE
    Nov 21, 2010 | Washing Machines
    Samsung model WF8602NHS showing error message 4E
    When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
    1. Turn off the water source to the washing machine.
    2. Unscrew the hose from the back of the washing machine.
    3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
    4. Push the filter back into place.
    5. Screw the hose back onto the washing machine.
    6. Turn on the faucet and make sure the connections are watertight.
    Also, please check the following:
    • Make sure the source water faucet is turned on.
    • Check the water pressure.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
    Sep 03, 2010 | Samsung WF306BHW High Efficiency Front...
    Error 4E + timer countdown is delaying
    Sep 02, 2009 | Samsung WF337AA Front Load Washer
    Letters UE on display
    UE = Unbalance Error
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Jan 26, 2009 | Washing Machines
    My brand new Samsung J845 washing machine keeps showing an error message (which is not in the manual of 1E. What could this possibly be and how do I fix it?
    I contacted Samsung Australia and was informed that this was a Water Sensor Level fault. The machine will be fixed under their warranty guidelines. Thank you.
    Apr 17, 2008 | Samsung Washing Machines
    Washing Machines Logo
    127 people viewed this question
    Top Samsung Washing Machines Experts
    Jaime Hernandez
    shaun taylor
    Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
