Question about Belling CookCenter 151 Dual Fuel (Electric and Gas) Kitchen Range
Oven not heating up
I think the element on my oven has blown, as fan is working but no heat. Does anyone know if this is a simple job that i could do to replace??? Can the element be replaced from inside the oven or do it mean removing oven and taking rear panel off????
  • Morph08 Mar 25, 2008
    keith thanks for your advice sorry only got instructions for 151 could scan this if you want if any help
Easy enough job, you can access the element via the screws inside the oven compartment. Just make sure the unit is isolated at the mains. It is then simply a case of removing the screw that holds the element in and unpluging the spade crimps that connect to it. 5 minute job at the most. Maybe you can help me in return, I have the cookcentre 132wgr but no instructions do you know where I could get some???
Posted on Mar 25, 2008
The fan works but no heat. Grill work
You need a new oven element. The oven element is not visible inside the oven as it is located around the fan, behind a safety panel. Its a simple DIY job if you are handy. Isolate oven from power. Look inside oven to rear panel where fan is located and there should be 4 screws holding the safety panel in place to cover the fan, Remove cover and you should be able to see the element which will probably be circular and mounted around the fan. Remove the element and take with you to ensure a correct replacement at your parts dealer.
Jul 03, 2015 | Ovens
No heat in oven
check that tthe cable connection to the elements is ok and not burnt and that the power is at this terminal, if present then change the element and if absent then check and change the the thermosatrt
Jul 13, 2010 | Ovens
My oven is not heating up but the fan is working - any ideas?
I dont know your model but generally the problem would be that the ring element around the fan has blown or less likely the thermostat has failed.Normally if you can see the light on the control for the oven temperature control light up and can hear a click from it as you turn up or down the the thermostat should be ok.You will have to get the ring element out and check with a multi-meter if it is blown and replace.
Hope this helps.
May 20, 2010 | Ovens
Heard a pop/bang and now no heat
Sounds like the oven element has blown.
To fit a new one, remove cover at rear of inner oven compartment, there you will see the round fan element.
Apr 06, 2010 | Electrolux EOD5330 Ultrafan Electric...
Oven's bottom heating element does not heat
this should show you how to change it
You-Tube video "pEhRqdvpiJM" placeholder (do not delete)
The main fault when the oven is not heating is that the element has blown here is a video on how to change your fan oven element and the motor.
For all your fan oven element click here
Jan 07, 2010 | Frigidaire Ovens
The main oven has stopped working. The fan works and the Small oven also works.
There could be a few different things wrong. The element may have died. Is the fan you mention the forced air fan? No heat usually means blown fuse or faulty heating element, and since the small oven works I would suspect the the element has blown. You would benefit from getting an appliance serviceman to make a house call to replace the element. Unless you're handy and have a soldering iron, some heat resistant sleeving, and can access the back of the oven comfortably.
Hope this helps. Let me know.
John
May 08, 2009 | Belling DB90 Electric Kitchen Range
Oven not heating up
circular element round the fan has blown. take back panel off inside oven and you will see element. to replace, take rear outside panel off and usually element is held in by 2 7mm nuts on posts sticking out of the element base plate. easy job.
disconnect of course
Jul 11, 2008 | Zanussi ZBF260 Electric Single Oven
Fan assist wont heat oven
the ring element may have blown. if it works ok with the top and bottom elements, (the convection oven) then it is likely the element surrounding the oven fan.
Jun 25, 2007 | Baumatic B187 Stainless Steel Electric...
Fan oven not heating, bosch hbn 202t
the fan oven element is separate from the grill element. the problem is that the circular element round the fan is blown. remove the back panel of the oven and you will see the element. replacement is easy. on most bosch, the element is removable from inside the oven but for some you have to remove the oven and take off the back casing
May 04, 2007 | Bosch HBL 5032 Electric Single Oven
Smeg single fan oven
You are right, it could be a thermostat or a heater problem. You should check that the heater element receive power. In case it receive power,the heater element should be replaced. In case it doesn't receive power, the problem is with the thermostat. In any case, check as well that all wires connected to the thermostat and the heater are in place. Good luck.
May 02, 2006 | Smeg SE250XUK Stainless Steel Electric...
Belling CookCenter 151 Dual Fuel (Electric and Gas) Kitchen Range Logo
338 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
