Question about GE Spectra JGBP35 Gas Kitchen Range
Oven's bake funktion does not work
My oven has two option bake and broil, I can broil, but can not bake ,what is the problem?
I thing this problem is caused by a clogged air pipe
  • Shep May 07, 2013
    It is an electric oven gas top
  • 713 Answers
Hi,You need to replace the oven igniter. You will find that this is a very common problem with that model and other models that use this igniter. It is very simple to do.
Look inside the oven and you will find 2 screws at the bottom of the oven in the back. Loosen them up and remove the bottom panel of the oven.
Remove the broiler, and oven trays and it is a 10 minute swap out. Removing the above items allows you the access needed to get to the two screws that mount the oven igniter to the burner.
Using either a socket (1/4") or a nut driver, remove the 2 screws and unplug the igniter. The most difficult part of the exchange is unplugging the igniter. The plastic will most likely break because it has become very brittle by being exposed to the heat. Be careful to break only the part that is being replaced.
If you do happen to break the fittings, they can be replaced with any male/female connector. If you need to replace this, I recommend that you stay away from plastic encased plugs.
You then install the ingiter, plug it in, and you are back in business. It is a very simple part to replace, but it is costly.
Thanks and take care
Posted on Apr 27, 2010
Will the oven work without the broiler attached
You could use the oven without the broiler. It is customary that the oven will use the broil element to even out the heat in the oven for better baking but you could use if. it just may not bake evenly. There could be two things that is causing the broil element to stay energized. the control is not shutting down or there is a short to ground in the broil element. Have the broil element tested, it could just need replacing. If it is in the control that is a bigger problem.
Mar 19, 2014 | Ovens
Oven quit, bake not working, replaced thermostat, now broil works, still no bake
Your problem may be the bake relay on the clock or wiring.try changing that
Aug 12, 2008 | Viking VDSC307-4B Dual Fuel (Electric and...
Frigidaire oven fefl68 broil element comes on on broil only will not come on on bake or clean
Hello - - If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works; contact a professional to diagnose the EOC (electronic oven control).
Nov 17, 2012 | Ovens
Frigidaire Gallery oven large element stopped working
Hello -
If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works, contact a professional to have the EOC (electronic oven control) diagnosed.
Sep 19, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Bake option doesn't work - other options work
If you have a gas range2_bing.gif check out this tip...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
If you have electric2_bing.gif then check this out...
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 03, 2010 | Amana AEW3530DDS Electric Single Oven
The oven doesn't turn on in the bake cycle
oven doesn't come in broil but the broil should . the bake should in bake . but if it does work in self clean then your oven is ok and its the clock ( erc) that has failed . some times there is a code in the display stating the problem. but ist loks like a clock failure . **** ..
Dec 23, 2009 | Amana AGR5735QDS Gas Kitchen Range
GE Profile Stove baking option not working
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at www.fixyourboard.com.
Aug 31, 2009 | GE JGRP17 Gas Single Oven
TAPPAN gas range model 30-3991-00/03 oven won't work.
the button your holding is the switch that tells the board that the consumer whats to bake.so if holding the switch causes that message to work[or oven to heat] and letting go of that button ,then no work .its that button ,but its all part of the board .just that part of its funktion is broken.,if it was lets say your oven ignitor or oven gas safty valve ,the board/oven control[the one with the button]would continue to try after you have selected bake [pushed button]or would give error code.hope that helps you. God bless you , tom
Jan 05, 2009 | Tappan Kitchen Ranges
Broil turns ON when pressing BAKE button on RBS275PD Whirlppol oven
Our Whirlpool oven just started doing the same thing!!!! The Delay Start Time (setting it for one minute ahead) and then Start works just fine.  But we fried the tops of three loaves of homemade bread!!!!
Is Whirlpool just a bad brand for ovens?
Dec 07, 2007 | Whirlpool RBS275PD Electric Single Oven
GE Spectra JGBP35 Gas Kitchen Range Logo
480 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
