Question about Kenmore Elite 45986 Front Load Washer
What does flashing 02 then F? - Kenmore Elite 45986 Front Load Washer
  • 5,911 Answers
If this is a Kenmore Elite series front loader, "F02" is a Long Drain error. This is usually an indication of an obstruction somewhere in the drainage system. In most cases, the drain pump reservoir needs to be cleaned out. The following link explains how:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
If you check the drain pump reservoir and the problem still persists, you may have a pump with a damaged motor/impeller, or something lodged in one of the drain lines. In particular, the drain line that runs from the bottom of the wash tub to the inlet side of the pump.
I recommend you remove the inlet hose, as well, and inspect for clogs. In is common for small garments to become lodged in this area and restrict water flow to the drain pump. Check the output drain line for obstructions as well.
It does not take much to damage this small drain pumps. The error code is generated if the drain cycle exceeds 8 minutes. So...if the impeller or motor become damaged, and the pump does not pull water at the correct volume, you may still experience the drain error. In this case, you will have to replace the pump in order to get the error to clear. The following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
NOTE: For an explanation of all the error codes, each one of these washers comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front fett of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information provided and let me know if you have any further questions. I hope you find this information helpful.
Posted on Apr 27, 2010
F 02 flashing on control panel
F/02..
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Oct 21, 2012 | Kenmore HE3T Washer
My gear is not selecting after the drive.
For Automatic transmission problem,click the link below:----Transmission shifting problem?
http://schematicsdiagram.blogspot.com/2012/01/transmission-shifting-problem-on-toyota.html
Transmission Slips out of 2nd gear?
http://repairhelpcenter.blogspot.in/2012/02/transmission-slips-out-of-2nd-gear.html
Automatic transmission troubleshooting:----
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Automatic transmission shift lever issues?-------
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
AUTOMATIC TRANSMISSION FLUID LEVEL? --
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-automatic-transmission.html
AUTOMATIC TRANSMISSION FLUID AND FILTER?
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-automatic-transmission.html
Transmission fault light on car dash?
http://schematicsdiagram.blogspot.com/2011/12/transmission-fault-light-on-car-dash.html
OD light flashing and transmission fluid leaking?
http://repairhelpcenter.blogspot.in/2012/02/od-light-flashing-and-transmission.html
Why Transmission fluid leaks near radiator?
http://repairhelpcenter.blogspot.in/2012/02/transmission-fluid-leaks-near-radiator.html
http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
****** wont go in reverse?
http://technoanswers.blogspot.in/2012/02/dodge-neon-wont-go-in-reverse.html
Automatic transmission will not go into reverse?
http://technoanswers.blogspot.in/2012/02/dodge-automatic-transmission-will-not.html
Transmission is making buzzing noise?
http://technoanswers.blogspot.in/2012/02/transmission-is-making-buzzing-noise.html
This will help.
Thanks.
Feb 27, 2012 | 2005 Ford Taurus
92 chevy 3500 6.5 auto trans trouble
For Automatic transmission problem,click the link below:----Automatic transmission troubleshooting:---- http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html---------Automatic transmission shift lever issues?------- http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
-----------AUTOMATIC TRANSMISSION FLUID LEVEL? --
-----------Transmission fault light on car dash? http://schematicsdiagram.blogspot.com/2011/12/transmission-fault-light-on-car-dash.html
--------Transmission shifting problem? http://schematicsdiagram.blogspot.com/2012/01/transmission-shifting-problem-on-toyota.html
--------Transmission Slips out of 2nd gear?
Automatic transmission will not go into reverse? http://technoanswers.blogspot.in/2012/02/dodge-automatic-transmission-will-not.html
----------Transmission is making buzzing noise? http://technoanswers.blogspot.in/2012/02/transmission-is-making-buzzing-noise.html
-----------This will help.Thanks.
Feb 22, 2012 | 1992 Chevrolet C/K 3500
1995 isuzu rodeo 5speed transmision shift lever not shifting gears
For Automatic transmission problem,click the link below:---- Automatic transmission troubleshooting:----
Transmission fluid leaking?
This will help.
Thanks.
Feb 15, 2012 | 1995 Isuzu Rodeo
F 02 STARTS FLASHING WHAT CAN I DO TO STOP
i believe that is the code for slow drain condition.pump may need to be cleaned
Jan 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer flashing 02 F. Maytag epic washer won't spin -flashing 02 F about 15 minutes into the cycle. We just had new electrical components put into it.
You need to use the HE detergent. I believe that is a drain problem. By using the regular detergent that causes more suds and in turn clogs your drain
Jul 16, 2009 | Maytag EPIC MFW9700S Front Load Washer
Washer won't spin- flashing "f 02"
in the HE3 series it means the drain tube or pump is clogged
Mar 02, 2009 | Kenmore Elite 45986 Front Load Washer
F flashing followed by a 2
F/02 Long Drain
Feb 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Check-engine light on
P1132 is front 02 bank 1 and P1152 is front 02 bank 2
This codes indicate a rich condition. I would check for a dirty air filter or a dirty MAF sensor.
Jan 31, 2009 | 2001 Ford Excursion
No sound flashing e-02 in window
Turn power off this will release the protection turn power back on if code is still flashing contact kenwood dealer
Jan 04, 2009 | Kenwood Excelon KAC-X621 Car Audio...
Kenmore Elite 45986 Front Load Washer Logo
83 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
