Question about Ryobi Garden
My Ryobi 767r weedeater will start but will only run for a few seconds.
#1 Taper
  • 1040 Answers
SOURCE: replacing fuel lines on ryobi 767r trimmer
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jul 03, 2009
SOURCE: RYOBI weed eater.hard to start. starts then stops
I have a ryobi doule line bought in 1997..Had same problem put new gas cap on and problem solved..could not get air in....
Posted on Aug 02, 2009
SOURCE: Ryobi weedeater 4 stroke starts but only runs for
We have a Ryobi gas weed eater. We can get it started but it doesn't stay on. I took it in to get it fixed and he said it was the primer switch, which he replaced, but we are still having the same problem.
Can you help us or refer us to a Ryobi repair store? We live in Phoenix, Arizona but can go to any repair store in Glendale, Tempe, Phoenix, Mesa, Scottsdale, wherever in Arizona. Thank you. Sally
Posted on Jun 26, 2010
  • 14 Answers
SOURCE: How to install replacement line for a Ryobi 18v weedeater
The long bolt coming down at the end shaft like place reel over bolt then turn back and forth slowly while pushing upward and it should lock in and take knob or bolt at end and tighten to the right.
Posted on Jul 07, 2010
rycgl
  • 1545 Answers
SOURCE: My Ryobi 700R "EZ" weedeater smokes excessively.
Check the fuel/oil mix ratio you are using. Some Ryobis use a 32:1 mix and some use a 40:1 mix. There isn't much difference there. To be on the safe side, if you machine is possibly running or tuned a little "lean" I would start off with about 4 oz/gallon oil to gas mix. Use synthetic 2-stroke oil also. Your machine will perform much better.
Posted on Nov 28, 2010
Nov 27, 2010 | Ryobi Garden
Ryobi weedeater 4 stroke starts but only runs for a second or so I can get it to run but not well and I have to have some choke on to do it
Jun 02, 2010 | Ryobi Garden
Probglem:Machine would run for 15-20 seconds and
i had a similar problem last year. finally took it to a repair shop..they replaced the diaphram under warranty. seems to be ok now, though i am not overly impressed with this machine
Mar 17, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How is the clutch rotor assembly removed from a ryobi 720r trimmer
on my 767r there are 4 cap head screws on a funnel shaped piece that connects the shaft to the engine. Once removed you'll have access to the clutch
Aug 21, 2009 | Ryobi Garden
Aug 01, 2009 | Ryobi Garden
Replacing fuel lines on ryobi 767r trimmer
Jim
Jul 03, 2009 | Ryobi Garden
Stihl weed eater runs 2min. then stop
Stihl weedeater was running and stopped suddenly. Put in a new fuel filter and cleaner air filter with soap and water. Checked spark plug and it appeared fine. Started the weedeater, ran for a second or so and stopped. Spark plug wasn't gas fouled. Could it be the carburetor needing new diaphram gasket and spring.
Apr 23, 2009 | Ryobi Garden
Ryobi 725r 31cc
Ryobi is Japanese for "Piece of ****" My suggestion is to throw it out!
My 767r has had fuel line and carb trouble from day one. I'll never buy another Ryobi or Craftsman tool again.
Jun 13, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
434 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
