Question about Hunter Electrical All-Weather 3/4'' Round, 48'' Extension Downrod - DR-48 AW Fan
Usha table fan winding connection
I have one usha table fan .I removed the winding .I have done new windingbut i do not know how to give connection to that winding.
we are using ac 240 volts.that winding has a 4 plus 4 coil set.plaese give idia to connection.
2 Suggested Answers
  • 8404 Answers
SOURCE: What is the correct schematic of any stand fan winding?
If you cut the coil ... your chance of actually making a repair are very limited. If you are skilled at using a volt/ohm meter, you can probably tell which one goes to which one ... actually making the solder or cold repair and getting it back into an enclosure will be difficult.
You can check the individual pieces of the wire using the ohm part of your meter checking contunity.
Posted on May 02, 2010
How give turns of the usha padastal hyspeed fans coil rewinding
The only time that I have rewound a transformer, I measured the length of coils when they were unwound as opposed to knowing the number of turns.
Jul 18, 2015 | Garden
My fan motor is not working totaly
PROBLEM; My fan motor is not working totally!
So, i guess that your fan motor is working partially
because it is not working totally.
Please try to be more vague, if you posibably can be.
You will loose 10 points if you actually give any one an idea of what could be wrong with your fan.---ha-ha! sorry,it just seemed too funny to me.
Sounds like:----option #1------- your fan motor is either not running at proscribed speed (fer instance, high is not high enough or low is too low.) This is usually caused by lack of oil on the fan motor bearings.,easy to oil the bearings & dirt cheap too.
but could be caused by an almost burnt out fan motor.In that casethe Motor is not fixable, & needs 2 -B replaced, but dont bother to. It is cheaper to buy another fan at wal marts.
option #2
that portions of the 2 speed or 3 speed selector switch are not totally making contact.
or --option # 3, one of your motor windings could be burnt open.
So,let me start with --#3-- the worst case senarieo
Diagnostic proceedure for Dr. Fixit
You need to supply 120 volts ac in turn to winding lead #1, then to winding lead #2 and then to winding lead #3----
There are 4 wires on a 3 position fan speed switch.
1 wire for low speed,1 wire for medium speed and 1 wire for high speed. This looks like the letter Y with each leg of the Y
[ around the outside of the Y ] being one speed winding. THe neutral return wire would hook up to the center of the Y and this would give you your 3 circuits, depending on which outside leg
that the speed selector switch selects. lo,med or hi--- the neutral return wire at the center of the Y will compleate the circuit, one winding at a time ,depending on speed selector switch setting, for all 3 speeds.
All 3 speed windings need to work for the fan motor to work totally.
If one speed winding is burnt open, the fan motor will only work partially, 2/3rds ,that is. You can still use the fan by cutting off the lead of the bad speed winding and using the other 2 windings.
If 2 wings are bad and dont run, the fan will still work partially with only 1 speed.
If you have no-- or intermittant contact on your fan speed switch,
you will have to order a new replacement switch. This is assume-ing that all 3 speed windings worked properly at their respective speeds , when you tested them earlier , with the speed selector removed from the circuit for testing of the motor windings to see if they each work with the selector switch out of the circuit
If you know that all 3 speed windings run ok , with the selector switch cut out of the circuit, then you know that the speed selector switch is bad.
Firstly,unplug the fan from the electricity so that your hair does not stand up on end, which would surely be a shocking experience.
secondly,
remove the old speed selector switch, noting down on paper, what color wires go where and put the same color wires from the new switch back in the same place that that color wire of the old switch came off of.
(i know this sounds funny, but it really totally works.)
use electrical tape and/ or wire nuts to make electrical connections, if necessary.
With the new switch installed, the 2 or 3 fan motor speed settings will now totally all work.
most electric fans have steel rotor shafts with bronze bearings.
they "call" them oilite bearings,susposedly because the bronze bushing (it is really a bronze bushing) but called a bearing, is oil impregnanted and susposed to be good for the life of the fan.
that is only true if you expect the life of the fan to be ONLY 18 to 24 months which is the average time that the factory oil lasts.
the oil dries up the longer the fan runs and the shaft makes the bronze bushing begin to heat up due to increased friction and eventually wear the round bronze bushinhg egg shaped.
Try giving your bearings a good healthy squirt of sae 30 wieght oil from a zoom spout-- [pull out straw squeeze bottle refillable oiler.]
I recommend oiling both the front and real fan motor bearings once a month.
This is the most common cause of fan failure.
Because I oil my fans bearings once a month,I still have fans that run from 1940,1950,1960 and 1970. The 1940 GE fan lasted 70 years and is still running strong.
Some newer fans have chinese ball bearings , but the ball bearings also die prematurely from lack of needed oil.
Sometimes, you can pry off the bearing race cover to get oil into the bearing.
a good trick here is to use wd40 if you think you cant get sae 30 into the bearing.
wd40 is a n extreemly light wieght oil that penetrates very well
and gets into places where you think it wont get into .
You can totally wet up a fan motor with either
sae 30 or wd 40 or both without worrying about the electric
motor being harmed by the oil.
the oil,sae 30 or wd 40 wont hurt the motor.
On badly rusted and nearly siezed fan motor bushings , or any electric motor as well, I use first wd40 for penetration and then sae 30 for good long duty lubricatin.
You may have to keep squirting ioil in the motor for 1/2 hour and end up with a puddle of oil under the fan motor, but about 40 % of the time ,you can bring back to life what yo thought was a dead motor. Perserverance is required and faith that you can fix the motor. 40 % of the time you get sucess to one degree or another and 60 % of the time ,its kaput for good.
I got all those fans i mentioned before because other people thought the bearing were seized and shot, and put the fans in the garbage pail where I rescued the fans from.
the bearings were almost siezed but far from shot becaue i got oil in to the shafts and bearings and another 12 to 20 years of life from the fans. However,i do oil them monthly in fan season, which is winter time for me, since I use fans to blow the hot air off of my wood stove.
Oct 10, 2013 | Dryers
How saree edgimg can be done using usha janome wonderstich
saree edging prosuder usha wonder machine
Dec 31, 2011 | Sewing Machines
Wall fan remote control usha made not working
Did you repalce battery?Check first if the battery is good and the connection.Also claen the sensor of the remote and the unit.
Jul 13, 2011 | Dryers
Hello, please let me know whether I can get and fit an upgrade fan blower motor with higher ventilation capacity than the standard one ,in my Saab 900 year 1994 in order to get more passenger cooling...
As far as I know there is not one available. Seeing as the design of the actual fan is critical to the housing it would not be recommended to change it out with another fan. You may well get poorer performance What you can do however is remove the fan motor from its housing and get it to an armature winder than can modify/rewire the original fan motor to give a higher ouput. This is done by removing the old windings from the armature and using a thicker guage wire, rewiring the motor. Using stronger magnets for the field or replacing the permanent magnets with an electrmagnet type design. Unfotunately the only DIY part of this is you removing and reinstalling the unit. Rewiring is pretty specialised.
Aug 01, 2010 | Saab 900 Cars & Trucks
Why does a table fan slow down after some time?
Revolving blades in table fans pushes out air towards the front by creating a vacuum at the back of the induction motor. Other than providing air flow, the gush of air also cools the motor. Over time, esp if used in a polluted surrounding, dust collects inside the motor and causes friction in the shaft. If left for a prolonged period, this friction causes heat eventually drying up the lubrication, causing breakdown in the motor amature windings and also a leaky starting capacitor, thus slowing down rotation and also a complete failure.
2. Fans must be regularly taken apart, cleaned and lubricated. It is fairly easy if you are willing to learn. My India made Usha brand table fan is 48 years old and is still running smooth - just changed the start capacitor last year and my National ceiling fans are more than 35 years old.
3. In fact all moving parts in any equipment must be periodically taken apart, cleaned free of dust and grime and freshly lubricated. It will outrun your lifetime and serve the next few generations.
Best Regards,
Mahathev of Malaysia
May 29, 2010 | Cfm 802 Ecofan Table
Craftsman 10in Table Saw Model No. 315.218060 Dust bag
all the manual says is to insert the elbow onto the tube coming from motor and then install bag onto the elbow and for maximum performance empty the bag before it gets half full. On most table saws that I work on there is no fan or anything like that to force the dust away from unit, the best way is to run a shop vac and connect to the elbow for mazimum dust removal.
Mar 13, 2010 | Craftsman 10" Table Saw
Table saw starts slow and the stops
Sounds like the run capacitor has given up. Or, maybe the worst is it overheated and burned the motor winding. You'll probably have to take it apart. If there is a smoked capacitor, that's probably the one you should replace. If the winding is scorched, might as well get a new motor. If both are the case, then replace the capacitor before you give up on the winding.
Apr 21, 2009 | Saws
Dryers Logo
2,192 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
