Question about LG 42LC2D 42 in. LCD HDTV
Image shattered/double when moving.
When I see my tv, the image of person in tv is look double or triple when the person move. I just bought 1 month ago.
    Problem Solver:
  • 15 Answers
Check your antenna connection and auto-reprogram the channels.
Posted on Apr 27, 2010
My LCD HGTV flatscreen was bumped up against something when moved, now has shatter like image on screen, glass itself not broken...can it be repaired?
No, the display panel which is very fragile is now damaged and the part will cost more that the set did or a new one will cost to replace this one.
Aug 30, 2012 | LG Televison & Video
Pionreer 64" hdtv, I think
Bad Convergence ICs they are Big Black ICs and will have the part number on them STK392-110
Mats has ICs $10.95 each 1-800-628-1118 In back of TV look on Board Located on Left hand side thats where you will find the ICs.
Jul 30, 2011 | Pioneer PRO-730HD 64" Rear Projection...
You can see the red blue and green lines on my tv it is like it is out of sync
I'm not sure what you mean by the "lines". If you mean the image looks like "double" (or triple!) vision, then you need to adjust the red/green/blue convergence. This is especially noticeable with white images on dark background (like text of credits). If this is it, check you manual or explore your menu via the remote. Sometimes convergence can be a problem if the tv was moved or experienced large changes in temperature... or sometimes all by itself!
Jan 22, 2011 | RCA D61W20 61" Rear Projection Television
Double images and no owners manual
First try going into the customer menu of the TV. Look for the convergence alignment parameter and see if you can move the images back into place.
If you can't move the images back together, this is a failure of the convergence circuit in the TV. The convergence output ICs will need replacement and the TV should then be re-aligned. Look for a service center that is factory authorized. Expect to spend $350-$500 to have this issue resolved.
michtech
Feb 14, 2009 | Zenith R57W46 57" Rear Projection...
DOUBLE IMAGES
there is a problem with tthe convergence section this is something a tech can do
Sep 23, 2008 | Toshiba TZ50V51 50" Rear Projection...
ALOT OF BLUE ON THE SCREEN!!
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Aug 20, 2008 | Philips 60PP9200D Television
Moved Sony Bravia TV, now will not turn on at all
The warranty on this set should be for 1 year. Return it for warranty service. Unless the set was dropped, moving it should not have effected anything. DO NOT open the set sas that would void the warranty.
Dan
Jun 11, 2008 | Sony BRAVIA KDL52XBR2 Television
Sony KP-57WS500
the unit needs the convergence ic's replaced and probably a couple of safety resistors.average repaire are about 300 from a tv shop
Mar 04, 2007 | Sony KP-57WS500 57" Rear Projection...
LG 42LC2D 42 in. LCD HDTV Logo
298 people viewed this question
Computer Repairing
Computer Repairing
