Question about Cameras
Camera card error
I have a SD HC 2GB memory card for my camera. The camera works fine with another memory card, but when I put this one in it comes up with ''Card error''.
Is there anyway to fix it, or anywhere in the ACT where I can take it to get fixed?
Thanks
  • 1,606 Answers
Basically you can format the card using the camera or a computer which may get it working again or just replace it with a new one. A 2gb card is fairly inexpensive to replace.
Posted on Apr 27, 2010
The screen say's memory card error, card locked, but it is a brand new card. I unlocked it and it still says error
I think you have a HC card, Any SD memory card about 2GB runs at a different compression rate to the 'normal' SD cards. ie High Compression. If you do have a larger card in an older camera it will not read, The camera cannot access the information, and it will not work. If it's a 2GB or smaller, try formatting the card - Go to your review menu, press setup and chose format from the list. This should sort it out.
Jul 25, 2010 | Canon PowerShot SD600 Digital Camera
Will my canon ixus 60 take a 16gb memory card
Yes. The IXUS 60 was designed to work with SD cards. Cards larger than 2GB are actually SDHC (the HC stands for High Capacity) and will not work in this camera.
Jul 12, 2010 | Canon Cameras
Put new optima sd hc memory card in screen says memory card error
Sorry but the A400 was designed well before the SDHC format came out. Your camera can only use standard SD cards (2GB or less).
May 05, 2010 | Canon PowerShot A400 Digital Camera
New digital memory card inserted and camara reads memory card error
1. Try to format your memory card using a PC/Laptop.
2. Now, insert it in camera and check whether its working!
please rate this advice if it helps....tc! :)
Jan 02, 2010 | Canon PowerShot A530 Digital Camera
Just put in new san disk 4gb memory card and receiving error message - memory card error. I unlocked memory on card itself (that little gray sliver that goes up and down) What gives
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Dec 21, 2009 | Canon PowerShot A610 Digital Camera
Inserted new memory card error message:memory card error unable to access format under menu
I'm guessing that you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
Nov 07, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Hi,just bought a 4gb sd card for my digimax s600 but it won,t work.when i switch on camera, screen says..format..yes.confirm ok.when i do this i get check sd card . i put in old card it works fine??..
Does your camera support SD HC? Anything above a 2gb SD card is concider a HC; so if your camera can't support HC format then you can not use that card.
Sep 09, 2009 | Samsung Digimax S600 Digital Camera
My Powershot 450sd camera is not reading 4GB SDHC
Apparently IXUS 55 is not compatible with a 4GB SD card. Use a 2GB and you would be fine.
Dec 29, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
Panasonic fz 18
Sorry for the extreme delay in answering your question: I've been trawling for old unanswered questions today and yours came up. The following answer will undoubtedly be way too late to be of use to you, but may assist others searching FixYa for an answer to the same problem.
You have been mistaking SD cards for SDHC cards. They look the same but are different, and your camera cannot use SDHC cards as it was designed before they existed. The limitation is due to the hardware in your camera so it cannot be updated to SDHC standards.
Your 2GB card was definitely an SD card as SDHC cards have a minimum capacity of 4GB, and 2GB SD cards are the maximum capacity which your camera can handle. Your only fix is to either stick to 2GB maximum capacity SD cards or to replace the camera with one which is SDHC compatible.
Aug 25, 2008 | Panasonic Lumix DMC-FZ18K Digital Camera
Using SD HC Memory Card with HP R927 camera
No. The R927 is limited to SD cards 2GB and smaller.
Aug 25, 2008 | HP Photosmart R927 Digital Camera
Cameras Logo
44 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
