Question about Zanussi FS1455W Front Load Washer
Simpson ezi loader washing machine clicks 3 times then the end button lights up without even starting the cycle. does anyone have a solution for this?Solve this problem 1 2 3 4 5 6 7 This is a... Solution Clarification Request Post It Simpson ezy loader when you press the start button, it clicks three times and goes to the end of cycle
  • Anonymous Mar 16, 2014
    the machine does not start when i press the start button but instead it clicks 3 time
  • 269 Answers
It sounds like a door switch fault see if the end light and the start/pause light are flashing count the flashes if end flashes 4 times and the start/pause once or maybe more this could be error 41, door switch fault.A door switch would cost about $ 20 but there may still be a problem with the main Programmer.
Good luck.
Posted on May 03, 2010
Same thing with mine , pulled appart switch and contacts burned out , traced red cables from switch back to control board to find track blown appart just below where it plugs in. Soldered a link and replaced door switch for $75 including delivery and all good now.
Posted on Dec 16, 2011
    New Friend:
Simply push on the door hard until the cycle begins.
The vacuum of the rubber seal thingy needs to be tight.
Posted on Apr 14, 2014
I have the same issue with mine
Posted on May 09, 2010
  • davethesp21 Oct 04, 2010
    Same problem, but end light flashes 4 times, pauses then repeats, no other leds light up.
    Does anyone know what this error code is?
  • Dave Zwar Dec 16, 2011
Manual for Simpson Ezi sensor front loader washing machine
Try Googling (simpson)(model)(manual) without parens.
Jul 11, 2017 | Simpson Washing Machines
I have a Simpson ezi set 9.5 kg washing machine.It has stopped in the middle of a wash and the LCD screen I showing EFO.Can you tell me what this means and what I need to do to get machine to finish...
i have a 9.5kg simpson washing machine just 5months old and ive had this problem E20 quite frequently that its annoying. I printed out a manual and foundout why. i do not have the patience to remove draining hose im sure there is a simplier way. Ive notice if i tap the side of machine 3 to 5 times it drains lol! seriously never had a problem with my old 7.5kg hoover machine, please help
Jun 19, 2013 | Washing Machines
Simpson Ezi Sensor Front Loader keeps pausing during washes, doesn't put through the detergent.
you might be putting the detergent in the wrong part of the dispenser,or you might have the hose on the wrong way,or the water valve has failed. Read up on your user manual to see what happens on this part of the cycle,does the w/m empty ,then try and bring in more water?? The main give away to this fault is,detergent still in the dispenser.Check all your filters on your inlet hose and water valves.
You have to ask yourself what has changed,cheers.
Aug 14, 2012 | Simpson Washing Machines
My simpson ezi sensor wont agitate
hi just read your posting.Does the machine spin and drain?Please reply with answer and I can help you further.
Jul 14, 2012 | Simpson Washing Machines
Simpson ezi loader 5.5kg front loader. when it goes to start the door clicks 3 times then the end light flashes. I am an electrician. but I do not work on appliances. if you could send me a...
the door is clicking because it is trying to lock the door but is unable to for some reason what is the make/ model number of the machine? most likely it would be something dealing with the door look but id rather be 100 percent correct then assuming Please send model number i await your reply Thanks again
Rick
Dec 09, 2010 | Washing Machines
Hey there.. our power went out on the circuit holding the washing machine and now it wont start a cycle. the lights are on and the start button is flashing but it wont start when pressed.. simpson ezi...
unplug the machine for about 15 minutes to reset it. after that plug it back in that should have reset it and allow it to function properly
Feb 28, 2010 | Washing Machines
Simpson front loader washing machine repair person
I have Simpson EZI sensor 9.5kg and during the washing i have a EF message coming up.
Dec 21, 2009 | Washing Machines
EZI Sensor is unbalanced on every load
Problem now solved, Simpson solved it by informing me that this machine comes with 4 transit straps on the bottom of the bowl to the adjustable feet. Its not stated anywhere on the material supplied.
Dec 16, 2009 | Electrolux Washing Machines
Simpson front loader won't power up !
that wa the first thing that came to my mind i think your on the right track call a service department give them the make model number of the washer they should be able to help you locate a reset switch if it has one . good luck
Jun 22, 2009 | Washing Machines
Zanussi FS1455W Front Load Washer Logo
1,119 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
