Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Help i have a whirlpool cabrio and f 51 keep poping up what do that mean
  • 299 Answers
F then 51 flashes when there is a motor rotor position sensor (RPS) failure.
It can also be a defective control board false reporting an error which is common on these models.
Posted on Apr 27, 2010
F#code keeps flashing on washer did what manual says to do but nothing changes can you help
The "F1" error code on a Whirlpool Cabrio washer means that the machine control assembly has failed and you must replace it. Order a new assembly from a Whirlpool parts dealer. The "F2" troubles code means that a key on the user interface or keypad is stuck. Look at each key and try to unstick it. Always hit the "Pause/Cancel" button to try and erase the error code. Try restarting the load.
Oct 18, 2014 | Whirlpool Washing Machines
Cabrio washing machine wont finish spin cycle and comes up with a code blinking F 51. how do i fix this problem I cant finish one load of laundry, without this cod F 51 poping up. thank you wendy
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit. This can be caused by several different problems.
Make sure that you are not overloading the washer. Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation.
With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily. If not, you could an item caught between the spin basket and the tub.
You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board. A failed RPS sensor or a failed control board could also cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 19, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer stops and F 51 flashs
Hello, It is a rotor position sensor code. The control is no longer receiving a signal from the motor. It can be a failed sensor or control, but usually it is a bad connection where the wires plug on to the sensor.
Thanks
Jun 11, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio W10106470 has an F51 code. What
F51 error is a rotor position sensor error, two parts really need to be replaced. 1) the rotor sensor itself ($43) and 2) the control board ($197)
Jun 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F-51 code on Cabrio Washer
usually this means you have a bad rps sensor that is attached to your motor. when you lifted the lid you should have seen the tech sheet it is attached inside the cabinet in the front. this should help you. the rps sensor has i believe 3 wires attached to it with a quick disconnect. let me know if this helps.
Jun 21, 2009 | Whirlpool Cabrio WTW6600SBK
F-51 code
Contact Whirlpool as they will now fix this on a special repair program--RPS sensor and wire harness replacement
Feb 10, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio dryer
af on your cabrio dryer means clean your air filter
Dec 14, 2008 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
Whirlpool Cabrio W10112999
http://www.theworldofwashers.com/2007/06/cabriooasis-f51-error-codes.html
F then 50 flashes when the motor rotor position sensor (RPS)
senses no rotation.
➔ Does basket turn freely? If not, determine cause of friction.
➔ If basket turns freely, see TEST #3, Page 10.
the above link is for code 51, very similar. the quite above is from the PDF manual. I just solved this problem on my machine. turned out it was clothing between the 2 baskets. Others have had bad control boards, or bad sensors
Oct 23, 2008 | Whirlpool Cabrio WTW6600SBK
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
182 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
