Question about Dell 1703FPs 17" TFT LCD Flat Panel Monitor
Menu Lock - Dell 1703FPs 17" TFT LCD Flat Panel Monitor
  • 11,361 Answers
Radio locked cant adjust
Can you hit
MENU (opens the menu)
24 and MENU (opens menu item 24, Auto-lock)
0 and MENU (sets auto-lock off and confirms)
EXIT
Auto-Lock locks up the keyboard to prevent accidental frequency changes. It allows for transmission with the PTT.
Jan 11, 2014 | Baofeng UV-5RA Dual Band Transceiver
Tip
LG mobiles Test Menu, secret codes and tricks
Here are some common codes for LG cellular phones and there use. Use these codes at your own risk and note that these codes may or may not work depending on your phone model.
Following are the codes:
LG all models test mode: Type 2945#*# on the main screen.
2945*#01*# Secret menu for LG
IMEI (ALL): *#06#
IMEI and SW (LG 510): *#07#
Software version (LG B1200): *8375#
Recount cheksum (LG B1200): *6861#
Factory test (B1200): #PWR 668
Sim lock menu (LG B1200): 1945#*5101#
Sim lock menu (LG 510W, 5200): 2945#*5101#
Sim lock menu (LG 7020, 7010): 2945#*70001#
Sim lock menu (LG 500, 600): 2947#*
LG-U81XX SPECIAL CODES
Code to read phone version :
- Phone without SIM
- Enter 277634#*# or 47328545454#
- Select ‘SW Ver.info’
Code to reset phone :
- Phone without SIM
- Select ‘Factory Reset’
Code to enter UNLOCK MENU :
- Phone wit SIM inside
- Enter 2945#*88110#
Test Menu 8330 : 637664#*#
Test Menu 8180 V10a: 49857465454#
Test Menu 8180 V11a: 492662464663#
Test Menu 8130-8138: 47328545454#
Test Menu 8110-8120: 277634#*#
on Aug 05, 2010 | Cell Phones
Ihave an view sonic E70fb moniter. and am having problem with osd lock. osd lock strip often and often see in my moniter screen. and i coulden't solve this problem. so, please give me the solution as...
· The OSD Lock Out Message
Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
· 2
Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
· 3
Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
· 4
Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
· 5
The OSD Settings Menu
Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out
Jul 22, 2011 | ViewSonic E70f 17" CRT Monitor
I don't know how to lock it
Hi there! here's how you can do that. Hope it helps. :)
Security Settings
All of your phone's security settings are available through the Security or Restrict and Lock menu.
Accessing the Security Menu
1. Press > Settings > More... > Security.
2. Enter your lock code to display the Security menu.
Accessing the Restrict and Lock Menu
© Press > Settings > More... > Restrict and Lock.
Apr 20, 2011 | Sanyo SCP-2700 Cell Phone
My HP 1730 monitor is showing "OSD Lock Out" message. How can I remove this msg?
The following site has step by step instructions on steps you can try: http://www.ehow.com/how_5008634_fix-lockout-display-computer-monitor.html
I'll paste them below: All computer monitors, whether they are LCD or CRT style, have a built-in feature called the on screen display (OSD) lock out that prevents users from viewing any images on the monitor. If your computer screen has accidentally been set to the OSD lock out setting, there are several different ways you can remove the lock out, depending on the make and model of your particular computer monitor.
1 Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
2 Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
3 Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
4 Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
5 Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out.
Mar 01, 2011 | HP 1730 LCD Monitor
How can i lock my pictures
Feb 28, 2011 | Sanyo SCP-2700 Cell Phone
How to remove child locks
If you have lost or forgotten the code, the default factory password is 0000. This should still work even if you have set another password and forgotten. You should also deactivate the lock fully from the menu if you no longer wish to use it or activated it accidentally.
Disabling the child lock (and/or other locks):
(This can be done from the remote or the buttons on the front of the TV)
1. Press MENU to open the main menu.
2. Press CH+ or CH- to highlight PREFERENCES.
3. Press OK to enter the PREFERENCES menu.
4. Press CH+ or CH- to highlight FPA Lock (Front Panel lock) .
5. Press VOL+ or VOL- to switch the lock on or off
6. Press MENU repeatedly to exit the menu
The menu will disappear if no buttons are pressed on the remote for several seconds.
Please let me know if you need further assistance.
Regards,
BElectric.
Jan 31, 2011 | RCA TruFlat 27F520T 27" TV
My hp 1740 monitor is displaying osd lockout and menu back ond forth and i cant get rid of it
  1. Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
  2. Step 2 Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
  3. Step 3 Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
  4. Step 4 Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
  5. Step 5 fix-lockout-display-computer-monitor-1.5-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep5 span.image a:first').attr('href','http://i.ehow.com/images/a04/or/7q/fix-lockout-display-computer-monitor-1.5-800X800.jpg'); }); The OSD Settings Menu Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out.
Apr 15, 2010 | HP L1740 17" LCD Monitor
How to watch dvd on a toshiba 20af43 without original remote control
To remove the video lock:
1. Press MENU, then press left or right to display the OPTION menu.
2. Press up or down to highlight LOCK.
3. Press left or right to display the LOCK menu.
4. Use the Channel Number buttons (0-9) to enter your PIN code,
then press ENTER. The LOCK menu appears.
5. Press up or down to highlight VIDEO LOCK.
6. Press left or right to select:
• OFF: Unlocks all video input sources.
Jan 05, 2010 | Toshiba 20AF43 20" TV
FPA Lock
After doing a little research, it looke like the front panel lock , can only be removed from the parental control menu using your remote. If your universal remote does not get you into the menu, see if you can borrow a friends rca remote long enough to get you into your menu & remove the fpa.
Nov 03, 2006 | RCA 14F512T 14" TV
Dell 1703FPs 17" TFT LCD Flat Panel Monitor Logo
mukhtar21 shaikh
mukhtar21 shaikh
