Question about Compaq ProLiant ML530 Server
Ml530 I have an old Compaq Ml530 Server and dont have a scsi hard disk i want to know when i install a ide harddisk it does not detect the disk
  • 3 Answers
You need to go into the bios setup and enable the ide controller and disable the scsi controller. Then, you need to re-boot before the bios can see the ide hard drive. Next, you configure the bios to boot from the cd/dvd drive first and the ide hard drive second.
Posted on Sep 19, 2012
  • 46 Answers
There are many configuration settings, although i personally would hunt down an SCSI hard disk, many will fit from many other models just like IDE ones
Posted on Mar 26, 2008
Hi: i have hp server ML 370 with array smart 642 controller and i replace hard drives to clean and check but when turn on the server get me many messages no scsi boot device found and next line scsi bios...
when did this beast last work.
see the manual yet>
there are many 370s ,which one, the full service tag answers that.
G , 2, on up. 9????????????
Proliant servers.
use google to find old manuals.
here is g2
https://www.manualshelf.com/manual/hp/hp-proliant-ml370-g2-server/compaq-proliant-ml370-g2-service-update.html
here is HP site covering retired products, I suspect your is..
https://www.hpe.com/h20195/v2/Library.aspx?doccompany=HPE&cc=us&lc=en&filter_status=rw#&doccompany-hpe&sortorder-csdisplayorder&teasers-off&searchword-Compaq%20ProLiant%20ML370&isRetired-false&isRHParentNode-false&titleCheck-true
HPE has the , 642 book here. (just a spec)
https://www.hpe.com/h20195/v2/GetDocument.aspx?docname=c04284123
if read that page it tells you the controller is only works with
SCSI
Compatibility with all Ultra320, Ultra3 and Ultra2 LVD family products.
it also tells you , it needs the HP utility tools to set it up properly
why would your clean disks boot? why say that?
what does this mean?
"and i replace hard drives to clean and check" surely you can elaborate the full story,
last run when?> what G number is it.
what drives , make and model. installed.
do you have the software setup seen on page 5 link just above.
quote
All Smart Array products share a common set of configuration, management and diagnostic tools,
including Array Configuration Utility, Array Diagnostic Utility (ADU), and Insight Manager.
this product is offically retired, by hp and only few books there.
but google finds many books, 15 years old now. (as old as...)
http://kmcs-service.austin.hp.com/km-ext/kmcsdirect/emr_na-c01127202-1.pdf
see this, it tells you what to do in 77 pages.
my guess is you get lost at Set the boot controller
(Chapter 4).
my guess, is that you have no HP sofware support kits.
just hardware there.... right?
next time tell the helper, full spec on 370 Gn G numer.
and full spec , on 642, version. and that you dont have the HP software kit to support this machine, it's no simple desktop, no at all.
at the least you get stuck here,
Create at least one logical drive, as described in Chapter 5.
Sep 25, 2017 | HP Compaq ProLiant ML530 Server
Configure & install two scsi disks scsi disks in ML 150 G2
The SCSI driver is required to installed during the initial boot up for installation when additional drivers are asked .the new models dont come with a Floppy drive so an external floppy drive can be used .The detection of HDD s must be at the startup by the Bios os SCSI card.
Feb 24, 2010 | HP ProLiant ML150 G2 Server
Connect ide or sata drives to a dell poweredge 2600 for additional storage
Yes and No..
The standard machine only allows SCSI, (no IDE or SATA or SAS connectors...
However SCSI drives are not cheap.. so
To overcome the power issue (you will notice there are no 4 pin molex connectors, or sata power connectors). However there is a 4 pin molex socket on the SCSI backplane. You can use one of those molex adaptor cables (one connector to many) to get power, from the molex you can use a 4 pin to SATA power connector.
Next step is to decide the drive you want to use. I personally use SCSI, SATA, SAS and IDE in mine (overkill I know).
Cheapness says use IDE or SATA. You can get a pci IDE/SATA controller card on ebay dirt cheap (PCI cards are compatible with the large PCIX slots), they dont take the entire "socket" up but they work (be carefull here, there is one 5v pci socket on these machines, and 6 pcix sockets, the pcix sockets will accept 3.3v pci cards (look at the notches).
Next you have to mount them, with a bit of jiggery pokery you can feed the IDE/SATA cables past the SCSI backplane into the hot swap bay. (If you dont have any empty caddy's pick them up off ebay), just remember you cant just pull em out like you can with the SCSI's!) - or use one of the 5 1/2 media bays.
Plud the other ends into the appropriate controller card (as installed in the PCI bus).
Load up the OS, install drivers (if needed - these should come with the pci card(s), use the disk manager to initialise/first format the drives etc.
All done.
I have done this myself running a 2600, with 2X U320 72gb SCSI (on Raid) 1 x IDE CD/DVDRW in Media bay, DAT 27 SCSI (channel B) in the second media bay. 2x 146gb SAS on a DELL SAS pcix card (in 2 of the hot swap bays) and an old 160gb IDE HDD (Funilly enough theres a bit towards the back of the two fans on the SCSI backplane that if you press the 3 1/2 drive against seems to fit perfectly in this place and stay there! (I think thats fluke to be honest).
All done :)
Jan 04, 2010 | Dell PowerEdge 2600 Server
Server XSeries 220
Yes, that is the total amount of hard drive space.
This server was built for speed not for storage.
The xSeries 220 server supports four SCSI hard disk drives. The server does not support IDE hard disk drives. Some models support hot-swap hard disk drives and other models support only non-hot-swap hard disk
drives.
Your server supports four 1-inch (26 mm) slim, 3.5-inch SCSI hard disk drives in the hard disk drive bays. You can install four non-hot-swap hard
disk drives in the models that have the standard non-hot-swap drive cage. You can install three hot-swap hard disk drives and one on-hot-swap hard disk drive in the models that come with the hot-swap drive cage. Both the non-hot-swap and hot-swap drive cages hold a maximum of three hard disk drives.
The calculation at that time was 4 drives with 36.7GB storage.
Even if you find the drives somewhere, they will be very pricy.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Oct 28, 2009 | IBM xSeries 220 (86451SF) Server
New install scsi hard disk no detect in ibm x3400 server
you will need to add the new drive to your array bbfore it will how up to be formated do this throught the array configuration util
Regards Al "alstech"
May 26, 2009 | IBM x3400 Server
SCSI hard disk is not detecting in IBM xSeries 346 Server
Hi
While running the windows 2003 setup (winnt.exe), it will ask for SASI driver, you have to add the scsi driver... then windows 2003 os will detect the HDD.. then it will install..
Apr 07, 2009 | IBM eServer xSeries 346
SCSI Devices not detected when posting ML530 Server.....
To get to the BIOS for your server, press F10 at start-up. This should get you there to verify if settings are detecting SCSI devices. If they are there, you may have to reinstall the SCSI controller drivers. Good Luck.
Jan 30, 2009 | HP Compaq ProLiant ML530 Server
Problem with scsi driver proliant ml 370 for NT4
Are you attempting to boot from the Windows CD?
If you are booting the server from a Windows installation disk and it is unable to detect the hard drive, this typically means the following things.
You need to provide the driver for the RAID controller of the server (this can vary, depending on the version of the ML370 e.g. G4/G5)
If it still cannot detect the hard drive after providing the driver for the RAID controller or if there is not a driver available for NT4, it may not support the controller.
In this case you can remove the RAID set by entering the RAID setup (could be LSI or adaptec). NOTE THIS WILL DESTROY ALL DATA ON THE DISKS THAT ARE A PART OF THIS RAID SET.
Dec 26, 2008 | HP Compaq ProLiant ML530 Server
Install xp in compaq presario c700
The hard disk may be set to Enhanced AHCI SATA mode. Look for Legacy or IDE mode setting in BIOS menu options.
XP SP2 does not recognise Enhanced SATA mode hard disks.
see http://www.mydigitallife.info/2007/10/23/windows-xp-setup-could-not-detect-and-find-any-sata-hard-disk-drive-on-ahci-mode/
You may be able to use NLite to make a CD which has correct SATA drivers.
Nov 23, 2008 | Computers & Internet
Compaq ProLiant ML530 Server Logo
304 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
