Question about Panasonic PT-60LC14 60" Rear Projection HDTV
Panasonic PT60LC14..Blue box pops up that the air filter needs cleaning and the tv automatically shuts off after 1 minute
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. “Air filter cleaning” in your set is something that should not be done by a normal user as it requires to remove the light engine assembly. It can only be done by someone who has good knowledge of the internal circuitry of the TV and probably also owns a service/repair manual. If you still want to clean it then you can access the filter from the front of the unit then pull off the cover, remove the 4 screws in the center and remove the door. There are usually two sides to the filter out of which the top side should be vacuumed and the bottom side the dust should be blown. However, as I said it is not recommended to be tried at home. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Apr 28, 2010
  • 2,335 Answers
This is a sign that your TV needs servicing.
The proper way to clean the air filter is to remove the light engine assembly and access. This requires a qualified service tech or at the very least someone with some good electrical repair knowledge and a service manual. It is not recommended that this be tried at home.
That being said, I have heard that supposedly you can access the filter from the front of the unit but I have not tried this myself:
  1. Pull off the cover (it unsnaps).
  2. Remove the 4 screws in the center and remove the door (not the lamp door).
  3. There are two sides to the filter, vacuum the top side, and use canned air to blow out the bottom side.
That said for DIY-er benefit, I really can't recommend blowing dust around inside an HDTV, and really do recommend a service tech do this maintenance for you to avoid further trouble with your TV.
I hope that helps.
_______________________________________
Panasonic PT60LC14 Manual Download
Posted on Apr 27, 2010
Where is the air filter on a Panasonic PT-52LCX65 Projection TV
THE AIR FILTERS ARE INSIDE THE ENGINE YOU MUST TAKE APART MANY PIECES LET A REPAIR CENTER DO THIS!!
Apr 25, 2010 | Panasonic PT-52LCX65 44" HDTV
Panasonic tv says i need air filter cleaning then shuts off after 1 minute any ideas?
Your TV manual should have the filter cleaning replacement procedure in the manual. Mine does. Otherwise what model do you have so I can get the procedure to you ?
Feb 28, 2010 | Televison & Video
Panasonic pt-61LCX65 osd air filter cleaning came on screen and the unit shut down in 1 minute. I would like to know exactly where the air filter is where I can clean it myself.
This is stright from Panasonic.
The consumer is not able to change the air filter. It will have to be done by an
authorized Panasonic service center."
Jan 22, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
A message keeps popping up saying I need to clean the air filter then the tv shuts off on it's own. It's a panasonic 60 inch projection
there is a louvered air intake panel on either lower side of tv. there is 1 or 2 screws the filter is right behind that panel.. take it out and clean it with warm dishsoapy water and pat dry on a flat surface with paper towels then reinstall. your th will not come on till the panel is screwed back into place. there is a microswitch type sensor that makes sure that the screws are in place...goodday
Nov 13, 2009 | Panasonic PT-60LCX64 Television
OSD Message Panasonic PT-50LC14 Air Filter Needs Cleaning
I had the same problem and the stupid tv would shut off after 1 minute. We opened the silver front panel , took the bulb out cleaned it, took the cover off the grey box to the right and very carefully vaccumed the filter and wiped it off with a microfiber cloth. It works great now!!! Make sure you unplug your tv before messing with it.
Sep 28, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Pt-52lcx66-k multimedia projection hdtv - air filter needs cleaning
Good Day,
It sounds like your lamp sensor is defective. Change it and it should correct your concerns. I hope this helpful.
Jun 11, 2008 | Panasonic PT-52LCX66 Projection Television
Where is the air filter on my Panasonic PT50LCX64 TV and how can I clean it?
I have the same problem!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 05, 2008 | Panasonic Televison & Video
Reset lamp meter on Panasonic PT-43LC14 television
While TV is on, simultaneously press and hold both the TV's Volume Down button and the remote's PP/Play button for 7 seconds.
Jun 03, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic PT-60LC14 60" Rear Projection HDTV Logo
133 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
