Fujitsu E8410 Notebook will not power on. I know battery and external PSU are ok. I need to know if this is a System board failure. New Systemboard from Fujitsu is about $600 AUD
    President:
  • 1,768 Answers
You could possible have a bad micro switch.
Contacts could have worn and needs replacement.
Posted on Apr 27, 2010
The system charger broke and I cant fix it
If the external PSU broke you will need to replace that. Be careful over what type you use as they depend on what type of battery you have (Li-ion or NiMH). Also use the right voltage with enough amps and the correct connector.
How ever if you are saying something internal id not working (eg battery not charging but system is working when PSU is plugged in and has power from the PSU) then some components on your m/b have become defective. Replace the m/b which you can do yourself if you have the appropriate level of technical ability or else take to a good or authenticated repairer. There are bound to be guides on the internet/youtube.
13.Apil.2015
Apr 10, 2015 | Easy 5200mAh 11.1V Notebook Battery for...
Is there a protection mode for this lcd visio tv that can be removed for this tv to come on ?
Hello Donald the first thing I would like to Know what the model number of your TV is. But that's ok if you have a external power supply you could try this .Make Shure your TV is not pug In to the Ac outlet. We are going to see if you have a short or a load on your 12v line. Ok you wont to unplug the 12v source from the power supply board. Fine out what pin is the 12v's. Connect your external power source to that pin, apply the 12v and see if it is drawing to much current. If so check the boards for any very hot items. If you have a problem on the 12v line. This will find the part that is loading it down. This is the old way of finding a load on a power source. I hope this will help some. P.S make Shure there is no AC connect to the TV as you do this test and you have the plug off of the power supply board before using the external power source.
Jan 01, 2015 | Televison & Video
Mouse doesn't work.
  1. go on eBay and order a new touch pad enter computer and model number and touch pad
Apr 04, 2014 | Fujitsu Siemens Fujitsu LIFEBOOK...
E8410 keyboard removal
Remove the power cord, remove the battery, turn the laptop over and remove any screws you see inside the battery compartment. Also look on the bottom and in the battery case for any keys that might have the icon of a keyboard beside them (they hold the keyboard in place). You might have to remove all the screws from the bottom case if the laptop's design does not have a separate strip that sits above the keyboard. Once you have the screws remove, turn the laptop over and open the lid. If there laptop has a strip above the keyboard, then pry it off gently because a cable might be under it. If it does not have a strip, but is all one big piece called the palmrest that surrounds the keyboard, then the keyboard might have little catches on the sides and at the top that you can move and wiggle the keyboard out. if not you will have to remove the palmrest. Also if you have the strip above the keyboard, once you remove it you might see screws that hold the keyboard then remove them.
Be careful when you lift the keyboard out, there is a cable under it that has to be removed from the board.
May 13, 2012 | Fujitsu LifeBook E8410 Notebook...
Audio driver
You can download the driver from this link: http://ts.fujitsu.com/support/downloads.html
On the left side of the page there is a link "Driver & downloads". Click on it, then on the middle area of the page, under "SELECT PRODUCT" you will select "Notebooks". A new menu appears, select "LIFEBOOK". A new menu appears, select "LIFEBOOK E". A new menu appears, select "LIFEBOOK E8410 (Intel Graphic)" or "LIFEBOOK E8410 (Intel Graphic)". (Makes no difference, since the audio card is the same ALC262 in both versions). After this, there appears a list with operating systems available. Select the one you are using, then select "Audio".
I would suggest to install first the "Chipset" driver from the same list, then restart the computer and after restart install the audio driver.
Best regards
Jun 28, 2011 | Fujitsu LifeBook E8410 Notebook - Intel...
The power button is on but no display is shown
u should take ur laptop to the service center. to turn off the power button plug-out ur battery from lptop.
Sep 01, 2009 | Dell Inspiron 1545 Notebook
Display problems at Boot Up (Windows PC)
my problem hp 530 notebook lcd light problem ..inverter flex no problem systemboard problem yes
Dec 18, 2008 | Gateway 7330GZ Notebook
Power failure,
you may have a blown power adapter board
Apr 27, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
My fujitsu lifebook e7010 doesnt always turn on properly
If an external monitor is plugged in an the display is ok then the problem is probably an inverter board or bad/loose flex cable to the lcd screen.
If the external display is distorted then the problem is the video adapter on the laptop.
Mar 31, 2008 | Fujitsu LifeBook E7010 Notebook
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
