Question about Boating
Water does not come out of the port hole all of the time.
I think my water pump on Evenrude 8 HP 4 stroke outboard engine isbad. I want to know where the water pump is located and if I can fix or replace it myself. Sometimes water comes out of the port hole and sometimes it doesn't.
1996 Evenrude 8 HP 4 stroke outboard engine, model E8FRLEUR97, serial # H 09365678,
    Top Expert:
  • 46,438 Answers
You might just have dirt in the water view port try a real smal drill bit BY HAND to clean the hole . if the morot doesn't run hot then you really don't have a problem
Posted on Apr 27, 2010
Why is my yamaha 2003 4 stroke 40 hp seem to be seized only 400 hr ran fine last time 3 weeks ago
Water pumps fail sooner from non use than using them all the time.13 years is a rather old unit
Oct 19, 2016 | Yamaha 40N/50N 40 and 50 HP Outboard Motor...
Water got into the engine oil of my 8 hp 4 stroke when on the boat only as troller
Water gets in your engine through the exhaust with the boat speed! Lift that engine when not in use!
Oct 16, 2014 | Mercury Marine 8hp & 9.9hp 4 Stroke...
Mercury outboard problems
Is this a two stroke?-If it is you most likely have a primary seal going bad (crankcase seal on the ignition side will lean it out,leaking seal on the other-side of assembly will do just what your describing)Hope this helps you out.....
Aug 07, 2014 | Mercury 4-Stroke 3.5 HP Outboard, Manual,...
How to install a evenrude outboard water pump
the exhaust ports start from the side of the engine block 2hp -90hp then v4 and v6 and v8 are between the v blocks ! from there they go down the leg unit , top rear of leg have an outlet for tickover then the main outlet is either through the prop or above it on small or old type engines !
May 09, 2014 | Boating
1982 55 yamaha outboard ,water not coming out the water pump hole in strenght
First thing to check: Disconnect the tiny hose between the check outlet and the engine. Disconnect it at the engine side.
With an airgun, blow in the check hole from outside to engine side.
With an airgun, blow out the engine connection.
Start the engine, check waterflow out of the engine connector. If water, reconnect the hose and check the water at the checkpoint.
If still no water at the engine connection: replace the impeller!
Mar 28, 2013 | Clymer Marine Maintenance and Repair...
My Yamaha 4 stroke 50hp engine was running fine. When i went to replace the cover, the water stopped running through the "pee" hole.
i have had this on mine and it was a sort of insect that made a mud nest in the small hole and it blocked the hole up ,try poking it out with a bit of wire
Jun 24, 2011 | Clymer Marine Maintenance and Repair...
Where is pee hole on 1980 Mercury 4 HP 2cyl 2 stroke
Hey I just got the same motor and actually have the same exact concerns. Have you found any answers?
Aug 30, 2009 | Boating
Boating Logo
208 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
