Question about Panasonic TOUGHBOOK CF-18 Tablet PC
Toughbook cf-18 cannot boot thru window. it come out with a start using safemode, then go into window , then blue screen with "a problem has been detected and windows has been shut down to prevent damage to your computer". 1. how do i solve this problem. 2. how to make a bootable tump drive by copying window xp from a cd thru my desktop. this cf 18 donot have a cd drive. thanks in advance kc eng / malaysia
    President:
  • 1,768 Answers
Yu possibly have a virus
You will need to format the hard drive and reload Windows if this doesn't work you will need a new hard drive.
Try to "defragment the hard drive 1st. check the disk for errors.
Posted on Apr 27, 2010
Panasonic toughbook cf-74 blue error screen loop
Which OS do you have? Have you tried booting to safe mode?. Restart the computer. Immediately after the BIOS post ends, start tapping the F8 key repeatedly. when Windows Advanced Options menu appears, select safe mode and see whether it boots completely without blue screen(BSOD)
Apr 22, 2014 | Tablets & eReaders
Bought used toughbook on ebay, no hard drive or OS. using my old hard drive from broken one. get to bios screen, but will not boot up into windows. I'm guessing some drivers may be jacking me up, how do I...
reformat the had drive and install a fresh copy of OS from the compact disc.... once the installation is complete, boot up the computer again... if it works, then every thing is perfect....you can go ahead and install the drivers for your devices in the compter...
please clarify if you have any further troubles in installing the OS in your computer...
May 07, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic TOUGHBOOK CF-18 Took out HD to reload windows as it would not load but stuck at the safe / last known good config etc. Loaded XP onto HD via an ACER laptop and reinserted it into ToughBook -...
I think your actually having issues getting it to run on the toughbook because it uses different drivers for everything from the Acer computer. If you press F8 while booting up you can choose the option "Disable automatic restart (of system errors or something)". Then when the machine boots up you should get a blue screen giving you an error code like "IRQ_EQUAL_TO_OR_GREATER_X Error: 0x0000005f. You could try to see what the message is trying to tell you to resolve it but the error msg would likely point to the driver that its trying to load that's most likely different from the toughbook you have. I'd suggest getting an external cdrom/dvdrom and install windows from a disc onto the toughbooks hd while its in that toughbook machine.
Dec 21, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
HOW TO INSTALL WINDONS XP PRO ON TOUGHBOOK CF-18
XP can not be installed from usb as the bios does not enable it. Plug the ide hard drive into an older desktop system and install from boot on cd. Once all files are copied over then you need to copy the i386 folder over from the cd. Reinstall the hard drive into the toughbook and carry on the install from there.
Jun 09, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic cf 18b toughbook,touch screen do not work,help
goto your device manager and then find your display driver and update it. Dont search for it, manually locate the driver being in the location where you extracted the driver. Then update. and bingo!
Feb 18, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Trouble booting!
You could attempt to boot to safe mode, and run the Start> System Recovery > PC Recovery Application.
Otherwise, I'd boot to safe mode, select start, run, type: msconfig, select the startup tab, remove any unwanted startup items that may be causing the system crash.
Hope this helps.
Jan 08, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
NUM Lock
I solved this on a toughbook. The numlock was activating while windows started even with the regkey set to have it off.
(http://support.microsoft.com/kb/154529/en-us)
All I had to do was restarting the PC waiting for windows to activate the numlock again during the shutdown process and then hitting the numlock once before windows was done.
Next time the Toughbook started the Numlock kept off!
Aug 12, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic CF-18 screens
Maybe you should try re-installing the drivers.
Here's a link
Jun 16, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic TOUGHBOOK CF-18 Tablet PC Logo
537 people viewed this question
Top Panasonic Tablets & eReaders Experts
Paul Wang
Mike
Are you a Panasonic Tablet and eReader Expert? Answer questions, earn points and help others
