Question about Whirlpool AWM6141/1 Front Load Washer
Drum is spinning uncontrollably no matter what setting, has been turned off then turned back on & still the same. No water going into drum instead going onto the floor.
  • Whirlpool Master
  • 43,501 Answers
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Posted on Apr 28, 2010
Hi, I own a Whirlpool Thin Twin Model# LT5000XSN1. I bought it used from a CRAPPY dealer (worst mistake EVER), since day one, we have had an issue with the spin cycle. The cycle will agitate then when the...
This sounds like a classic clogged empty pump issue. The empty cycle is timed and then it steps on to the spin cycle. The machine won't spin if there is still water in the bottom of the drum. When you reset it to a spin cycle again, you are making it run through the empty cycle again, finally getting rid of the water that the clogged filter could not evacuate on the first attempt.
You need to clean the empty pump filter. Now... Where is the filter???? Hmmmm... not sure. It MAY be behind a little panel in the front of the machine near the bottom. I can't find a picture of the machine on the net so I'm not sure.
Clean the filter, I'll bet your problem goes away. You have to wonder why the idiot who sold the machine to you hasn't suggested this!
Jun 21, 2011 | Washing Machines
The washer shakes uncontrollably during the spin cycle also a loud banging noise is heard during the spin cycle.....
If front load check the inner drum If it is loose at all you have a lot of problem . Very expensive.
Nov 17, 2010 | GE Washing Machines
I have 2 problems with my AEG Lavamat 981. 1. The drum won't empty out. We have tried using the emergency drain and even removed the hose connecting the drum and the pump(at the pump end) but the water...
first if you drum is filling again after wash you may have a faulty hot or cold inlet valve turn water taps of after wash has finished if no water in drum the next day just a matter of isolating which valve it is
your second problem sounds like you have a blockage in the hose coming out of your drum to the water pump may be that missing sock you were looking for hope this helps let me know how you went
Nov 13, 2009 | Audio Players & Recorders
During the spin cycle basket vibrates very badly - very rough
I had a similar problem. During the final high spin and there was POW and the drum went funky eating into the plastic. I opened the back of the washer and look things over,.The belt for spinning was intact. I set the washer on a drain/spin option and watched from the front and back. While watching the pulley on the drum and could tell there was a hiccup as it went around. I pulled the pulley off and put on a new pulley. The new pulley was going in a perfect circle to spin the drum. It's not a hard repair, just need a little muscle to loosen the nut holding the pulley on and the same muscle to tighten the nut as much as possible. Hope this helps.
Nov 07, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Bosch Classixx 1200 - Drum not turning
It could be the motor itself (is there any overheating smell from the motor) or it could be the capacitor which controls the motor. I had a similar problem and it turned out to be the motor brushes. I replaced the brushes and all was OK.
The only other thing that could be wrong especially if it overfills with water is the water level switch (this is a pressure switch on the side of the washer) You can easily check this by removing the hosepipe to the switch and blow gently into it, you should hear a clicking sound) This might be the clicking that you heard so it is probably Ok.
Aug 08, 2017 | Bosch Washing Machines
Spinning no matter what i do
Issue: Heli spins to the Left (counterclockwise) uncontrollably.
Problem: Tail rotor not turning fast enough, Dragging.
Background: My son's Heli Cage also started spinning to the left after he had flown it a couple 3 times. The trim and direction stick could not compensate. One time, the tail rotor came off during a crash. It was put back on and ran fine a couple more times until the dreaded left spin. I began to troubleshoot the issue. I checked for damage, hair and whatever else on the shaft. There was no obvious signs. When I pulled the tail rotor off, I noticed that it came off very easily. I put a new one on it and problem solved.
Diagnosis: the tail rotor shaft was spinning inside the rotor. This prevented the tail rotor from turning the correct speed.
Corrective Measures: replace rotor with new one. Avoid hitting the rotor while it is spinning...good luck! :-)
Mar 02, 2009 | Air Hogs Havoc Heli Helicopters
Kenmore 44092/spin cycle
It turns out that there was a sock stuck within the pump in the washing machine. I removed the back cover and removed all the excess water, because once the sock was removed, the water was free to escape. I just removed the hose that connects to the pump and felt the sock, and was able to remove it. Once I hooked everything back up, the washing machine ran great.
Apr 17, 2008 | Kenmore Energy Star 44092 Front Load...
Maytag performa pye/g2200,3200
when you say the drum wont spin even manually. Do you mean the drum is too stiff to turn by hand? If so the bearings may have seized up solid. If the drum is free to turn by hand, the pump may be blocked, or burned out & not allowing the water out. If so the circiut wont allow the machine to spin. If thats the case, unblock or replace the pump
Oct 20, 2007 | Maytag PAV2300 Top Load Washer
Whirlpool AWM6141/1 Front Load Washer Logo
52 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
