Question about Samsung RS2630SH Side by Side Refrigerator
Samsung fridge freezer model no: RS21DCNS
Same prob as most people, fan makin noise like it was hiting ice, took it apart and defrosted it using hairdryer, now fridge at 24degrees and temp hasn,t gone down in the last 2hrs. any awnsers.
How do we disconnect the water line to the freazer
Posted on Apr 14, 2008
I have samsung side by side. The fan behind the evaporator cover was making a grating noise and now doesn't seem to run and fridege not so cold. Took cover off and evaporator and fan completely iced up....
IT means that you have not fully defrosted the fridge in sometime.(should be done every 6 months max).switch it off,let it fully defrost for 12 hours,then restart,should work fine(i hope).
Nov 23, 2010 | Samsung Refrigerators
What temp should my freezer be , also the fan in the top of the fridge stated making a noise when it stopped or started its cycle sounded like something was catching on the fans blades , then it stopped...
I like 0 to 10 Deg. F in the freezer.
As for the Fan. yes it could be ice or the fan blade hiting the shroud, sometimes the fan blade moves on the shaft and starts hiting the shroud.
Jan 11, 2010 | Hotpoint FFM90 Bottom Freezer Refrigerator
MY SAMSUNG FRIDGE/FREEZER HAS A PROBLEM MY TEMPERATURE ON THE FRIDGE IS FLASHING. THE MODEL NO. RS21DCNS THE FRIDGE IS NOT COLD ENONUGH AND I PUT THE TEMPRATURE ON HIGH AND IMMEDIANTLY IT WENT BACK DOWN....
This is caused by the ice building up in at the back - the fan catches the ice and eventually will stop. With the fan malfunctioning the temperature will rise and the light then flashes. Keep searching the web, and you will find instructions how to remove the back and de-ice it. I had exactly the same problem 2 months ago. Make sure that it is fully de-iced, including the tray at the bottom. Ours has worked OK since!
Jul 07, 2009 | Samsung Refrigerators
SAMSUNG RS21DCNS
samsung fridge freezer problem
samsung fridge freezer diy help
Apr 27, 2009 | Samsung Refrigerators
Fridge and freezer not staying cold but lights and fan working
the problem is going to more then likely in the main control board which is on the back of the refrigerator in a little compartment this board is bad about going out if you have power surges or outages
Jan 03, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung rs21dcns fridge freezer Ice build up in fridge - twin cooling fan not working Fridge temp not acheivable
very common issue on samsung r21 models , repair kits available and plenty of help videos out now
have a look at this youtube video and the chanel it belongs to
Nov 10, 2008 | Samsung Refrigerators
SAMSUNG RS21DCNS
The middle part of my refrigrator (RS21DCNS) is full of ice. i have removed ice many times. could you tell me whats the reason and solution of this?
Jan 15, 2008 | Samsung RS2630SH Side by Side Refrigerator
SAMSUNG AMERICAN STYLE FRIDGE FREEZER MODEL RS21DCNS
Sounds like u need to replace fan motor
Check fan motor for continity IF none replace fan motor
Oct 12, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung fridge freezer rs21dcns not cooling
press for diagnose the power freece and power cool, you will get an information about the self diagnosis. you can call samsung and will get a clue what is going on. maybe the heating is not working well.
Sep 30, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
297 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
