Question about AcerPower 1000 (AP1000EA380M) PC Desktop
Help plesase, my computer won't past POST
Help plesase, my computer won't past the POST screen and keyboard not responding
    Guru:
  • 163 Answers
Check the there is proper power supply is coming through the power supply. And also remove ur CMOS and Then check if it works or not
Posted on Apr 27, 2010
My computer turns on but is stuck on the acer screen del: enter setup and f12: boot menu are there but keyboard won't respond I've tried everything
First unplud everything except the monitor and keyboard from the system. This can help to narrow down the problem. If it boots after doing this then one by one plug everything back in until you find the problem device.
Also try leaving it on the Acer screen for a while to see if you eventually get an error code. You might even have to let it set there for 30 minutes or so.
Jan 08, 2013 | Computers & Internet
On my Toshiba Satellite Laptop I have opened and started the computer but can't get past the sign in window because my enter key and space bar won't respond. I can type letters but can not enter...
> hardware problem or software or keyboard?
Experiment #1: turn the computer off. Connect a USB keyboard. Turn the computer on. Use that keyboard to try the 'TAB' key (to move from field-to-field). If TAB works, then try using the SPACE or ENTER keys.
Experiment #2: turn the computer off. Turn the computer on, and look for the message:
PRESS <blah> to ENTER BIOS SETUP
When you see the message, press the <blah> key. On the BIOS SETUP menus, try the ENTER key to "select" a field, to prove that the ENTER key works fine.
Experiment #3: Turn the computer off. Disconnect the AC power. Remove the battery.
Remove the disk-drive. Take the original CD/DVD disk, and start to install Windows to the disk-drive. As you work through the installation screens, you'll need to press ENTER at least once,
if only to acknowledge that installation cannot proceed, because the disk-drive is not connected.
If the ENTER key works, it works.
Experiment #4: Like #3, but connect a different, empty, disk-drive, and reinstall Windows.
If it completes, then your "original" setup has a SOFTWARE problem.
Jul 14, 2011 | Computers & Internet
When my computer starts up after the windows logo loading screen the screen turns black and then my keyboard and mouse stop responding and the screen stays black thats it
Press F8 key after post boot screen and before windows booting, dos screen will come from there select safe mede booting, computer will boot in safe mode
1) Click On start
2) Go to All programs
3) Go to Accessories
4) Go to System Tools
5) Select system restore
Sytem restore window will come there you will select restore my computer to the earlier time, you will get calender on the screen there you have select any highlighted previous date
After restart your computer will be ok.
Apr 01, 2010 | ASUS P4B533-VM Motherboard
Keyboard not responding.
This post seems to be a duplicate of one posted under the name of Guest, so, I am pasting the solution here just in case you have not gotten notification of resolution suggestions.
Your problem sounds more like the system running slow rather than the keyboard being the issue.
Do routine maintenance and cleanup on your system to see if it helps it.
To start the Disk Cleanup tool and specify the hard disk to clean by using a command line, use the following steps:
  1. Click Start, and then click Run.
  2. In the Open box, type the following line and then press ENTER
    cleanmgr
  3. click OK
  4. The dialog box that opens shows you the files it will remove to clean up the system
  5. Make sure Temporary files is checked
  6. Click OK
Then check your system for malicious software.
  1. Go to http://malwarebytes.org
  2. Download and scan the system
  3. Remove all found infections.
  4. Restart your system
These things should help if this is the cause.
Let me know if this resolves your issue.
Mar 26, 2010 | Logitech 967461-0403-PK Keyboard/Mouse
Keyboard keys y h n and one of 6 keys not responding
Try another known working keyboard on the computer, if all the keys work then that means your other keyboard is bad. If you have the exact same problem then its something in the Operating system for the keyboard that needs to be checked.
Nov 27, 2009 | Apple M9034LL/A Keyboard
Have you tried a USB keyboard and mouse wired.try also to hook up the normal keyboard and Mouse with out any usb devices hooked on the computer
May 05, 2009 | Logitech 967461-0403-PK Keyboard/Mouse
My Compaq keyboard won't display ''print screen'' when I press that key (prt scr). Everything else works fine on the keyboard. I purchased the computer/keyboard about 7 years ago. Thanks very much for any...
The print screen button doesn't usually do/display anything other then pasting the image on the screen to the clipboard. go into another application like word or paint and select ctrl+v to paste (or right click then select paste) If you hold Ctrl then press print screen, it will only copy the open window.
Apr 26, 2009 | Compaq Presario 5000 PC Desktop
AcerPower  1000 (AP1000EA380M) PC Desktop Logo
54 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
