Question about Microwave Ovens
Sharp r-798 problem
My sharp microwave model r-798,sounds like it is working but it does not heat,also the turntable is not turning. I replaced the waveguide but this did'nt help. Is a repair possible?
thanks.
I think i discoverd the problem, the bottom latch of the door had broken off but was being held in place within the door.When i checked the door switches i could see the bottom latch was not pressing the switch down because of the break.hopefully some super glue will suffice, if not i will need to get a replacement part.Reading some of the solutions of other posts greatly helped me.Hope this helps someone else.
Posted on Mar 24, 2008
My sharp R-352DC Microwave won't heat, and turntable doesn't turn, also the display does not work. Please tell me the problem?
It sounds like power to the circuit board might be interrupted, but data on non-US models is limited.
Nov 17, 2016 | Sharp Microwave Ovens
Sharp Carousel Model R-1874 no heating or turning, display works
sorry without seeing the machine we can not help try whatever you want . that is how many of us learned what we know today
Nov 17, 2017 | Sharp R-1874 Convection/Microwave Oven
Sharp Carousel R-1481 Turntable
It may very well have have damaged the turntable motor.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
On many Sharp models, you have to cut the motor cover off with snips, then use a screw when reassembling it.
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
You will need the
free Acrobat Reader to view or print it in case you don't have it already.
The best place to order parts for this brand is Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
Be sure if you cook an egg that you puncture the shell first so it can breathe.
Mar 01, 2009 | Microwave Ovens
Microwave not heating up
Check the door switch, when it is faulty the oven will turn on but turntable, fan and magnetron wont operate.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Jan 13, 2009 | Sharp R-1850A Convection/Microwave Oven
Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
Jan 08, 2009 | Sharp Microwave Ovens
Turntable does not turn.
To replace either, you need to unplug power, then remove the bottom cover of the oven. In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
The best place to order Sharp parts is Tritronics. Or you can call them toll-free at 866-779-5835.
Dec 23, 2008 | Sharp R-530ES Microwave Oven
Microwave turntable won't turn
Most likely the turntable motor itself is bad - not an uncommon problem for that model.
Check with www.martinmicrowave.com (toll free 1-877-894-0035)
unfortunately, the particular motor used in your model is rather expensive - + - $50
Dec 23, 2008 | Sharp R-930AK Convection/Microwave Oven
MICROWAVE RUNNING. DON'T HEAT & TURNTABLE WON'T TURN
your magnatron needs replaced! (It may cost less for a new one then to fix this one!)
Dec 09, 2008 | Sharp R-930AK Convection/Microwave Oven
Sharp 1505 over counter microwave
It's almost certainly not a switch issue. If the primary interlock (lower door switch) were bad, the turntable and cooling fan would not come on and it would not heat.
If it heats, but the turntable won't work, the motor is likely bad.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
We have the complete service manual for this model and have uploaded it to our site here to help you.
You will need the free Acrobat Reader to view or print it in case you don't have it already.
Nov 07, 2008 | Sharp R-1505 Microwave Oven
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
Microwave Ovens Logo
187 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
