Question about D-Link DSS-16+ (dsdldss16p) 16x10/100 Mbps Networking Switch
The power wont come up, how can i buy or replace the power chip inside?
I have a pioneer pro 730hd took the back off and now the red power light just blinks and it wont turn on
If convergence was off it may have railed (shorted convergence chip) and the set is now in shutdown.
Also go over inside in case you moved or pulled a plug loose.
This is not an easy set to replace the chips and only the original remote will adjust convergence.
Mar 17, 2012 | Pioneer PRO-730HD 64" Rear Projection...
How do you buy chips in zynga poker on facebook?
Hello and Welcome to FixYa!
If you want Zynga Poker Chips, you should buy them directly from inside the game (you can click on the "Get Chips" tab at the top of the screen. It's the only legal way to buy Zynga poker chips.Zynga is the only authorized seller of Facebook chips, When you buy Facebook poker chips they immediately credit your account. That's it!
I hope this solution will helpful for you.
Anymore help, I am here to help.
Thanks and Keep Visiting FixYa
Jun 10, 2011 | Facebook Social Network
My polaroid i836 camera wont power on. I put in brand new batteries and it still wont power on. This camera is just 3 weeks old. help!!!
the procesor on main board is in short circuit, in other words you will have to replace the board, unfortunely polaroid dont sell it, i check the whole entire camera with an osciloscope and the chip isnt giving me the right values,,it just click inside but no power up,,sorry get new camera and research for brand problesms before you buy...
Mar 04, 2011 | Polaroid i830 Digital Camera
Computer wont turn on but there is a green light on inside
Dead power supply man, just had a computer in the shop that was doing the same thing. Unless its beeping at you then probably memory
Feb 25, 2010 | Dell Dimension XPS 400 PC Desktop
I have an Vgn fs742w sony laptop, as of yesterday it wont start up. No noise no bios nothing.
Check your power supply, if the supply is good, then check the adaptor on the side of unit.
Do you have a power light when plugged in ?
Does the power supply have a light ?
Also you may try removing the battery and try to power up.
Sep 30, 2009 | Sony VAIO VGN-FS742/W Notebook
360 wont read or do anything
heat the board inside with a rework then clean the heatsnks n chips with artic cleaner and replace ll bolts on heatsinks (m5) apllie new thermal compound then put all back together an see if it works cos it sounds like ur chips are damaged this is the way to fix this problem
Mar 23, 2009 | Microsoft Xbox 360 Console
Computer wont boot after memory upgrade
when working on computers you have to be carefull to ground your self before touching the inside of them. when installing memory you dont need to unpluge everythinf just the main power cord on the back of it.the blinking green light means you have something no pluged in right,double check everything you unpluged make sure it back in the right areas.on memory the slots are mark 1,2,3,4
make sure if the memory is diffrent in speeds the lagger ons go first.the first to slots normally have to be the same speed and size ram.if that does not work let me know i can look into it for you.
Dec 15, 2008 | ASUS P5RD1-VM Motherboard
RCA TV RCA D61W20, Light Blinks 3 Times
Usually when the crt leaks onto the chassis it can be cleaned and the affected components only have to be replaced I am not sure what "chip" you are refering too, but most ICs can be purchased as a replacement part. usually the entire board wont need replacing unless the traces are destroyed or replacement parts are unavailable.
Apr 11, 2008 | Televison & Video
Hp dv5000 problem
ill suggest o you like many technician do when they messed around their workstation...
if that what you have done is similar to a desktop replacement of ram probably you just knocked out some of the components inside...
first thing check the specs of your old ram and compare it to your new ram... its not just buying the higher capacity but also considering the type of ram you are buying... you can't just put oddly different rams to replace the old one just because its has higher capacity... go to the store where you bought the new ram and show them your old ram for an assistance, hopefully the guy selling the ram knows what type of ram you really need (they should ask you that on the first place).
if the two rams you bought are similar to each other then you save your time going back to the shop where you bought the new ram... just open your system and make sure everything sets firm and if you can just the ram out and get a brush.... brush the dirt out of the connectors and use an eraser to your ram and erase the contact points...
if this helps just rate me to give thanks ok...
Jan 20, 2008 | HP Pavilion dv5020us Notebook
D-Link DSS-16+ (dsdldss16p) 16x10/100 Mbps Networking Switch Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
