Question about Refrigerators
I have a GE GSH25JSTA SS refrigerator. The main problem is that its not cooling enough, both freezer and fridge. Now ive been reading alot and i still have alot of questions. Things I've done so far: last night i vacuumed and cleaned dust behind and under the fridge but nothing. Now today i took everything out of the freezer and removed panel behind the freezer and the coils are covered with ice. Blow dried it and received helpful assistance from a pro in this site. Located heater part and terminator(everything looks fine)...now what do i do next???
  • trey08 Apr 27, 2010
    yes the fan is working. btw, this fridge is 2 1/2 years old brand new. thanks!
    I still need help. any pro's available??? thanks.
  • Refrigerators Master
  • 3,866 Answers
Check the condenser fan does it run? Does the fan turn on if not replace the fan itself you be so happy you did.
Let us know, please od click the accept button for my efforts.
Posted on Apr 27, 2010
  • Grand Canyon Tech
    Grand Canyon Tech Apr 27, 2010
    if the fan is running only thing i can think of is a faulty thermostat. let me know what you find because i had the same issue.
  • Grand Canyon Tech
    give me a zip code so i can look up a tech in your area to fix this for you i know you have not tried testing the thermostat or have you?
Why is mt GE Profile PSC25sgsc ss not cooling
Most likely the=> Defrost Heater Assembly WR51X10055 and High Limit Thermostat WR50X10069 need to be replaced. Heater is burned out. High Limit Thermostat WR50X10069
Appliance 911 Sea Breeze
Aug 01, 2015 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer thaws and refreezes
HI.DO BASICS FIRST .CLEAN CONDENSER UNIT FIRST THOROUGHLY.INTERMITENT FAULT IS ALWAYS A BIT DIFFICULT TO DIAGNOSE.TRY IT IF OK U HAVE CRACKED IT BUT IF SAME THEN C WEATHER THE MOTOR AND CON/UNIT IS WARM WHEN DEFROSTING IF COLD IT COUD BE A LAZY DEFROST TIMER OR T/STAT THEN HEATER AND FAN.GOOD LUCK ALI
Jul 09, 2012 | GE GSH25JFR Side by Side Refrigerator
Gss25xsrd ss GE fridge gets warm on the top (both fridge and freezer side) and freezes at the bottom. Ice completely melts and veggies in the drawers freeze too.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 26, 2010 | Refrigerators
The cooling unit stops running periodically.....long enough to allow food in the freezer to thaw. The fridge light is on, so electricity is getting to the fridge. The previous tenant had dogs, and when we...
Could be defrost sticking or the compressor not starting...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Sep 26, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
I replaced the water filter for my GE GSH25JSTA SS side by side fridge and now the unit is no longer dispensing water
I have had the same problem with the same model several times in the past. It also happens to me within a few days of replacing the water filter.
In my case, I believe the water line in the freezer door has become frozen. I usually let the freezer thaw for a couple of hours, and my water works again.
I have had constant problems with this model. I would recommend trying to sell your fridge now while it's still running, before the real headaches begin (mine has died 2x in the past six months, and I have not even had it for 2.5 years yet). No more GE's in my house.
Mar 22, 2009 | GE Refrigerators
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
GE Fridge: PSS26SGPA SS Model
CallMe-
Your "freezer" and "refridgerator" temps are not jumping back to 14 and 44 respectively. When you change temps, they both wait 3-5 seconds before they revert back to a temp reading, not a temp setting.
Does your "freezer" make any loud or thumping noises? If not, do you hear a quiet whisper when both compartment doors are closed?
Solutions could be :
1. Servicing the coolant (might have a small leak)
2. Checking the seal on your freezer compartment (black rubber that meets the metal frame)
3. Your internal cooling fan is not operating and needs replacing (but I think your temps would be significantly higher).
Best of luck.
Jul 28, 2008 | Refrigerators
GE GSH25JSTA SS side by side fridge not cooling/freezing
In most cases it is the Defrost timer circuit. One of three things the Defrost time (most likely) it allows the cooling for a 6 to 10 hour period and the defrosting for 10 to 30 minutes to remove ice buildup, ICE BUILDUP is the main problem as it restrict air flow, the cooling air circulation through the system. You see cool air only comes in the freezer side and passes through vents (pass ways) to the refrigerator side. Ice buildup in the freezer side inhibits cooling air to the refrigerator side. You think the freezer is working, but it is only cooler because there is ice in there that you can't see. The Terminator (a LIMIT switch) opens the defrost circuit if the defrost heater gets too hot (second likely) the next is the Heater which heats for those 10 to 30 minutes to melt the ice buildup (least likely) no matter the Unit you have they all have this circuit... Hope this helps, I'm Tango
Jul 26, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
Ge profile side by side fridge
THIS IS CAUSED MORE COMMONLY BY A FAILURE TO THE MAIN PROCESSING BOARD NOT SENDING PWR TO THE DISPENSER RELY BOARD
May 29, 2008 | GE GSH22JSRSS Stainless Steel Side by Side...
Refrigerators Logo
81 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
