Question about LG 24 in. LD-12BW5 Free-standing Dishwasher
Erroer flashing "he"
Dishwasher was washing then started beeping and flashing " he"
  • chris oxlade Apr 28, 2010
    thanks all good covered by warranty
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. HE error is you dishwasher means “Heater Error”. This is caused when either the heating element or the thermistor goes bad as the thermistor is also part of heating assembly. To resolve this issue the heater assembly should be replaced or whichever has gone bad out of two (heater/thermistor) should be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Apr 27, 2010
Haier dishwasher HDW9WHT beeps 5 times and won't wash what is wrong with it can I fix it or should I get someone in
7 results (0.54 seconds) Search Results
    Haier HDW100WH / HDW100SS - ProductReview.com.au
    www.productreview.com.au > ... > Dishwashers > Freestanding > Haier
    Rating: 1.7 - ‎30 votes
    Haier HDW100WH / HDW100SS: 30 customer reviews on Australia's largest ... 1.7 out of 5 stars for Haier HDW100WH / HDW100SS in Freestanding Dishwashers. ... I putthis review in to do my part for what I think is a great consumer service you ... it it keeps beeping 10 times telling me doors open??and won't begin cycle.
    Haier Dishwasher Error Fault Codes - Lights Flashing ...
    removeandreplace.com/.../haier-dishwasher-error-fault-codes-lights-flash...
    Dec 21, 2015 - Haier dishwasher error codes - flashing lights - beeping ...Dishwasher keep filling water and draining at the same time ... Fix Washing Machine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note 5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The Refrigerator ...
    Dishwasher Has Beeping Sounds Blinking Lights - How To ...
    removeandreplace.com/.../dishwasher-has-beeping-sounds-blinking-light...
    Dec 21, 2015 - At times your dishwasher may need to be reset. ... Haier DishwasherError Fault Codes - Lights Flashing Beeping Sounds My Haier ... Fix WashingMachine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The ...
    How to Troubleshoot & Repair a Dishwasher ' HomeTips
    www.hometips.com/repair-fix/dishwasher.html
Jan 19, 2016 | Haier Dishwashers
I have the CW447 integrated dishwasher which won't fill with water
Like most electrical appliances what worked for me was turn it off at the wall for 10 mins, then turn it back on. Did you get an error code? Check the pipes are not twisted and that the water supply is turned on full. Let me know how you get on
Apr 13, 2014 | CDA WC430 Dishwasher
The light keeps flashing an going beep beep dishwasher isnt doing it's job not washing
On my dishwasher if I hold down the start button for a few seconds it resets the cycle could you do that with yours as mine is a different make?
Feb 02, 2013 | Dishwashers
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
The Drying light flashes and the unit beeps about once per second. At the same time the unit acts like it is washing (sounds of water washing insiide. The bottom is oompletely full of water.
so its beeping and flashing once per second correct this beeping and flashing is an error code that your unit is giving blinking lights or beeping sounds may indicate a problem with the dishwasher caused by power surges. To correct the problem, try pressing the "Start/Reset" pad to reset the dishwasher. If the problem persists, reset (reboot) the control by turning off the circuit breaker supplying the dishwasher for 30 seconds. Turn the circuit breaker back on and the dishwasher should function normally if you still have the flashing and beeping message me back Im going through the error code book as I type this if it still persists after you turned off the power then back on message me back with the number of beeps within 60 seconds as well as the number of flashing lights for instance if it does it every second or once every 5 seconds also if you have any further questions message me back them as well and please remember when our chat has fully concluded to rank how this opinion has helped it allows me to help others in similar situaitons Thanks Rick
Feb 04, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
Maytag Performa Dishwasher draws water then stops
More than likely you need to replace the washer control panel.
Jul 19, 2017 | Maytag 24 in. MDB5600A Jetclean II...
Dishwasher beep twice but dont start washing
You may have a problem with the control board and needs to addressed by a qualified LG technician.
Mar 15, 2008 | LG 24 in. LD-12BW5 Free-standing...
Prima LPR600
my prima LPR intregated dishwasher just not playing ball, has not been washing properly and had a continuous flashing and beeping fault, we cleaned out the filers and the arms which seemed to help the beeping problem but now have a fault where at the end of the cylcle its now showing another fault where it flashes 4 times but beeping has stopped what seems to be the problem and how do we fix ?
Oct 17, 2007 | Dishwashers
LG 24 in. LD-12BW5 Free-standing Dishwasher Logo
182 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
