Question about LG LRBC22544 Bottom Freezer Refrigerator
I have an LG fridge (LG LRBC22544) that collects water underneath the crispers. It freezes (almost 1 inch thick) and then melts. Once it melts, then it leaks out the door. This reforms every 3 weeks or so.
I have had the same problem. In my case, its the little water tank behind the left crisper. The tank has cracked (twice now) which means replacement (again). The water leakage gets so bad that it leaks into the freezer causing ice up problems in the rear.
Posted on Jul 15, 2010
I have a Westinghouse freestyle fridge and it is collecting up to 500 ml water underneath the crisper bins each day.
remove crisper bins and look for the drain tube . it must be clogged . as water is supposed to drain to the evaporation tray under the fridge .
Dec 17, 2014 | Westinghouse Refrigerators
My Whirlpool refrigerator, model GT22DMXGW00, leaks. Water is accumulating in the bottom-underneath the right hand side crisper. It then drains out onto the kitchen floor. Some is freezing too. It is...
check the ice door flap where ice drops into a glass.sometimes the flap doesn't close completely and allows heat to enter threw the flap.this causes frost to build and melt thus you have water you can't explain. hope this helps.
Dec 11, 2014 | Whirlpool Refrigerators
On my LG top freezer model, it collects water in the bottom of the refrigerator, under the pull-out crisper drawers. there is no visual sign of were it is coming from. it does have an ice maker i8n the...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 17, 2011 | LG Refrigerators
Fridge freezes up and then meltsw
I FOUND A PROBLEM WITH A COUPLE OF THESE THAT THE AIR FUNNEL ALONG THE BACK WALL WAS SEPERATED FROM THE FLOOR OF THE REFRIGERATOR REMOVE THE CRISPERS AND LOOK AT THE BACK WALL. IF THERE IS A GAP AT THE BOTTOM AIR DUCT APPLY SILICONE {FOOD GRADE ONLY} TO SEAL THE GAP
Jan 12, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
For some time, water was accumulating on the floor
before you call check the bottom of your freezer, if it is full of ice, yuou more than likely have a clogged defrost drain
remove the back panel of the freezer and ensure the drain is free and clear,
check the fill tube of the ice machine to be properly installed
Oct 13, 2009 | Refrigerators
Whirlpook ET21NK--Water collecting in crispers
Self-defrosting refrigerators turn themselves off to defrost once in each 24-hour cycle. There is a 'drip pan' under the refrigerator that catches water from this automatic defrost cycle. The pan is not very deep, so if the unit is leaning very much, water will run over the top of the pan. For this and other reasons, you should try to keep the unit as level as possible.
Aug 21, 2009 | Refrigerators
Underneath the crispers is full of water sometimes even freezes Underneath the crispers water collects, but it does not freeze.
Here is a link to help you resolve the problem I also have an even better link but on-line is moving slow at moment. Anyway you will need to take the part out from back and clean the blockage., Let me know if this helps, Sea breeze
http://appliancejunk.com/forums/index.php?topic=1309.0#top
http://servicepartstec.blogspot.com/
May 19, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Water under crispers in my fridge
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 13, 2009 | Refrigerators
Water dripping from top of fridge then freezing under crisper's
Jan 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Roper Refrigerator
open the freezer compartment loo for ice build up on floor of frezer especally towards rear behind back panel. sounds like you have a clogged/frozen defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials)
Mar 05, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
LG LRBC22544 Bottom Freezer Refrigerator Logo
581 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
