Question about Zodiac Baracuda G3 Automatic In Ground Pool Cleaner
Our zodiac x7 quattro is not sucking at all?? It is only 2 months old
  • 990 Answers
If you have no suction it is probally in the pump, you can check for suction where the hose hooks to wall.If you have suction there than you have a clog in your hose or in the head itself. If you don't have suction there check your pump basket and pull the basket with the pump off reach in the hole behind it with screwdriver or needlenosee and feel for a clog at the impeller. Also check to be sure the pot lid seal is in good shape and soft enough to seal. If none of this helps then you may need to get a repairman out to look at it.
Posted on Apr 27, 2010
Barracudu wont go up the walls anymore and seems to get stuck in corners
Check your filter. It may be dirtier than it once was. If Sand Filter, use a "Sand Filter Cleaner" to soak the sand & remove the particulate that normal backwashing won't remove. If cartridge filters, then the elements need to be soaked overnight with a Cartridge filter cleaner. If DE, then - grids need to be removed and even possibly cleansed (mild acid wash) then recharged with fresh DE.
Or... check internals of pump. The impeller may be plugged where the flow is reduced. Internals of the cleaner itself, is also suspect. check for any sucked up large debris: pine cones, toys, plastic bags, etc. You may also have a pinhole or larger in the suction hose. Do you have a dog or critters (possums, squirrels, raccoons?) they have been known to Attack the hose and the teeth put holes into the hose. Just a minor hole will affect the efficiency of the operation of a suction style cleaner.
Feb 01, 2014 | Zodiac Baracuda X7 Quattro Swimming Pool...
3 months old Zodiac not working
Can you be more specific about which product you have, and what is coming loose? Thanks, Bill
May 27, 2013 | Zodiac Pool & Spa
Zodiac G2 Cleaner not moving around pool. Suction is adequate, filter has been backwashed. Cleaner pulled to pieces and reassembled. Has small crack in diaphram. Unit is 6 months old and has problems the...
any damage to that diaphram will cause the cleaner to not work. If it is only 6 months old then it is under warranty. any pool store should be able to get you a new diaphram at no cost. bring your paperwork with you to show proof of purchase.
Dec 29, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Baracuda X7 stays at the deep end of the pool
With these pool cleaners, there are several things that you can try to get your cleaner to move around your pool. Check to make sure the hose is long enough to reach all ends of the pool and that it has proper hose balance. Check the return line water flow and redirect as necessary with an eyeball diverter.
Jul 23, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Zodiac x7 quattro won't move, even with the flow set right.
unscrew the collar just above the handle and push the pipe inside downward. visually inspect the diaphragm for debris or damage. This is the most common cause, given you are confident the suction is sufficient.
Mar 13, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Barracuda x7 quattro won't go to the shallow end of the pool
Zodiac X7 only 4 months have problems with Parts, had to replace all lower parts and now the flex hose fitting is bad.
I believe this design is a lemon.
Aug 12, 2009 | Zodiac Baracuda G3 Automatic In Ground...
Zodiac Pacer pool cleaner not sucking water or moving
Remove diaphragm and check for rips or tears in plastic.
May 31, 2009 | Zodiac Pacer Pool Cleaner
Centrios X7 gaming mouse
It should work on Vista 32-bit. It says explicitly in the manual that it WILL NOT work with 64-bit Vista. I think you're out of luck, dude.
Aug 29, 2008 | Computers & Internet
Zodiac Baracuda G3 Automatic In Ground Pool Cleaner Logo
219 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
