Question about D-Link AirPlus DI-524 Wireless Router
Connection Problem I have just purchased as part of a package from Dell a DI-524 router. At present my PC is connect to the internet via a ADSL modem supplied by Onetel, the out put from the modem is a USB connector can this be converted to fit the DI-524 or do I require to purchase a new modem of get ontel to supply an item with the correct flying leads. regards Derek
  • 813 Answers
Insatll your drver cd of router if u have connted with a usb cable
then after configar your router
the router defot ip is
type in your web page address bar
the user name is admin & pass: admin
just login & configer
& enjoy
Posted on Mar 25, 2008
I recently moved from Cable ISP to DSL ISP service. For the DSL service, I was asked to configure my Router to use PPPoE with Dynamic IP addressing. I also provided the router with my username and password...
The reason you have no internet is because the router is specifically for cable. your description contains errors what i think you mean is that you have gone from cable dsl to an adsl, correct me if i am wrong. Basically your modem connected to your router via an ethernet cable and then the router fed the wireless signal to your wireless devices or via ethernet through the 4 ports in the back. With adsl you have a feed from your phone line to an adsl modem so the only way for you to get the dsl router working is to have two ethernet leads connecting to your pc, one from the modem to the pc and one from the pc to the router. You would also need to setup internet sharing on the pc thats connected to both devices.
Either do it that way or buy an adsl router
Nov 10, 2010 | D-Link DI-624M Router (DI624MRE)
Ethernet connection of DI-524 does not work
You have to make the Ip changes on the laptop not on the modem.
You said you have internet acces on one computer. Then use that computer to find out the exact IP address used by the modem.
On the laptop use the exact same numbers, (IP, Sub mask, Gateway, Primary DNS)
and chek if it works.
If you want to have both computers on the Internet, simply change the last number on the IP address ONLY.
Please don't forget to rate this answer if it helps
Sep 22, 2009 | D-Link AirPlus DI-524 Wireless Router
Router and pc configuration to connect broadband via dsl modem
Sorry i tried to open and it could not display. what is the new IP
Aug 06, 2009 | D-Link AirPlus DI-524 Wireless Router
My D 502T Adsl+2 will connect but when I try to
First of all, what IP address does the 502 give you when you plug into it alone? Do an IPCONFIG from DOS and note the numbers.
Now, what is the default IP of the 524. Is it the same as the 502?
If it is, change your 524's IP to something else, like
If it isn't, please post back what your IP configuration is and what the link is, DSL,Cable Modem, PPPoE, or DHCP either fixed or variable.
Apr 01, 2009 | D-Link AirPlus DI-524 Wireless Router
Haw I can connect tow adsl line in one modem ?
Your connection should be like this:
PC --> Port 1 on the router
Modem --> Internet or WAN port of the router
Dec 18, 2008 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Connecting to internet
you need to configure wireless on router panel using the browser.
Apr 16, 2008 | D-Link AirPlus DI-524 Wireless Router
L2TP connection problem
Hello, I've had the electric cut off and immediately back on and I lost my connection from Wireless router to modem. I could not connect in the same way. I could access the router settings with wireless laptop and PC but not to internet on either. I bypassed the router and connected the PC computer to modem then to internet verifying with a browser. I then reconnected the computer cable back to router and router to modem. It stayed connected. But I'm not sure if you have a PC connected to the router also. Sometimes just unplugging some cables and replugging will solve problems. Hope this helps.
Feb 18, 2008 | D-Link AirPlus DI-524 Wireless Router
How to connect wireless router to adsl router?
You're wanting to connect the directly connect the DI-514 to the ASDL modem to give you a wireless network, right? If so here's what you do:
Connect an ethernet line from the modem to the Internet/Wan port of your DI-514 and then you're set. I recommend you then follow the directions in the manual to setup wireless security.
If you're wanting to have your DI-514 wirelessly connect to the ASDL modem, then connect your PC to one of the LAN ports of the DI-514 and open the administrative web interface (usually located at and go to the wireless section and select "Wireless Client" and input the MAC of the ASDL modem's wireless interface (you can find this on the administration web interface of the ASDL modem) and you should be good to go.
Feb 10, 2008 | D-Link DI 514 Wireless Router (DI-514)
When connected to internet via D link 524 router, laptop won't allow opening some web pages
Can you surf to websites via your wireless connection without a problem? Is it only web-based email that's giving you problems? It may be caused by a firewall that is blocking traffic on your wireless connection but not on your LAN-card. Are you using a security suite (McAfee, Norton, etc)? You might want to check those settings too. Finally, make sure that the IP-settings of your wireless card are the same of those of your LAN-card. Can you connect to your router via wireless, Check the various settings there too. G'luck.
Aug 08, 2007 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
100 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
