Question about Canon PIXMA MP830 All-In-One InkJet Printer
It says there is an error code 5010 and prints a black line down the centre of the page?
  • 4,041 Answers
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 27, 2010
MY PRINTER SHOWS 5010 CODE HOW DO I CORRECT THIS PROBLEM PLEASE ?
Error code 5010 indicates carriage lift mechanism error. That means that the carriage did not move up or down properly. You need to replace PR lift shaft assy, Sheet feed unit, Logic board assy, Carriage lift sensor unit. Before replacement of the logic board assy, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or more, also replace the ink absorber kit when replacing the logic board assy.
Feb 21, 2011 | Office Equipment & Supplies
The copies have a black line in the middle and the error code 5010 comes up, turn it on and off and it works again but the line in the copies is still there. thank you
Dirty print out is basically due to cartridge related issues. Take out the cartridge and clean its drum/ (green roller) with a dry, soft, lint-free cloth. The drum is usually located under a cover. Checkout for any spilled toner inside the printer and clean it also. Print a few pages so that the parts get further cleaned. I think, this would solve the issue.
Moreover, black streaks (thicker lines) and dots etc indicate faulty PCR Roller which is located behind the green drum inside the cartridge. Cartridge or get the PCR Roller changed by a professional.
Let me know if any further clarification is required.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Feb 15, 2011 | Office Equipment & Supplies
Error code 5010
Error code 5010 indicates carriage lift mechanism error. That means that the carriage did not move up or down properly. You need to replace PR lift shaft ***'y (QL2-0936), Sheet feed unit (QM2-2916), Logic board ***'y (QM2-3078), Carriage lift sensor unit (QM2-3092). In brakets you have the part number for each one of them. Before replacement of the logic board ***'y, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or more, also replace the ink absorber kit (QY5-0146) when replacing the logic board ***'y.
Feb 01, 2011 | Canon Pixma MP500 All-In-One InkJet...
Unwanted line down centre of page
you need to reassemble image unit and clean completely
if you dont know how to do just bring it your printer to technicians
Jan 06, 2010 | Samsung CLP-510 Laser Printer
Printer will not print, error code 5010 is
5010 is a scanner error, either worn out scan lamp or sensors. Canon only replaces the entire scan assembly, if you like I can get part number and price.
Jun 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Error code 5010
Yes, same thing happens to me...Error code 5010...and flashing green and orange...alternating lights.
I was trying to photocopy (in basic black, not colour). I had a few pages to copy. I got this 5010 Error code after EACH copy!
I had to turn off the printer after each copy and then turn it back on for the next copy. That's not the worse of it.....once I turned the printer back on and hit copy again...the printer took a VERY long time to scan the item for the next copy. It took me a good 40 minutes to copy 15 pages.
Sooooo irritating!!!!!
Anyone know what to do?
I've also had the paper jam on me tons of times. I am really disappointed with this product. I would not recommend this printer to anyone!
Mar 24, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Error Code 5010
it's the printer version of a blown engine(as in your car)..got a warranty, I hope.
start with printer driver updates here
Feb 05, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
109 people viewed this question
old marine
old marine
