Question about Whirlpool Duet GHW9150P Front Load Washer
We get an F6 message sometimes when the spin cycle is supposed to come on? any ideas
  • 299 Answers
F6 = The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after three minutes.
1. Verify the shipping system including shipping bolts, spacers and cables are removed. 2. Unplug washer or disconnect power. 3. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU). 4. Plug in washer or reconnect power. 5. Check the MCU by looking for operations of the drive motor. 6. Check the drive motor for powered rotations.
Posted on Apr 27, 2010
I have an f6 code and the machine will not operate once it comes up
The F6 error code means that the computer on the control didnt detect that the motor reached a high speed on the spin cycle, sometimes it thinks the washer didnt spin fast enough because of a loose wire connection either on the motor or the control boards (motor &machine control) if you find that the washer did actually spin at high speed (clothes dont come out sopping wet at the end of cycle) the wire connections or the motor control board will be the potential causes of the F6 error code. Try unplugging the machine for five minutes to let the computer reset then try again. Next check the control panel wires. f6 code flashing on display Kenmore Elite HE3 Washing Machine
May 19, 2015 | Washing Machines
F6 error on Hitachi washing machine Sk 120KJS
Jul 09, 2012 | Washing Machines
Why does the washer stop during a load and "F 06"
GENE
Sep 09, 2011 | Kenmore HE2 Plus Front Load Washer
Cannot get a spin cycle, washer gets stuck before spin cycle get F6 error code
You will need to access the drain pump first by removing the bottom panel. Open clean-out on pump and check for obstructions. If none, the pump may have a broken rotor, these are the problems related to the F6 code.
Dec 01, 2010 | KitchenAid KHWS01PMT Front Load Washer
My washer is going through the wash cycle but when the spin cycle is supposed to start it doesn't spin
my washer is going through the wash cycle but when the spin cycle is supposed to start it doesn't spin
Mar 08, 2010 | GE Washing Machines
Simpson Esprit 700 Top Loader washer will not pump the water out
You situation could be caused by various problems. The easiest would be to check that no hoses on the drain side are kinked or plugged. This includes the tub to pump hose or the pump itself. Sometimes socks and other items can get stuck in the tub hose. Sometimes objects left in pockets can seize or hinder the pump ejection. Its sounds like if the unit is spinning and water is not ejected the above solutions should be checked first.
Feb 14, 2010 | Washing Machines
Clothes still wet after wool cycle
Hi
For all washing machines irrespective of the make... Wollens and acryllic do NOT have a spin cycle as the same will damage the clothes....
In wollen and acryllic mode the machind is NOT supposed to go into a spin cycle and hence you get wet clothes.....
There is Nothing wrong with your machine.
Regards
Berry
Jan 31, 2010 | Washing Machines
Will complete wash/rinse cycle, start spin and pump out but not speed up
put a full load in it, its telling you that, try 20 shirts, or 10 towels
May 27, 2009 | Hotpoint Ultima WF860 Front Load Washer
Kenmore Elite smart wash quiet pak 9 Front Load Washer
Our washer is flashing a F21 and it never finishes the load there is always water left.. what can we do to fix it?
Oct 16, 2008 | Kenmore Elite 45986 Front Load Washer
Loud screaming sound during spin cycle
The screaming noise is probably from a dry bearing in the motor, it will probably come and go and shouldnt cause to much problem, they are supposed to be self lubricating but sometime they run dry.
Oct 18, 2007 | GE Spacemaker WSLP1100D Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
118 people viewed this question
Dan Webster
Dan Webster
Sal De
