I have a ricoh MpC4000 that has a usb/sd card attached. How do I scan to the usb?
Hi
Adaptor not working any alternate adaptor for this model
Posted on Apr 28, 2010
How do i fix module authentication has failed error sc 866 on Ricoh Mpc 3002
SD card authentication error
A correct license is not found in the SD card.
? SD-card data is corrupted.
1. Store correct data in the SD card.
Feb 10, 2016 | Ricoh Aficio Office Equipment & Supplies
Ricoh mpc 4000 sc 531
531 Exhaust fan motor error
The IOB does not receive the lock signal for 10 seconds after turning on the exhaust fan motor. • Defective exhaust fan motor or connector disconnection. • Defective IOB • Disconnected harness http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio%20MP4000
May 23, 2015 | Ricoh MPC4000
Que significa error sc 863 18?
HDD data read failure- q partition
Format the hdd or replace.
Apr 11, 2015 | Ricoh AFICIO MPC4000 MPC4501 SD YLD...
Mpc4500 touch screen not working
Either the screen has failed. or the cable is disconnected. The cable that connects the screen to the main board. That cable is not user serviceable take the machine to a brother tech. I happen to be one but?
Nov 11, 2013 | Ricoh AFICIO MPC4000 MPC4501 SD YLD...
Ricoh 3045 say's cannot instal the software when i insert the SD card in it
go to Sp Mode, select 5 number option which is known as mode. now choose 2nd last option which is (for NIC) press 1 and then press # similarly (for USB) press 1 and Press #, now simply reboot this machine.
Regards;Noor Impex151-Naiper Road Mall Road Lahore+924237232511MAJ
Mar 22, 2012 | Ricoh Office Equipment & Supplies
My ricoh aficio 3025 copier has the capabilities to scan, print & fax but it only copies. Can we add those modules?
you need to buy a enable sd card for print and scan... and the problem with the fax function just conect it., the line and the phone.
Jul 09, 2010 | Ricoh Aficio 3025 All-In-One Laser Printer
Virus of my usb
Use your virus scanning software to scan and remove the virus on your USB memory stick.
OR
Use a WEB base virus scanning to remove the virus on the USB memory stick. Please click on these links to access these WEB-based Virus Scan sites :-
Trend Micro housecall
http://housecall.trendmicro.com
symantec - Norton Security Scan
http://security.symantec.com
Feb 11, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I attach Nikon CoolPix S550 (off) directly to USB port of iMac (OS 10.5.8), then turn camera on. Nikon Transfer (Preferences set to launch when camera is attached) does not launch. No sign appears on...
Some Macintosh computer systems support using a digital camera using SD/MMC card in two modes: 'Digital Camera' mode and 'Disk Drive' mode. At times, when try to use the camera using SD/MMC card in 'Digital Camera', it is not recognized by iPhoto or Image Capture. To solve such behavior, you might need to reformat the digital SD/MMC card and use backup to restore the lost files. But sometimes, you observe certain issues while restoring from backup or the backup is not available. To cope up with such situations, you should use Photo Recovery application to recover the lost files efficiently.
For an instance, consider that you perform following sequence of steps:
  • You connect your digital camera that uses SD/MMC card to a Macintosh computer in 'Disk Drive' mode
  • You switch to 'Digital Camera' mode and observe that the camera is no longer recognized by iPhoto or Image Capture
Similar behavior is also observed if you use FireWire or USB card reader to connect the SD/MMC card to your Macintosh computer and try to switch to 'Digital Camera' mode.
Solution
To prevent such errors from occurring, you should continue using the camera in 'Disk Drive' mode. You can then successfully access it through iPhoto or Image Capture. However, to solve the existing problem of the SD/MMC card, follow these steps:
  • Connect the camera in 'Disk Drive' mode or use FireWaire or USB card reader to access the card.
  • Backup all the files to your system
  • Use your digital camera to reformat the card.
Note: A digital camera using SD/MMC card uses different protocols in different modes so that to communicate with the Macintosh system. But it can only be accessed through Desktop, when connected in 'Disk Drive' mode.
After reformatting the SD/MMC card, sometimes you observe that backup is not valid and couldn't provide the required results. In such situations, you are suggested to use Digital Photo Recovery products to recover them. Photo Recovery utilities are competent tools to scan a logically crashed media using powerful scanning algorithms. Also, they provide interactive user interface that allows easy implementation
Nov 25, 2009 | Cameras
Ricoh Caplio R5 Digital camera
Not many but a FUJIFILM 1 gb card will do the trick
Nov 26, 2007 | Ricoh Caplio R5 Digital Camera
275 people viewed this question
jasbo
jasbo
